2006 4.7 cranks but no spark
Discussion in '1st Gen Tundras (2000-2006)' started by shaw0531, Jun 11, 2016.
  1. Jun 17, 2016 at 10:55 PM
    #91
    shaw0531
    shaw0531 [OP] New Member
    Jake
    2006 Spectra Blue Mica Tundra SR5 2WD DC
    It says I can't open that file
  2. Jun 17, 2016 at 10:56 PM
    #92
    shaw0531
    Jake
    I did that earlier and it wasn't reading anything that I saw. What would this indicate if it did/didn't?
    Yes at the end of April
  3. Jun 17, 2016 at 10:58 PM
    #93
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Weird, its a pdf. Maybe try again or restart PC.
  4. Jun 17, 2016 at 11:08 PM
    #94
    shaw0531
    Jake
    Well I'm on my phone so that is probably my issue. I will try it tomorrow morning
  5. Jun 18, 2016 at 8:15 AM
    #95
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    No signal or break in wiring to ecm. If it was getting signal you should see a rpm.
    If ecm doesn't see the crankshaft turning, it will not fire engine.
    I'm going on a far stretch with this could be a jump in timing too. If the crank and cam doesn't match it will be a no start too.
  6. Jun 18, 2016 at 8:38 AM
    #96
    shaw0531
    Jake
    It's not seeing any rpm on either the truck gauge or he UG
  7. Jun 18, 2016 at 9:12 AM
    #97
    Mike Tread lightly.
    south carolina
    You have a break in the wiring some where. Doesn't rule out a defective part (sensor)either now. most of the time it's at connection points.
    Do you know how to get the engine to tdc ( top dead center). If so put it at tdc and pop off the timing covers( top ones) and see if the marks are lining up..
  8. Jun 18, 2016 at 9:19 AM
    #98
    shaw0531
    Jake
    I'm throwing in the towel guys. I appreciate all the help and suggestions and advice, but this issue is beyond my mechanical knowledge and realm. I'm going to have it taken to a shop on Monday and let them deal with it and cut my losses.
  9. Jun 18, 2016 at 9:41 AM
    #99
    Mike Tread lightly.
    south carolina
    Let us know what they find.
  10. Jun 21, 2016 at 4:04 PM
    #100
    shaw0531
    Jake
    Got the truck back today. When the shop did the timing belt and water pump, they didn't noticed the wire running to the crank sensor had gotten wedged between some metal and they bolted it back together pinching the wire. They called today and said it was their fault what happened and I went to pick it up and they didn't charge me for towing or anything. Even though this was a fault on the shop they corrected the fault and admitted to the wrong and did me right and got me back on the road. To me that shows true character and a good shop. Glad to say I'm back up and running!
    T-Rex266 and driverdog like this.
  11. Jun 21, 2016 at 4:13 PM
    #101
    Mike Tread lightly.
    south carolina
    Common mistake on wiring route.. @LOTSOFTOYS will agree here.
    glad it running like it should :thumbsup:
    shaw0531[QUOTED][OP] likes this.
  12. Jun 21, 2016 at 4:22 PM
    #102
    shaw0531
    Jake
    No kidding! Definitely recommend them to anyone!
    I again appreciate all the help from members on here trying to help me self diagnose the problem in the first place. Couldn't have asked for better help!
  13. Jun 21, 2016 at 5:14 PM
    #103
    shaw0531
    Jake
    Thanks Ron!
  14. Jun 22, 2016 at 7:23 PM
    #104
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Right on! Yup wire routing is important on this engine
