My 03 build
Discussion in '1st Gen Builds (2000-2006)' started by Brown Bear, Sep 7, 2017.
  1. Jun 30, 2018 at 7:22 AM
    Brown Bear
    Brown Bear [OP] New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Yes the lights are 2x2. The measurement is of the actual lens. The overall dimension is 3x3 on the face of it.
  2. Jun 30, 2018 at 8:15 AM
    Brown Bear
    Nor cal
    03 TRD offroad
    East TN Yota likes this.
  3. Jun 30, 2018 at 9:18 AM
    BestGen
    BestGen Free Kyle!
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Do the lights contact the windshield when raising the hood? Like the clean install.
  4. Jun 30, 2018 at 12:00 PM
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Best looking 1st gen tundra I've ever seen. Great lift!
  5. Jun 30, 2018 at 2:40 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    The lights do not hit the windshield when opened.
  6. Jun 30, 2018 at 2:46 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Thanks man. I still get excited every time I drive it.
  7. Aug 15, 2018 at 5:21 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Sway bar end link quick disconnect #2:
    My first attempt I tried making a disconnect out of the stock sway bar end link. I had bought a cheap end link off of Amazon to build it with. Well bolting one on to the lower control arm the Allen key at the end of the bolt stripped out well being tightened. After realizing how cheap the part was that I had started with I decided to go a different route. I made new disconnects and have had them on for about a week now. They are working as planned. Disconnection and reconnection is easy as long as the truck is sitting onrelatively flat ground.20180801_180701.jpg 20180802_171556.jpg 20180809_185113.jpg 20180814_161408.jpg 20180814_160148.jpg I cut the head off a 7" X 5/8 bolt for the main shaft. The heim joint is 5/8 X 5/8 with a 1/2" reducer. A 1/4" pin connects the two. I used about a foot of 1/16" cable to tie the pin to the top of the end link. Then I drilled a 1/4" whole at a upward angle of 45° in the frame for the pain when it is disconnected.
    5N0W808, 2002tii, 03tundra4x4 and 5 others like this.
  8. Aug 15, 2018 at 5:41 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Very thoughtful. Is this sway linkage something you thought up? Or, did you see it somewhere? I love the creativity aspect and the safety cables set up.
  9. Aug 15, 2018 at 7:15 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    I got the idea from a buddy. He has pretty much the same thing on his 3rd gen 4Runner.
  10. Sep 5, 2018 at 5:30 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    Are those 6112s?
  11. Sep 5, 2018 at 5:47 PM
    Brown Bear
    Nor cal
    03 TRD offroad
  12. Sep 7, 2018 at 2:28 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    Great looking 1st gen!
  13. Sep 7, 2018 at 9:04 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Thanks bud!
  14. Sep 7, 2018 at 9:29 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Ok, stupid question here. What is the practical purpose of disconnect sway bar links? Easy of access to steering components? Performance off road?
  15. Sep 7, 2018 at 11:11 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Disconnecting the sway bar is for off road performance. It allows your front suspension to operate independently of each other. It makes for a smoother ride on bumpy dirt roads. It also helps to get more flex for better contact with the ground. Some people just take there sway bar off. But with no sway bar on what off road performance you gain, you lose in on road performance. So basically I like having my sway bar disconnect well off roading. But I like to have it connected well on road. Especially on windy roads and well towing. The quick disconnect just makes it easier to switch between having the sway bar on or off.
    Rileymor, Outbound and ethan1911 like this.
  16. Sep 8, 2018 at 6:14 AM
    Outbound
    Aaron
    Northern Alberta
    Good to know! Now I need one. :D
  17. Sep 8, 2018 at 6:20 AM
    Blueknights75
    Ron
    Clayton, NC
    Love that color!!
  18. Oct 31, 2018 at 12:16 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    My understanding is, and a reason to go with the RCD lift, is that the spindles that come from RCD are much more substantial.
  19. Oct 31, 2018 at 12:18 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm digging your build. I'm jealous of your rear leafs.
