Icon six speed or Rebound?
Discussion in 'Wheels & Tires' started by SeanO86, Jun 1, 2018.
  1. Jul 9, 2018 at 7:57 PM
    bcpnick
    bcpnick New Member
    Utah
    2018 Tundra TRD Sport DC
    Yes. They moved mine over from my stock wheels when I had mine installed.
  2. Jul 9, 2018 at 9:39 PM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    Mine work with the sensors. no issues.
    equin, Icon_Adrian and JDL17CM4x4 like this.
  3. Jul 10, 2018 at 7:48 AM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    Pretty much any aftermarket wheel now a days are designed to work with the TPMS sensors because people won't buy wheels if they have to have a tire light on their dash.
    equin and Erichudgins like this.
  4. Jul 24, 2018 at 3:10 PM
    Lobodog1
    Lobodog1 New Member
    Looks SWEET. Can you confirm what size the X3's are and maybe your suspension specs?? Thanks!
  5. Jul 25, 2018 at 6:53 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    :threadjacked:
    I see your running 35’s, with a 3inch lift? If so do you have the cab mount chop? If not do you rub? I just ordered my 315/70/17’s as well as relentless fabs can mount plate JUST IN CASE but I really don’t wanna do it. Also gonna be running the rebounds I’m about to order from sdhq.
    MikeyMTBs likes this.
  6. Jul 25, 2018 at 7:18 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  7. Jul 25, 2018 at 7:23 AM
    Cmilla25
    Cmilla25 New Member
    2015 Tundra Trdpro
  8. Jul 25, 2018 at 7:55 AM
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    Lets see a whole truck sideways view por favor?????? PLEASE!!!! :popcorn:
    Darkness and Rica25 like this.
  9. Jul 25, 2018 at 8:01 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    JDL17CM4x4[QUOTED] likes this.
  10. Jul 25, 2018 at 2:41 PM
    crochetjohn
    I do not have the cab mount chop. I did have to remove the front lower fender liner. Otherwise it clears.
  11. Jul 25, 2018 at 2:42 PM
    crochetjohn
  12. Jul 26, 2018 at 7:38 AM
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
  13. Aug 13, 2018 at 12:28 PM
    Llahsram11
    Llahsram11 New Member
    2016 White Stormtrooper
    Im running 35's. I have Icon 2.5 coils with Camburg UCA's.
  14. Sep 10, 2018 at 6:39 PM
    ChrisTRDPro
    MT
    Got mine mounted up today. 315/70r17 Falken Wildpeak AT3Ws. All I had to do was remove the rear mudflap and no rubbing! No alignment yet though, not sure I need it. Could probably add more caster and put the flaps back on...
    What torque are you guys running for the lugs? I did mine to 100ft/lbs, and they seemed to come loose pretty fast. Most of them needed a quarter turn to get back to 100 after I did a 5 mile trip. About half as many needed it after the next 5.
    Tundrago, parker44, equin and 2 others like this.
  15. Sep 10, 2018 at 6:40 PM
    TheBeast
    TheBeast The Beach
    are you using ET lugs ?
  16. Sep 10, 2018 at 6:41 PM
    ChrisTRDPro
    MT
    Yep, I’m using the ones camburg sells.
    TheBeast[QUOTED] likes this.
  17. Sep 11, 2018 at 9:56 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Good question. I had Discount Tire install mine using the same spline drive conical nuts used on my previous MB 352s. I'll have to double-check and make sure they haven't loosened.
  18. Sep 26, 2018 at 5:51 AM
    pedroyap
    pedroyap New Member
    Peter
    Just had mine installed on a 2010 CrewMax and no CMC/BMC. Only minor rub on the passenger side front fender liner behind the fog lamps. No big deal. 315/70/17 toyo open country MT.
    22A2451A-C7BC-4777-9B4A-FF27ED9B109E.jpg 68A1A979-2D0C-4F7A-8B7D-441EBE2C1551.jpg
    Hattori, TheBeast, parker44 and 3 others like this.
  19. Sep 26, 2018 at 11:12 AM
    Tundrago
    Tundrago New Member
    Nashville area
    2016 SR5 upgrade. TRD
    My bronze rebounds are enroute! Your picture confirmed for me that my stock steps really need to go.
    Nice truck man, the metals look pretty sweet together.
  20. Sep 26, 2018 at 11:15 AM
    #50
    pedroyap
    pedroyap New Member
    Peter
    I plan to take out my step bars... they don’t look good on the truck :)
    TheBeast likes this.
  21. Sep 27, 2018 at 8:26 AM
    #51
    pedroyap
    pedroyap New Member
    Peter
    No more step bars
    C9622232-EBFC-403B-BCEE-78202569CE15.jpg F2FDA79C-0E3C-4AB9-B996-E7754C8B14DC.jpg
    Newm, JDL17CM4x4, Tundrago and 3 others like this.
  22. Sep 27, 2018 at 9:03 AM
    #52
    TheBeast
    TheBeast The Beach
    very nice !
    Rica25 likes this.
  23. Oct 28, 2018 at 10:13 PM
    #53
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    What's your suspension setup?
  24. Oct 29, 2018 at 6:28 AM
    #54
    pedroyap
    pedroyap New Member
    Peter
    I am on fox 2.5 front with 3” lift and fox 2.0 rear with 2” shackle lift. Procomp UCA and a drop kit
  25. Mar 6, 2019 at 1:15 PM
    #55
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    Ordering these wheels. Can anybody confirm whether 285/75/17 tires will fit with Bilstein 6112's set at 2" with no trimming required?
    equin likes this.
  26. Mar 6, 2019 at 3:59 PM
    #56
    equin
    Ed
    DFW, TX
    I took the front bumper plastic liner off before I installed 6112s at the 1.9” setting and added Rebounds and 285/75/17s last summer. I’ve been meaning to cut and redrill them before reinstall but haven’t gotten around to it yet. So I can’t say whether that setup will rub the front liner. Otherwise, they fit fine with no rubbing anywhere else.
  27. Mar 6, 2019 at 4:20 PM
    #57
    ChrisTRDPro
    MT
    equin likes this.
  28. Mar 6, 2019 at 9:03 PM
    #58
    dlowry81
    dlowry81 New Member
    Doug
    Hard to argue with video evidence, but that goes against all the data from the wheels and tires setup thread. Guess I’m going to give it a try.
    *edit* after reading the YouTube video description they had a 3” icon coilover kit on it.
  29. Mar 9, 2019 at 10:33 AM
    #59
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Folks, I have done this. I have 17” Rebounds and went with 315-70-17’s. I did Bilstein 6112’s at 2.5” in front, and a 1” shackle in the rear. Yes, they do fit, HOWEVER, I still have to do the cab mount chop because at full lock they rub.
    Big J and equin like this.
  30. Mar 9, 2019 at 10:44 AM
    #60
    dlowry81
    dlowry81 New Member
    Doug
    I would think 285/75/17 at the top setting on 6112’s would be fine then because it shorter and a lot narrower.
    equin likes this.
