Tire Pressure Light....?
Discussion in 'Wheels & Tires' started by DawgPound82, Sep 23, 2018.
  1. Sep 23, 2018 at 5:22 PM
    DawgPound82
    DawgPound82 [OP] New Member
    I just upgraded 3 months ago from an 01 to a 15. My tire pressure light came on. I found one tire at 30 where the rest were 44. I filled it up, but the light is still on. Is there a reset switch, or do i have a problem?
    Thanks!
    Y0TA PR0 likes this.
  2. Sep 23, 2018 at 7:03 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Did you check the spare?
  3. Sep 23, 2018 at 7:19 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Sometimes it takes a couple of miles of driving for it to go off. There is also a reset button under the dash. Your owner's manual will tell you how to use it.
  4. Sep 23, 2018 at 8:06 PM
    gosolo
    Ray
    NW Oregon
    the 2015 TPMS only monitors 4 sensors and cannot be modified to do 5. It’s possible that one of the 4 is the spare, but unlikely. This would only be the case if the original owner had matched the spare ( rim and tire type) to the others and had swapped its location.
  5. Sep 23, 2018 at 8:11 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
  6. Sep 23, 2018 at 9:28 PM
    DawgPound82
    Thanks guys! hope this problem solves itself.
  7. Oct 15, 2018 at 7:31 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    IMG_1871.jpg PSI had been running around 45, now that the temps dropped my Low psi light came on. I wanted everyone to know what psi trigers the TPMS low tire pressure warning, answer it's below 41 psi. Tires are 285,55/20 BF Goodrich All terrain KO's. How much air is everyone running?
  8. Oct 15, 2018 at 7:37 PM
    Sas
    OKC, OK
    I think that's only if you have the pressure set to 45 as it's normal tire pressure. I know when I let the air out of mine down to 38 I had to reset it. It didn't go off again after that.
  9. Oct 15, 2018 at 7:39 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    45 psi ?
  10. Oct 15, 2018 at 7:41 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    35 or 38 I beleive
  11. Oct 15, 2018 at 7:54 PM
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    I didn't know you could set them, but makes since. Guess I may add some more air for winter time, who knows I may get some better gas milage.
  12. Oct 15, 2018 at 7:56 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA...:)
  13. Oct 31, 2019 at 7:50 AM
    Csebren 55
    Csebren 55 New Member
    Charles
    2008 Toyota tundra
    I just put all new sensors on my 08 Toyota tundra tire pressure light came back on a day later how do you determine which tire is low pressure
  14. Oct 31, 2019 at 8:02 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    There is a "re-set" button located on the lower kick panel on the RH side...right below the trailer brake controller. Once you set your desired pressure, you need to turn the key on and press and hold this button until the low pressure light blinks 3 times. I can't remember if the key has to be in the ACC or ON position (check manual). Once reset, when the pressure drops by a predetermined amount (no idea what that is), it will notify you.
    Good Luck!
  15. Oct 31, 2019 at 8:02 AM
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Where did you get sensors, my dealership wants some supercilious amount for them or is tHere an aftermarket that works as well?
  16. Oct 31, 2019 at 11:52 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Does the tire pressure light blink a few times when you turn on your truck?
    I also just got new sensors, but resetting didn’t work for me. Every time I turn my truck on it blinks a few times, I guess that means that I need to take it to the dealer so they can reprogram the new sensors I put in.
