Spacer Lift Advice
Discussion in 'Suspension' started by Hams, Oct 15, 2018.
  1. Oct 15, 2018 at 1:23 PM
    Hams
    Hams [OP] New Member
    Joel
    Fort Myers, FL
    16- Pro
    Camburg uniball UCA, Cooper AT3 XLT 295, Coachbuilder shims, shackles, and steering kit, SCS Ray 10, Undercover Flex Cover Ultra, GTR Lighting LED headlight and fog.
    About to embark on .5 spacer install to maximize lift on my pro, curious if I will need to install standoff’s (spacers) on the pro skid plate? I am planning on diff and carrier bearing drop to align driveline. Also, for those who have done this, any tips to ease install would be appreciated. I vaguely remember reading to loosen control arm nut and something else prior to getting truck in the air as this will allow suspension to drop and avoid messing with lower arms cam bolts. I don’t have access to a lift so will be on jack stands.
    Thanks!
  2. Oct 15, 2018 at 2:02 PM
    art64
    art64 New Member
    Yes, you'll need the skid plate spacers to properly bolt on the skid plate. I didn't loosen my cam bolts. I used a long pry bar to lower the Lower Control Arm further down. This was when I was installing King coilovers for 3 inches lift. Also, a breaker bar will help too if you don't have impact wrench. This was done on my 2010 Crewmax 4x4. No differential drops.
  3. Oct 15, 2018 at 8:07 PM
    Hams
    Joel
    Fort Myers, FL
    16- Pro
    What are y’all doing for bump stop extensions when adding 1/2 spacer to your Pro; Wheeler super bump, coachbuilder?
    831Tun likes this.
  4. Oct 15, 2018 at 8:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You don't need the drop and it might actually be harmful. You're better off putting stress on axles than on the drive line by changing the angle of the diff.
    You don't need a carrier bearing drop either unless you feel a vibration emanating from the drive line.
  5. Oct 29, 2018 at 5:58 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Where did you find a 1/2 inch spacer?
  6. Oct 29, 2018 at 6:36 PM
    Hams
    Joel
    Fort Myers, FL
    16- Pro
    Toytec, got it from Wheelers.
  7. Oct 29, 2018 at 6:59 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Thanks- how much lift does the 1/2” add approximately?
  8. Oct 29, 2018 at 7:08 PM
    15whtrd
    15whtrd Mr. Blonde
    A 1/4” shim raises the front about 1/2” so 1/2”=1”
  9. Oct 29, 2018 at 9:15 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Wheeler super bump will collapse equivalent to stock bump stop. DO NOT USE AS STAND ALONE BUMP STOP when you have spacer lift.
