Gun Pics..whatcha got?
Discussion in 'Guns & Hunting' started by R0CKETMAN, May 22, 2017.
  1. Jun 30, 2018 at 2:37 PM
    #601
    LML 3500HD
    Those are TruGlo
    https://usa.palmettostatearmory.com...2jOTIzJj_NPxcWghjAVu1LCCnHXTTwokaAmN8EALw_wcB
    This is just a personal opinion, so take that for what it’s worth.....
    I like my rear sight to be squared off, or have a lip like this:
    The benefits to this design are:
    I can load the weapon with one hand in the event my other arm is out of the fight. The rear sight can be used on your pants to catch and open the slide, or drop down to your knee and use the bottom of your shoe/boot to rack a round into the chamber.
  2. Jun 30, 2018 at 2:38 PM
    #602
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  3. Jun 30, 2018 at 3:08 PM
    #603
    No my buddy is a certified coater for them and he does all my stuff!
  4. Jun 30, 2018 at 3:27 PM
    #604
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Best sights for the glock hands down. Best company to work with as well. I broke my front sight off during training once, and they replaced it free of charge even after I told them I was racking my glock using the front sight.
  5. Jun 30, 2018 at 3:48 PM
    #605
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Who did the work on the 1911? Looks good!!
    iHacker likes this.
  6. Jun 30, 2018 at 4:14 PM
    #606
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    Thank you...she's a beauty...all factory and smooth as butter!
  7. Jun 30, 2018 at 4:30 PM
    #607
    HighDesertSurfer
    New Mexico
    Leer shell
    Colt factory that is
  8. Jun 30, 2018 at 7:01 PM
    #608
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Doing a once over on my trusty 12ga in prep for our upcoming trip. Over 11,000 problem free rounds through this gun. It hasn't been cleaned in 6000 rounds. There's a story about it I can post if anyone cares.
  9. Jun 30, 2018 at 7:30 PM
    #609
    JimBeam
    JimBeam Moderator Staff Member
    2015 Limited
    I like Truglo TFOs and the basic Glock branded ones
    I’d stick to Trijicon and Truglo just based on my experience with them...I cannot say bad or good on anything else
  10. Jun 30, 2018 at 10:29 PM
    #610
    LML 3500HD
    I'm all ears....
    Prostar 190 likes this.
  11. Jul 1, 2018 at 7:09 AM
    #611
    Outbound
    Aaron
    Northern Alberta
    The Maverick 88 Story
    For a budget gun, the Maverick punches way above it's weight class in terms of reliability. I've been on a multi-year mission to push mine to it's limits and see what it can take.
    - Current round count is somewhere above 11,000. That's a mix of 2 3/4", 3" and 3" magnum shells including birdshot, buckshot and slugs.
    - I have cleaned the gun 3.5 times. The first 3 times were when I cleaned it roughly every 1000 rounds before going on my torture test mission. It has been 6000+ rounds without a cleaning. The half clean was simply a rinse and wipe down of the exterior to remove mud and grime after a swamp test.
    - I've fired it under a few feet of snow
    - I've fired it with the action and barrel jammed with mud and debris
    - I've fired it after dunking it in Alberta muskeg (hence the rinse treatment)
    - I've tossed it out of a moving truck a few times
    - I've fired it in temperatures from +40 Celsius down to -40 Celsius
    - I've fired it in freezing rain
    - I've frozen the action shut and fired it
    - I've drop kicked it down a mountainside
    - In one test I loaded, fired, loaded and repeated so quickly and with so many rounds that the barrel began to change color from the heat. I believe the count was 200 ish shells with about 10 minutes give or take (didn't have a timer running) of constant firing and reloading
    - It's been rudely exposed to dust, dirt, grime, mud, ice, snow, water (salt and fresh), swamps, you name it.
    - I've probably abused it in ways I don't even remember.
    The gun still looks very good, almost too good. I should put some more scratches in the receiver. LOL.
    The only pieces I've replaced have been the mag spring and follower, which are honestly the two weakest pieces in any firearm as far as I'm concerned. That right there is also a testament to Mossberg's customer service. When I mentioned to them the abuse I'd given the gun, they shipped me the mag spring and follower for free. I installed the spring and kept the follower in reserve after upgrading to a S&J Hardware No-Jam follower.