  20. Nov 1, 2018 at 9:27 AM
    #50
    Brown Bear
    Nor cal
    03 TRD offroad
    The beefier spindles is one of the reasons I picked the RCD over the Tuff Country. That and I can fit 35s on opposed to 33s with the Tuff country lift. Not only that but one day in the future I will still be able to medium or long-travel it. The leaf pack is one of my favorite things I have done to the truck. With 11.5 inches of travel in full flix and around 500 pounds more payload.
    Rileymor likes this.
  21. Jan 18, 2019 at 12:59 PM
    #51
    Brown Bear
    Nor cal
    03 TRD offroad
    I got a custom one piece driveshaft made. It's a lot lighter and eliminated my issues I had with the old two piece due to my 4 inch lift in the rear. I went to B&W Driveline Plus. They did a good job and so far i am very happy.
    2002tii, Darkness, 00TundraZ and 5 others like this.
  22. Feb 24, 2019 at 8:23 PM
    #52
    Casper421
    In the woods
    06 DC
    Any update?
  23. Feb 25, 2019 at 10:42 PM
    #53
    Brown Bear
    Nor cal
    03 TRD offroad
    So far so good. The only issue I have had is when disconnected sometimes dirt or mud gets down in the female part of the heim joint. Making it impossible to get the shaft of the end link back in the heim joint. Most of the time I just blow it out with my compressor to clean it out. I also had to replace one of the pins. The little locking ball popped out.
    Casper421[QUOTED] likes this.
  24. Feb 25, 2019 at 10:45 PM
    #54
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    Welcome from SC. Nice truck!
    Brown Bear[OP] likes this.
  25. Mar 12, 2019 at 8:47 PM
    #55
    03tundra4x4
    03tundra4x4 New Member
    Jordan
    Bristol, TN
    lifted 03 tundra access cab
    2 in front spacer with bilstein 5100s, wheelers 3 pack springs in the rear and 16x8 -10 level 8 mk6 on lt285/75/16 falken wildpeak at3
    Can you post a link to the parts used?
  26. Mar 14, 2019 at 4:28 PM
    #56
    Brown Bear
    Nor cal
    03 TRD offroad
    Sorry it took me a few days to get back to you. Here is everything I used.
    2- Heim joint
    https://frsport.com/qa1-precision-p...9YzOcmQZVxWOcbr76FWIZlmna5z9C-yIaAh0dEALw_wcB
    4- 5/8 x 1/2 Misalignment Spacer
    https://www.ruffstuffspecialties.co...Product_Code=58TO12SS&Category_Code=58REPARTS
    Hardware store or auto parts store
    1- 5/8 metal drill bit
    1- 1/2 metal drill bit
    1- 1/4 metal drill bit
    2- 3 x 1/2 grade 8 bolts
    6- 1/2 washer
    2- 1/2 locking nut
    2- 7 x 5/8 bolts
    6- 5/8 washer
    2- 5/8 nut
    2- 5/8 locking nut
    2- New set of sway bar end link bushings (drill the center hole out to 5/8)
    2- 1 1/4 x 1/4 pin
    4- 1/16 cable clamp
    3 feet of 1/16 cable
    Voss, the red, Casper421 and 2 others like this.
  27. Mar 14, 2019 at 4:36 PM
    #57
    03tundra4x4
    Jordan
    Bristol, TN
    Thank you! Saw a YouTube video of the exact same swaybar disconnects.
  28. Mar 14, 2019 at 4:41 PM
    #58
    Brown Bear
    Nor cal
    03 TRD offroad
    That's cool. I got a buddy with the same thing on his 4Runner. He was the one that helped me figure out everything I needed.
    03tundra4x4 likes this.
  29. Mar 14, 2019 at 5:07 PM
    #59
    Casper421
    In the woods
    06 DC
    :yes:
  30. May 8, 2019 at 5:25 PM
    #60
    JustGotDuals
    JustGotDuals New Member
    Awesome build, I am so jealous of your truck. Maybe some day I will make mine like yours haha @Brown Bear did you ever do that shackle flip mod that you had posted a picture of? Its been a long while, but If so, how much lift in the rear did you get out of it. Thanks
