Anybody have experience with OEM Audio + packages?
Discussion in 'Audio & Video' started by benboosted, Jul 15, 2018.
  1. Jul 15, 2018 at 10:02 AM
    benboosted
    benboosted [OP] New Member
    Ben
    2014 SR5 CrewMax
    Icon Stg 6 suspension // Coachbuilder +2 shackles // Ride Rite airbags + on board air compressor // SDHQ hidden winch bumper + Platinum Zeon 10k winch // OEM Bi-LED headlight conversion // Rigid fogs // NSV LED bar // Method wheels // 295/70 Nitto Trail Grapplers
    I'm no audiophile as I'm sure most of you here are, but I would like to step up the sound in my '14 CM without paying a ton of money to installers. It seems OEM+ guys have a couple very attractive and relatively simple packages with handy video "how-to's" that I could probably attempt myself.
    Has anyone installed their product before?
    Link to their site (I have the non-JBL system) http://oemaudioplus.com/toyota/tcm/
  2. Jul 15, 2018 at 10:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Only seen one or two people go with the OEM+ kits and I think they were the jbl systems.
    Since you have non jbl, just get a amp that takes speaker level inputs and swap it with the factory amp.
    Get ahold of James at tech12volts and let him know what you are trying to accomplish and that you want to spend and he will hook you up
    benboosted[OP] likes this.
  3. Jul 15, 2018 at 11:22 AM
    benboosted
    Ben
    2014 SR5 CrewMax
    Thanks man. Just eyeballing it, does the OEM+ seem particularly expensive?
  4. Jul 15, 2018 at 11:44 AM
    Sunnier
    Sunny
    San Diego, CA
    Tech12volts or ********* are the best-rated, least expensive, do-it-yourself-with-great-customer-service-if-you-need-help options I've seen discussed on this forum, to those of us who don't know anything about wiring and audio. ********* has discounts sometimes. Tech12volts, you let 'em know what you need to accomplish and what you can spend, and they'll create a set-up for that.
    Jai LI, B737 and benboosted[OP] like this.
  5. Jul 15, 2018 at 2:17 PM
    benboosted
    Ben
    2014 SR5 CrewMax
    man that's great - appreciate the guidance!
    Sunnier[QUOTED] likes this.
  6. Jul 18, 2018 at 3:29 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    These days with all the aftermarket parts you don't have to be one. go to crutchfield.com click what fits my car..punch in what you have and what you want to do. Even if you don't get it from there it will give a good idea of what's involve. Most people replace the speakers and add an amp. Both are pretty straight forward. If you want to add a sub there are plenty of relatively inexpensive options.
    Sunnier likes this.
  7. Jul 18, 2018 at 4:04 PM
    Sunnier
    Sunny
    San Diego, CA
    @benboosted this is good advice about crutchfield.com. A lot of people on here with some audio-build know-how have gone that route. Keep in mind though that the head units for our Tundras are so lame that replacing the amp and speakers with most after-market options won't improve sound quality (there'd be noise) which is why a few specific products have been developed to improve the sound of our lame systems specifically. Of course, if you swap out everything including the head unit, the sky's the limit.
  8. Jul 18, 2018 at 4:31 PM
    xj2202009
    x
    Lutz, Fl
    I started with replacing the headunit. added a sub, two amps, door speakers are next. by the way.. your sr5 should have an amp under the front passenger seat. I believe one of the vendors here have an after market amp that's plug and play.
  9. Jul 18, 2018 at 4:42 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    The biggest problem I've had in the past with aftermarket audio components is with hiss and hum. The OEM Audio + system apparently doesn't have that issue. I honestly don't want to dick around trying to put a system together at this point in life. I just want to install it so I can enjoy it and move onto other things. If I were still in my teens or twenties I'd be all over researching/building/assembling a badass custom system. That OAP solution checks a lot of boxes for me.
    Jai LI and 5.7TRDProm like this.
  10. Jul 18, 2018 at 4:55 PM
    xj2202009
    x
    Lutz, Fl
    I'm far from a teen don't care for loudness but does have to sound like I'm in a symphony. If that does it for you go for it. I would search online reviews.. I like to start with the lowest ones first. 5 stars don't tell me anything..I want to know what pissed the customer off and could I live with it.
  11. Jul 18, 2018 at 5:03 PM
    marxtoy57
    marxtoy57 New Member
    Mark
    2016 Toyota Tundra SR5
    Many. Lol
    I installed an OEM+ system in my 2016 SR5 without JBL speakers about a year and a half ago. Back when OEM+ was just beginning to produce systems for the non-crewmax cab Tundras (double cab). They make a sub-woofer enclosure with 8" sub that fits under the right passenger seat in the double cab Tundra's like a glove and looks OEM. Of course they also have systems for the crewmax cab trucks. Best upgrade I've done to my truck yet! Also, their systems are tuned for our trucks. No dicking around with EQ's and time delays. I just wanted something that was easy to installed and didn't require a lot of tuning. This system from OEM+ was it!
    http://oemaudioplus.com/toyota/tdc/
    I installed the Reference 500Q system which includes the amp (which replaces the factory amp). Plug and play.
  12. Jul 24, 2018 at 8:16 PM
    djkoto
    djkoto New Member
    Mark
    2015 Black Tundra TRD OFF ROAD
    I have same system in my 2015 SR5 for about a year. It was best upgrade I ever done to my Tundra. I also have android head unit. The sound unbelievable!!!
