Towing Advice for a Travel Trailer
Discussion in 'Towing & Hauling' started by marcjmo79, May 30, 2018.
  1. May 30, 2018 at 7:19 AM
    marcjmo79
    marcjmo79 [OP] New Member
    2015 Tundra
    I have a 2015 Tundra Crewmax 4.6L (no tow/haul button) and have never towed anything with it. We plan on getting a TT for our family of 4 to take on trips all across the country. The TT we're looking at getting has a dry weight of 4,615#, a cargo capacity of 1,385# and a dry hitch weight of 470#.
    Along with the TT, I plan on getting a weight distribution hitch, sway control and brake controller.
    I *think* the truck should be able to pull it safely but please correct me if I'm wrong.
    From what I've read so far in this forum, payload capacity might be my bigger concern. The sticker shows a payload capacity of 1,355# with 166# to subtract for modifications. That leaves me with 1,189# for my family of 4, gear to load and the tongue weight.
    Am i pushing the limits of my truck and should just look for less trailer? Or will this setup be just fine and not be a headache to haul on vacations across the country? Thanks in advance!
  2. May 30, 2018 at 7:49 AM
    LML 3500HD
    You will be close on the capacity, and if your careful on what/where you load everything, the truck should be fine.
  3. Jun 21, 2018 at 12:19 AM
    WilliamRoberts
    WilliamRoberts New Member
    William
    Why don't you take the suggestion from any of the expert transportation service provider to decide the best travel trailer to buy. This can help you in choosing the right and necessary trailer. Either you can browse the websites of a genuine transportation service provider or you can contact companies like California Transporter, A1- Transporter and many more to save your time in buying a new trailer.
  4. Jun 21, 2018 at 2:29 AM
    Adam New Member
    About a month ago a guy came up to my mom and step dad at a campground. He had a 2010 with the 4.6, Mom has a 2010 with the 5.7. He asked how much their camper weighted and mom said it was about 9500lbs. The guy was amazed apparently. Asked how it towed, mom said a hell of a lot better than with the f150 we had. The guy then said his camper was about 5k and he was disappointed with the way it pulled. Said he is kicking himself for not getting the 5.7 in his truck.
    jewsNbrews likes this.
  5. Jun 21, 2018 at 2:52 AM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Welcome! How you load the TT will be key in your situation. Make sure to turn Overdrive off when hauling/towing. Good luck.
  6. Jun 21, 2018 at 3:12 AM
    MikeyMTBs
    MikeyMTBs New Member
    In my opinion, driving safely at the limit of the truck and driving comfortably well-within the truck’s capabilities are two entirely different things. My 6.7 CM pulls our 5000lb TT comfortably. Comparatively, my Taco pulled it safely, but at its limit, and it certainly wasn’t comfortable and something I wanted to do across the Country.
    Two pics: Taco with TT and my Tundra CM with the same camper.
  7. Jun 21, 2018 at 4:03 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I couldn't imagine pulling my TT without Tow/Haul mode. Makes a huge difference - it holds the gears longer and changes the shift points. IIRC my TT is about 6000lbs un-loaded. With two kids, fire wood, gear, etc the 5.7L CM pulls great. Fill the fresh tank with water and it's a different story - still pulls nicely but accelerates much slower.
  8. Jun 21, 2018 at 6:56 AM
    marcjmo79
    2015 Tundra
    Good news is I was able to talk the wife into upgrading to a 2018 Tundra 5.7L. We took the tt home last week and it felt like nothing was behind me. All is good! Thanks yall!
    35431409_10160910129015389_4774274908815_6da2dde16a8ac266796d040d6169251782e6b9de.jpg
  9. Jun 21, 2018 at 2:01 PM
    Adam New Member
    Looking good
  10. Jun 21, 2018 at 3:52 PM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    You’ll be fine. Shift the transmission manually but keep your rpms greater than 3000 to help keep your transmission from overheating. I’m assuming you have a tow package with an included transmission cooler??
  11. Jun 22, 2018 at 4:10 AM
    SOB
    SOB Big Member
    Ohio
    That's the thing - with no tow/haul button there is no tow package and no tranny cooler.
    Moot point I guess since he did the right thing and upgraded.
  12. Jun 22, 2018 at 4:19 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Now that is how you get things done right there!
  13. Jul 6, 2018 at 11:41 AM
    fragnightmist
    fragnightmist New Member
    Redmond, Washington
    2014 SR5 TRD 4x4
    Trd Dual exhaust, TRD Intake, ProComp 3" leveling kit, 2018 Headlight/fog light Upgrade
    Recently purchased a 29 foot TT. The truck sags a little less than 2” with the trailer hooked up. Using a WD hitch and the truck has a 3/1 leveling kit. Should I get airbags to help with the sagging, are they a necessary upgrade?
    9E585A9E-7404-460B-A713-2A1655409713.jpg ADC1B02D-4FB1-4AD0-B262-062B89E6A85F.jpg
    Chucho likes this.
  14. Jul 6, 2018 at 11:59 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Welcome from CO!
