Alignment analysis - need help from the experts
Discussion in 'Suspension' started by agentcox000, Jul 25, 2018.
  1. Jul 25, 2018 at 4:17 PM
    agentcox000
    agentcox000 [OP] "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I got my lift installed and alignment done today. Numbers seem close to what I told them but want your opinion. The steering wheel shakes bad at anything above 40mph. I’m taking it back tomorrow to have them check the tire balance as well, but wonder if I need to make any alignment adjustments? Thanks for any input you could give!
    Lift - ADS coilovers, MCM UCAs, Deaver K37s, 3/4 shackles - approx. 3/1 lift achieved
    Tires - Toyo open country A/TII 285/75/18, method race wheels +18 offset
    831Tun likes this.
  2. Aug 17, 2018 at 12:29 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Any results on this? BTW I want your alignment numbers haha currently have Camburg uca.... might make the switch to MCM. But for the steering wheel shake I have no idea. Maybe the wheels got a bad balance. Or a wheel weight fell off? Sorta have a slight issue with shacky wheel on the wife’s 4Runner too.
    agentcox000[OP] likes this.
  3. Aug 17, 2018 at 12:51 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Those numbers are fairly close to mine, minus the Caster, I'm closer to 3 degrees.
    Total toe looks good.
    I'd rather be on the positive side of camber slightly (like you are), since the front end could settle a little or settle with added load.
    The shake sounds for sure like a wheel out of balance. Are the tires new as well?
    Had a friend with a set of Nitto's (37's) that would not balance with weights. He must have brought it back to the shop 2-3 times. Required the ceramic balancing beads in the tire. The truck was perfectly smooth at every speed after all the weights were pulled and they put one bag of the beads in each front tire.
  4. Aug 17, 2018 at 1:43 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Ended up being one of my Method Race Wheels was calling for over 20oz of weight for just the wheel itself. Currently going through the exhausting process to return it to MRW. I purchased a new one that balanced great and everything feels 100x better. Still pulls to the right slightly but overall the truck drives great.
    equin likes this.
  5. Aug 17, 2018 at 1:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The alignment numbers look good to me. You could use more caster on the right but if it's not pulling, don't bother.
    I would guess your steering wheel shake is from the tires/ balance?
  6. Aug 17, 2018 at 1:58 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Yup one of my Methods was way out of round. Bought a new one and shake is gone. Pulling slightly to the right but it’s a 100x better now
    equin and 831Tun[QUOTED] like this.
  7. Aug 17, 2018 at 2:02 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :thumbsup: Another .2 caster on the right might eliminate the slight pull. Maybe @Vizsla can verify?
  8. Aug 17, 2018 at 3:00 PM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    wow corey! did you visually see all the weights on one wheel. 20 oz is over a pound ... thats insane! you figured the person balancing it would figure something was not right with the wheel. i am glad you figured it out.
    can anyone confirm what is the range of weights to add during wheel balancing that is acceptable. thank you in advance.
    cheers
    831Tun and agentcox000[OP] like this.
  9. Aug 17, 2018 at 3:05 PM
    tinman10101
    Tinman
    2016 MGM Crewmax
    just had my method roost balanced and saw a strip weights added to one wheel. looked closer and noticed they were all 1/4 oz weights. they feel good and have driven them over 75 mph just to test.
  10. Aug 17, 2018 at 5:03 PM
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Ya needless to say I am no longer a customer of the first tire shop I went to. I know there is a lot of negative reviews and opinions on Discount Tire out there, but the one in Buckeye, AZ was phenomenal helping me fix this issue. Went out of their way and charged me next to nothing to fix another shops negligence. Gained a customer
  11. Aug 17, 2018 at 8:31 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As far as I know there's no standard but 1% of the tire+wheel weight is generally considered acceptable.
    tinman10101[QUOTED] likes this.