  13. Jul 24, 2018 at 11:19 PM
    marxtoy57
    Mark
    Many. Lol
    Agreed!
  14. Sep 15, 2018 at 12:55 PM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I just ordered the Reference 500Q system from them. I can’t wait to install it!
    marxtoy57 likes this.
  15. Oct 7, 2018 at 5:13 PM
    Dwreck91
    Dwreck91 New Member
    Central Valley, Ca.
    2018 Black DC SR5 TRD Offroad 4x4
    How did it turn out, are you happy with it? Does the one 8" sub provide adequate bass?
  16. Oct 7, 2018 at 5:47 PM
    BigGreek
    BigGreek New Member
    Evan
    2016 Tundra Platinum
    I did the JBL Enhancement on my Platinum CM. The upgrade in sound and especially the ease of installation make this worth it. I wanted to keep the stock radio also.
    The non JBL if I remember correctly replaces more speakers as well.
    My vote is oem audio plus.
    TundraLLama, sprtbkr and Dwreck91 like this.
  17. Oct 7, 2018 at 8:20 PM
    sprtbkr
    Scott
    Denver, CO
    It sounds great. I’m not 22 anymore, so I don’t need for the world to feel my bass as I drive by. ;). My husband the audiophile was impressed with the sound.
    Dwreck91[QUOTED] likes this.
  18. Oct 7, 2018 at 8:59 PM
    Dwreck91
    Dwreck91 New Member
    Central Valley, Ca.
    Excellent, yes I agree, I dont want over-powering bass either, I just want to be able to feel that I do indeed have a subwoofer and it isnt overshadowing or drowning out the lyrics of a song. I have been doing much research and to be honest I have kind of been trying to find every reason not to go with OEM Audio+ and doing a custom build but everything I seek in an audio system it seems as though OEM delivers so I think I am just going to take the plunge! Thanks for the feed-back.
    sprtbkr[QUOTED] likes this.
  19. Oct 7, 2018 at 9:13 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I replaced (had installed by pro's) all my speakers with JL audio speakers and an Alpine amp for $600 and it's the best thing I have done . This was on a base 2015 SR DC
    Dwreck91 likes this.
  20. Oct 7, 2018 at 10:16 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Can you just get the enclosure for the sub under the back seat? Kinda seems expensive for the whole thing without being able to get your own speakers to your liking
  21. Oct 7, 2018 at 10:55 PM
    Dwreck91
    Dwreck91 New Member
    Central Valley, Ca.
    No you can't get the sub alone, the minimum package you can get is the sub, amp, wiring harness, and tweeters. The reason being is they have done extensive research and scientific acoustic development to produce a cinematic audio solution for your specific vehicle. They dont want to diminish their brand quality due to their components being implemented in an inferior, non-enhanced audio set-up. I do not blame them one bit for this, If I spent extensive R&D money to produce a harmonious audio package I'll be damned if my components get dinged due to improper implementation.
    sprtbkr likes this.
  22. Oct 8, 2018 at 6:56 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Extensive scientific acoustic development :goingcrazy: I guess when I upgrade audio I have to get this lol
  23. Oct 8, 2018 at 7:39 AM
    Dwreck91
    Dwreck91 New Member
    Central Valley, Ca.
    Haha, ya I was pretty drunk when I wrote that so I probably used a couple more words than were necessary, sorry. Point being though they designed, tested, and tuned all the components to work together. I'm going to pull the trigger on the system myself pretty soon. Hope it lives up to the hype!
    jmdaniel and Alexstundra[QUOTED] like this.
  24. Oct 9, 2018 at 3:48 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    How do ya get the jack out? Does the sub pop out easily
  25. Oct 9, 2018 at 4:04 PM
    sprtbkr
    Scott
    Denver, CO
    if you lift both seats and lift the bin cover on the larger seat, you can just lift the sub enclosure out. They give you plenty of wire so you can totally set it out of the way on the back seat floor when accessing the jack.
    Jai LI and Alexstundra[QUOTED] like this.
  26. Nov 12, 2018 at 9:04 PM
    RB1
    RB1 New Member
    2018 Tundra Sport DoubleCab 5.7
    So I think I understand that the sub enclosure sits in the storage box ... I'm assuming it is friction fit somehow so it doesn't have any wriggle room ... however considering the storage box is just plastic and not well bolted in I'm wondering how there is no rattling from the storage box when the sub is pumping away? One would think the plastic from the box would be vibrating ... no?
    Rica25 likes this.
  27. Nov 13, 2018 at 10:04 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    wonder this same thing, I have the DC under seat storage and whole thing is two bolts. Went JRT when I got scared of fit of other.
  28. Jul 30, 2021 at 9:13 AM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    I had a bump this because I started a new thread but just saw this one. Are you overall pleased with the system and did you install it yourself I have a pro do it? Thank you
  29. Jul 30, 2021 at 10:28 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I am curious about this as well. I watched the install video, looks very, very easy!
  30. Jul 30, 2021 at 12:39 PM
    BigGreek
    BigGreek New Member
    Evan
    I did install it myself. Super easy, removing the rear seat was the toughest part. I was happy with it but wanted more so I jumped on the @james@tech12volts group buy a while back.
    TundraLLama[QUOTED] likes this.
