Tips for installing Bilstein 6112?
Discussion in 'Suspension' started by phonyteachr, Jul 18, 2018.
  1. Aug 14, 2018 at 3:06 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    My 3/1.5 setup. Front is setup at very top setting with a CB shim and JBA UCA at each side. Rear is 5160 with Toytec shackles.
  2. Aug 14, 2018 at 4:33 PM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Looks sharp what are the wheel & tire deets?
  3. Aug 14, 2018 at 4:34 PM
    Noice!
  4. Aug 14, 2018 at 5:41 PM
    matictundra
    Franco
    AZ
    Nitto Terra Grappler G2 295/60R20 on fuel vector wheels.
    TacoWuzzaTurd[QUOTED] likes this.
  5. Aug 15, 2018 at 4:00 AM
    TacoWuzzaTurd
    Scottsdale AZ
    Did it settle or is it still nose high? How long did it take to settle? How does it look now?
  6. Aug 15, 2018 at 5:21 AM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Mine settled in nicely after a month or so. 6112/5160 setup. 1.9 up front
  7. Aug 15, 2018 at 11:46 AM
    matictundra
    Franco
    AZ
    Mine has not settled in yet after 2.5 months, which included two long distance and two off-road trips. I'm kinda surprise by it. But I did give it 6 months to settle and will do free re-alignment then.
  8. Aug 15, 2018 at 12:02 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    If I go with the 1.9 setting, and then decide to go to the highest setting, how hard is it to “move the clip”?
  9. Aug 15, 2018 at 12:31 PM
    TacoWuzzaTurd
    Scottsdale AZ
    You'll have to pay for installation all over again essentially. They have to remove them, disassemble the shock and spring, reset the clip to new desired setting then reinstall.
  10. Aug 15, 2018 at 12:43 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Ok thanks
  11. Aug 15, 2018 at 12:47 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Expectations management. In other words if you talk to them up front they may give you a break on labor if you decide you want to readjust. My shop offered this...although we never got to details as too how much they would shave off.
  12. Aug 15, 2018 at 12:47 PM
    matictundra
    Franco
    AZ
    I do my own work, so no big deal for me. I also opted for lifetime alignment, so that is also free. FYI, I highly recommend an alignment when you mess with suspension geometry such as height change.
  13. Aug 15, 2018 at 12:49 PM
    TacoWuzzaTurd
    Scottsdale AZ
    Yep had them do an alignment. I did the 6112s, 5160s and AAL on my taco in my driveway. For 325$ labor I was happy having someone do this job this time around.
    equin likes this.
  14. Aug 15, 2018 at 1:05 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I agree. I did the 6112s and 5160s myself. I don’t mind replacing the rear shocks. But if I decide to adjust the 6112s to a different height or swap them out for something else, it’s worth it to me to have a shop do it next time if the labor rate is fair.
  15. Aug 15, 2018 at 1:30 PM
    phonyteachr
    phonyteachr [OP] New Member
    2018 SR5 TRD off-road CM
    Looks like it has evened out a bit judging by line for spot next to me under truck..IMG_20180813_124555307_HDR.jpg IMG_20180813_124612994.jpg
  16. Aug 15, 2018 at 1:34 PM
    phonyteachr
    Nice...what size wheels?? Stock UCA's?
  17. Aug 15, 2018 at 1:37 PM
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    Has anyone had their truck go out of alignment after the lift? I assume I need to align it more often with big tires etc., but thought it would be longer than 6 months or so. Is this maybe just a 1-off? I have 6112/5160/TC UCA/Shackle.
  18. Aug 15, 2018 at 1:39 PM
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    Hows the ride on the top setting?
  19. Aug 15, 2018 at 2:08 PM
    Borgs
    Borgs New Member
    PA
    I think it is difficult. Like ripping them off the truck and starting all over. The Fox’s May be adjustable on the truck but don’t quote me.
    equin likes this.
  20. Aug 15, 2018 at 2:10 PM
    #50
    Borgs
    Borgs New Member
    PA
    Stock, stock. Tires are BFG KO2 stock size.
  21. Aug 15, 2018 at 4:02 PM
    #51
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I dont have many miles on it yet, maybe 5 , to be 100% honest I have not noticed much a difference.
  22. Aug 15, 2018 at 5:31 PM
    #52
    equin
    Ed
    DFW, TX
    Correct. There might be a way or some special shop tool that can compress the coils while still on the truck, but I’m not aware of anything like that. So you have to remove them, then go through the coil spring compression process in order to move the clip to the desired setting, and then reinstall and get another alignment.
    With adjustable coilovers, you can just jack the truck up and adjust them on your own with a spanner wrench. I find it easier to do with the wheels off. Still have to get it aligned again, though.
  23. Aug 15, 2018 at 7:19 PM
    #53
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    Matictundra
    Great looking truck
    matictundra likes this.
  24. Aug 16, 2018 at 11:57 AM
    #54
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    No chance they are making that adjustment on the truck. Compressing those springs is no joke. If on the fly adjustment is a major concern, these are not the right choice.
    -Jim
    equin[QUOTED] likes this.
  25. Aug 16, 2018 at 12:24 PM
    #55
    phonyteachr
    Just an update..after a week a settle and a few miles front and back are within an 1/8 of an inch or level for government work! At 2.25 for drivers front and 2.5 for passenger front...both r set at 3rd highest or 1.9....keep u posted on anymore settling...looks level to me!IMG_20180816_094025740.jpg
    Gabby_Miles and equin like this.
  26. Aug 16, 2018 at 2:21 PM
    #56
    matictundra
    Franco
    AZ
    Thanks. I'm actually itching for 37" tires now.
  27. Aug 21, 2018 at 9:43 AM
    #57
    groverdill
    joe
    Rathdrum ID
    Took the truck in for alignment and get the Falken ATW3s on and all 4 of the cam bolt sleeves are seized. I kind of expected this and seeing what has to be done I left it at the shop for them to sort it out. Im sure it is not going to be cheap but it has to be done.
  28. Aug 21, 2018 at 10:03 AM
    #58
    Paulwall91
    Paulwall91 New Member
    18 blue double cab
    Maybe a dumb question these shocks can be installed on stock without a lift kit? I read something about without lifting the truck the shocks would be maybe too compressed?
  29. Aug 21, 2018 at 10:18 AM
    #59
    TacoWuzzaTurd
    Scottsdale AZ
    Well the 6112s are a spring + shock combo-- pretty much a coilover assembly. They replace the stock spring/shock when you install them. You could set the adjustment on the 6112 to ride about stock height if that's what you're asking. Basically if you set the adjustment on the 6112 higher, it will preload the spring more and you'll get more lift. If you set the adjustment lower, you'll get less "lift."
    https://youtu.be/A0ww8bRNrw4 check this video out
  30. Aug 21, 2018 at 10:19 AM
    #60
    matictundra
    Franco
    AZ
    6112 is a kit. It is the lift kit. It will produce .75" average lift at the lowest setting.
    See pic.
    K6BRY, silverhack and TacoWuzzaTurd like this.
