Rear Brake grind after rotor and pad change
Discussion in '2nd Gen Tundras (2007-2013)' started by 1truck66, Oct 9, 2018.
  1. Oct 9, 2018 at 7:11 AM
    1truck66
    1truck66 [OP] New Member
    Rich
    2012 tundra rock warrior
    Can anyone give me some advice ?
    Changed pads and rotor on my rear brakes (2012 Tundra) terrible grinding sound after new install. I am positive I replaced all components correctly. But I did this while the vehicle was in park. Never touched the E brake. Any ideas or thoughts on what this could be and how to fix ??????????
  2. Oct 9, 2018 at 8:39 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is the noise anytime the truck is moving, or only when braking?
    I’m thinking you accidentally bent one of the dust shields and it’s rubbing on the rotor.
    15whtrd and TheBeast like this.
  3. Oct 9, 2018 at 9:20 AM
    TheBeast
    TheBeast The Beach
  4. Oct 9, 2018 at 10:35 AM
    1truck66
    Rich
    The noise is anytime the truck is moving, I will check the dust shield, I hope that's it !!! but, sounds too easy LOL
    Thanks
    TheBeast likes this.
  5. Oct 13, 2018 at 7:55 AM
    1truck66
    Rich
    Thanks for the help, It was the dust shield. The dust shield has to portions that cover the (outside diameter and inside diameter) it was the smaller inside diameter. I just banked it out a bit with a block. Presto no more noise!!!!!!!!!!!! Thanks again !!!!!
    TheBeast, landphil and 15whtrd like this.
  6. Oct 13, 2018 at 9:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Nice! Glad it was easy. Stick around and enjoy the fun!
  7. Dec 29, 2018 at 10:55 PM
    Jermalex
    Jermalex New Member
    Central Idaho
    2011 Tundra 5.7L DC LTD
    Billstien 6112/5160 shocks, EBC Rotors and Pads, lots of little tweeks
    I had the same problem on my 2011. Mine was on both sides in the area closest to where the caliper mounts. Several calculated whacks with a flat head punch and it was dead quite again!
