What octane gas do you use for your Tundra?
Discussion in 'Performance and Tuning' started by tundrathr0w, Jun 22, 2018.
  1. Jul 13, 2018 at 12:10 PM
    #91
    zapman29
    zapman29 New Member
    Jake
    2018 Toyota Tundra SR5 Crew Max TSS Off Road 4X4
    so just found out that my Tundra can use flex fuel but on this forum there seems to be more that say dont use it so far i just use 87 but have not ever filled up completely yet and when i do that i was going to try to use flex, if the savings was good.. now i dont know if i want to try. i mean if the vehicle is designed for it i dont see how it would be not good to use.
  2. Jul 13, 2018 at 7:47 PM
    #92
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Just because we can doesn’t mean we should. It’s desigend to tolerate it. Your body could handle bacon cheese burgers every day for a while, but it doesn’t make it a good idea!
    If you do decide to use it, follow manufacture instructions: when changing octane add it to a 1/4 tank of what you’ve been using
    Jengel451 and zapman29[QUOTED] like this.
  3. Jul 13, 2018 at 7:49 PM
    #93
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Here at elevation; 85 from Costco
  4. Jul 14, 2018 at 10:36 AM
    #94
    zapman29
    zapman29 New Member
    Jake
    thanks and of course I would follow manufactures guidelines.. but where i disagree is is why not should i do it or why is it not good? if it was not meant to be used why would the company design the engine for it? i mean they know the tudras dont get the best gas mileage so they designed it to be able to take the flex fuel so that you will saving money on fillups since your burning more gas, this is just my 2 cents.
  5. Jul 14, 2018 at 8:56 PM
    #95
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    It’s basically the same engine as I understand it. I’m not a mechanic so maybe someone else will come along and give a better or more correct response, but here’s my thoughts:
    It’s not cheaper at the moment, but I think it was for a while there. Price per gallon may be cheaper but I believe it runs around 20-30% less efficiently. So unless it’s 20-30% cheaper you’ll actually end up paying more to go the same distance.... and, if I’m right, causing more harm to your engine.
    The engine has better seals, and the fuel system is stainless steal. The ethanol would eat through the components of a standard fuel system.
    It’s not as good as standard fuel because it doesn’t burn as clean. Gunks up the engine / fuel filters / etc which could cause components to fail more quickly or raise the likely hood of failure.
    But as with most things - it’s your truck, do what you want. I’d just do more research before tinkling it through MY engine.
    BTBAKER likes this.
  6. Jul 14, 2018 at 9:24 PM
    #96
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Costco or Chevron 91 whenever possible, not sure if it really makes a difference but I feel better afterwards. Until I look at the receipt...
  7. Jul 15, 2018 at 8:51 PM
    #97
    r1-superstar
    DB
    UTAH
    This is why I told myself I would fill up at half tank and not empty. LOL
  8. Jul 15, 2018 at 10:38 PM
    #98
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    87 all day everyday except on our anniversary, then she gets a bottle of the finest chevron with Techron (additive) I can find...
    P.S. I own my own gas station so the price doesn’t dictate the octane choice.
    Jrharvey02 likes this.
  9. Jul 15, 2018 at 10:56 PM
    #99
    Punisher17
    Punisher17 New Member
    87 when prices are high and 87 is a pretty low octane. 91 everytime I can afford it. There are a lot of benefits running a 91 octane. I also try only going to Chevron for gas. It has the most detergents. Benefits are going to be less engine wear and engine performance that lasts the life of the vehicle therefore it will last longer. Horsepower also naturally deteriorates from normal use of a vehicle.
  10. Jul 16, 2018 at 4:36 AM
    #100
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Sigh.......4 pages of info and people still don't get it.
    Ace402 and UNTMatt like this.
  11. Jul 16, 2018 at 7:00 AM
    #101
    MlrTyme
    MlrTyme New Member
    87 and Top Tier Gas only. Usually Exxon. Anything higher is a waste of money.
    UNTMatt and sprtbkr like this.
  12. Jul 16, 2018 at 7:15 AM
    #102
    Professional Hand Model
    Fred
    Hand Protectors
    I think I get it. Higher Octane makes for a smoother running engine (less pings/knocks) due to better explosive timing inside the combustion chamber.
    And, stay away from ethanol.
    Do I get an A+?
  13. Jul 16, 2018 at 7:18 AM
    #103
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    B+ You forgot that using higher octane than the manufacturer recommends is just wasting your money.
  14. Jul 16, 2018 at 7:22 AM
    #104
    Jengel451
    The Bitterroot, MT
    Leo's first likes this.
