What is this plug for?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Upgrayedd, Jul 19, 2018.
  1. Jul 19, 2018 at 2:42 PM
    Upgrayedd
    Upgrayedd [OP] Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I have a 2015 SR5 4.6 and am wondering what this plug is for. I am installing a Tekonsha P3 brake controller, and I’m wondering if this plug is for a Tow/Haul button. Can anyone confirm what it’s for? Because if I can add the tow button that would be awesome as the 4.6 doesn’t come with it.
  2. Jul 19, 2018 at 5:29 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    It’s stuck in the panel that holds the traction control button, and right next to the brake controller harness.
  3. Sep 15, 2018 at 10:56 AM
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    It’s for an aftermarket brake controller.
  4. Dec 16, 2018 at 3:46 PM
    1bad10tacoma
    1bad10tacoma New Member
    Mark
    2019 Tundra
    Are you sure that's what this for? I really need to hook up my Prodigy controller and I didn't think I had the wires but this is there. Any idea where I'd get the plug that plugs into it?
  5. Dec 16, 2018 at 5:46 PM
    1bad10tacoma
    Mark
    2019 Tundra
  6. Dec 16, 2018 at 6:00 PM
    hudrock
    hudrock New Member
    So Cal
    18 Tundra before 20 Sequioa now
  7. Dec 16, 2018 at 6:10 PM
    1bad10tacoma
    Mark
    2019 Tundra
  8. Dec 16, 2018 at 6:17 PM
    Jrharvey02
    Jrharvey02 New Member
  9. Dec 16, 2018 at 6:22 PM
    1bad10tacoma
    Mark
    2019 Tundra
    Yeah I have that wire, but there is no harness to be found on the truck. I do have the wires pictured above but it's not a match.
  10. Dec 16, 2018 at 7:22 PM
    vanoss101
    vanoss101 New Member
    2015 SR5 Tundra DC
    I suspect that would be for the park assist option or auto high beam option. That is not the brake control connector.
  11. Dec 16, 2018 at 7:37 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Its Park Aassist, I just had that panel off last week while removing dash vents to paint. My Tundra has the park assist feature and I plugged that back in when I re-installed.