    The only other replacement to it has been the Magpul SGA stock. This is simply to improve the ergonomics as I have a short L.O.P.
    Plinking, camping, hunting, war or a zombie apocalypse. If I had to take one gun, my Maverick 88 would be it. This gun has reached legendary status amongst my shooting friends with 1 or 2 nicknaming it the Ak-88, a tribute to it's reliability compared to the Ak-47.
  12. Jul 4, 2018 at 1:39 PM
    #612
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    It fits m&p 40c with the universal-2 plate( smallest plate)if anyone was wondering.
  13. Jul 4, 2018 at 2:08 PM
    #613
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    I picked this up about two weeks ago..taken it out twice so far..250 plus rounds through it...fits my hand perfect, ultra smooth trigger, super fast reset, easy on the recoil it just makes my ammo therapy session oh so enjoyable...
  14. Jul 4, 2018 at 5:19 PM
    #614
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    Very nice, my buddy has one. Hope to get one down the road. I also loved the trigger and reset, not much creep to it at all.
    aperezsh[QUOTED] likes this.
  15. Jul 10, 2018 at 8:42 AM
    #615
    Okietundra
    Okietundra New Member
    OKC OK
    2015 Silver Sky CM TRD OFF ROAD
    She's missing the range as much as I am...
    GAknight, TundraLuv, aperezsh and 3 others like this.
  16. Jul 10, 2018 at 8:51 AM
    #616
  17. Jul 18, 2018 at 9:52 PM
    #617
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Got quite a few more lingering around the house, but this was close by. Bonus points if you guess the ejection port cover reference.
    Max Power, Prostar 190 and ColoradoTJ like this.
  18. Jul 18, 2018 at 10:00 PM
    #618
    LML 3500HD
    Oh that’s good @Sas
    Sas likes this.
  19. Jul 19, 2018 at 6:33 AM
    #619
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    This shotgun might be my next purchase, quite a test you've done, do u have any videos?
  20. Jul 19, 2018 at 7:08 AM
    #620
    Outbound
    Aaron
    Northern Alberta
    No, I haven't bothered really taking videos.
  21. Jul 19, 2018 at 10:28 AM
    #621
    warlord192
    warlord192 Get off my lawn !!
    New Orleans
    2014 Silver Sky metallic Tundra Double Cab
    Nice looking weapons, I keep losing mine in the bayou can't keep a leash on anything..:rolleyes:
  22. Jul 19, 2018 at 7:06 PM
    #622
    JimBeam
    2015 Limited
    I’m probably stupid but I’m basically the opposite and keep telling.gov more and more
    I got an FFL a few weeks ago to run a gun store on the side
  23. Jul 19, 2018 at 7:17 PM
    #623
    warlord192
    New Orleans
    The gooberment knows more about me than I feel they should so I will admit nothing, deny everything ,demand proof and make counter allegations.
  24. Jul 19, 2018 at 7:21 PM
    #624
    On-the-Bayou
    On-the-Bayou New Member
    James
    NW Louisiana
    2015 Silver Tundra SR5 DC
    BAMuffler, Bilstein 5100s
    Sas[QUOTED] likes this.
  25. Jul 19, 2018 at 7:48 PM
    #625
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Too bad your truck isn't Inferno.
  26. Jul 19, 2018 at 7:51 PM
    #626
    This was for someone else. But he has a orange chopper! Lol
    lionix[QUOTED] likes this.
  27. Jul 19, 2018 at 8:01 PM
    #627
    Sas
    OKC, OK
    lionix likes this.
  28. Jul 20, 2018 at 12:33 AM
    #628
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    My daily carry weapon.
  29. Jul 22, 2018 at 8:37 PM
    #629
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Winchester mod 54 30.06
    Remmington mod 700 .243
    Marlin micro groove barrel mod 336 30-30
    Colt AR-15 .223
    Ruger 10/22 carbine
    Ruger 10/22 MK II
    Browning automatic 5 12g
    Ithaca mod 37 featherlite 12g full choke
    Ithaca mod 37 featherlite 12g modified choke
    410
  30. Jul 22, 2018 at 8:48 PM
    #630
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    To many and not enough time to shoot.