  15. Jul 16, 2018 at 7:25 AM
    #105
    Jengel451
    The Bitterroot, MT
    unless you have a Supercharger on top of your intake, using 91/93 is a total waste of money. But hey, at least you feel good about it, and that's what really matters here.
  16. Jul 16, 2018 at 7:26 AM
    #106
    sprtbkr
    Scott
    Denver, CO
    everybody gotta feel good. :rofl::rofl::rofl:
  17. Jul 16, 2018 at 7:27 AM
    #107
    Fred
    Hand Protectors
    I am very fluent with the sarcastic language.
    Jengel451 likes this.
  18. Jul 16, 2018 at 9:17 PM
    #108
    Punisher17
    Toyota says that it doesn't call for premium 91 octane as long as it is top teir gas you are good to go. But... in older vehicles premium 91 octane can be used to prevent knocking and pinging. At 11 years old I'd consider my Tundra an older vehicle even though it is the newest and nicest vehicle I've ever owned lol.
  19. Jul 16, 2018 at 9:35 PM
    #109
    Aron9000
    Aron9000 New Member
    Aaron
    87 octane is what I run, people using 93 are wasting $$$$ IMO. That is if you are stock, supercharged, different ECU tune, yes use the good stuff.
    Also 93 octane is stupid expensive in my neck of the woods, usually 60 to 80 cents more a gallon. My old 1992 Lexus SC300 called for premium, it was stock as a rock(2JZ-GE) and did 17-18 in town, maybe 22-23 on the highway. The 2JZ with no turbos is a great motor except it has a drinking problem worse than George Jones and only swills the best single malt. The fuel bill on my Tundra has been less than my Lexus due to the 87 vs 93 price difference.
    I usually fill up with 87 at my local shell. Its top tier gas and my Kroger fuel points are good there. Its also the same price as the Thortons across the street and I know that is kind of suspect fuel in terms of the quality/quantity of cleaners/additives they put in it.
    UNTMatt likes this.
  20. Jul 17, 2018 at 7:28 AM
    #110
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    Enthanol free at kwik fill in NW Pa 90
    Octane at selected stations
  21. Jul 17, 2018 at 10:36 PM
    #111
    tundras00
    tundras00 New Member
    I still don't get guys that complain about the 91/93 being too expensive. I fill up at Costco and the 93 I get there is around the same price that I would get 87 at regular gas stations. At times, it is actually cheaper depending on the gas station location. It is not an excuse.
    I actually feel the difference and you can't tell me any different. My butt dyno is pretty calibrated too, as I used to play the horsepower game with turbos and what not.
    Punisher17 likes this.
  22. Jul 17, 2018 at 10:48 PM
    #112
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    87, 100% gas.
  23. Jul 17, 2018 at 10:51 PM
    #113
    tundras00
    That's also another aspect, as we don't see any gas in IL that is 100% gas. If it was 87 100% gas, and not mixed with any crappy ethanol (up to 10% although supposedly they aren't supposed to put any during summer time) maybe it wouldn't be such a drastic difference, but who the hell really knows. I sure don't... And than you have DAP tuning that proves it that it 87 pulls timing hard.
  24. Jul 17, 2018 at 10:55 PM
    #114
    Sas
    OKC, OK
    That's a bummer! We're definitely lucky down here. There is 100% gas all over the place and at different octanes.
  25. Jul 18, 2018 at 3:38 AM
    #115
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, and i love the ones that thing it is better fuel
  26. Jul 18, 2018 at 4:39 AM
    #116
    Fred
    Hand Protectors
  27. Jul 18, 2018 at 5:12 AM
    #117
    tundras00
    Yeah, I dont think it's better, I know it's better on MY truck. Do whatever your butt pleases, but we have the tuner on our side so it is not just placebo.
    Btw, the manufacturer has to market this engine as an 87 or else it wouldn't sell. Same engine on Lexuses requires 91 or higher, and I doubt it has even anything on tuning as it could be just timing, but this could be a question for DAP to answer.
  28. Jul 18, 2018 at 5:29 AM
    #118
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    My employer is a member of the top tier gasoline group. We run the same additive package in the same amount on all octane levels.
  29. Jul 18, 2018 at 10:10 AM
    #119
    Jengel451
    The Bitterroot, MT
    Butt dynos are always 100% accurate at all throttle positions, rpms and loads.
  30. Jul 18, 2018 at 10:55 AM
    #120
    tundras00
    Unless your butt is off and uncalibrated that is... It also helps to be free of fecal matter like some butt dynos might be. Maintenance and a free mind is key....
