Updated with Coach Shackles review
Discussion in 'General Tundra Discussion' started by Tracker, Mar 28, 2016.
  1. Apr 1, 2016 at 12:47 PM
    #61
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    Ok I have a project then. I will use the guide and do it the right way and report back. I think I was so excited to get it done and I should have researched the install more as it wasnt as obvious as it seemed.
  2. Apr 1, 2016 at 5:33 PM
    #62
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I installed my 1" shackles and bushings this afternoon we went a different route on the bushing removal as my Tacoma has no ball joints so I don't own a ball joint press. I pulled the leaf pack and pressed them out in the 100 ton press brake in about 3 seconds:cool: The whole job took 2 hours and that was 30min of trying to press out the bushings on the truck with a heavy duty clamp that didn't work.
    Now for the ride wile the ride is smoother it does not completely get rid of bed bounce on the really rough roads. Now it is noticeably less on the rough spots and seams to smooth out sooner not as rhythmic . I took the lane I try and avoid on my way home wile bad it's less then it was so I'm happy with that.
    If your trying to remove it completely just shackles is not going to do it and mind you I have KING 2.5's with the same valving as @jberry813 and our trucks ride pretty well as it is!
    geno0506 likes this.
  3. Apr 1, 2016 at 7:58 PM
    #63
    Aurora CO
    I will always defend my Yugo purchase. Best car ever made. (4/1/2016..hint)
  4. Apr 3, 2016 at 9:07 AM
    #64
    DBL TAP
    DBL TAP Light 'em up
    USA
    Tracker: after you get the shackles squared away, do this: disconnect the sway bar links or remove the sway bar and feel the difference. The TRD rear sway bar has stiffened the spring rate on my Pro, and now on a concrete freeway section I'm feeling some bed bounce that I didn't have before the sway bar install. I disconnected both links and back to a smooth ride. The sway bar actually does more than minimize body roll, it increases spring rate on the opposite side of the body lean, and that stiff spring rate makes for increased bed bounce. My solution: remove the sway bar.
  5. Apr 3, 2016 at 10:02 AM
    #65
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  6. Apr 3, 2016 at 1:15 PM
    #66
    DBL TAP
    USA
    Joon,
    Yeah, I guess, but after another cruise this afternoon the sway bar most definitely adds bounce that can now be felt inside. I'm going out in a few minutes to disconnect the RH link. If I get any rattle with it disconnected, it's coming off. The ride in the Pro is just too smooth to screw up with a sway bar. If I were towing a TT, then it serves a very good purpose. It may show up on Craigslist soon.
  7. Apr 5, 2016 at 10:18 AM
    #67
    Tracker
    Shane
    I have been stuck here for an hour. This thing will not budge any more. I tried numerous ways to get it out.
    Rica25 likes this.
  8. Apr 5, 2016 at 11:24 AM
    #68
    Tracker
    Shane
    Thanks for the chizzle and hammer idea Dave. The 2nd one came out in about 1 minute tops lol.
  9. Apr 5, 2016 at 12:12 PM
    #69
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    You got a press? This is what I used.
    Rica25 likes this.
  10. Apr 5, 2016 at 1:22 PM
    #70
    Tracker
    Shane
    Ya I got pretty much the same one. The metal sleeve was caught up and the press was maxed out. I got it out with a punch. I am all done now and will test drive and report back in a few hours. I am excited for this to work :)
  11. Apr 5, 2016 at 1:36 PM
    #71
    jlee
    jerry
    Bay area CA
    Oh one or two.
    I can tell you right now it's not going get rid of it completely but the bushings do help a lot. If you replace your shocks that's going to help the most.
  12. Apr 7, 2016 at 7:43 AM
    #72
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  13. Apr 7, 2016 at 10:31 AM
    #73
    Tracker
    Shane
    No, i had a surprise B-day party and had to take my G6 to work yesterday lol. I cant even find time for a test drive.
    ColoradoTJ likes this.
  14. Apr 7, 2016 at 1:54 PM
    #74
    LML 3500HD
    Happy Belated Birthday!!!
  15. Apr 7, 2016 at 2:19 PM
    #75
    I think he took his sedan there b/c it was for a fellow co-worker and didn't want to he recognized. I may be wrong though :notsure:
  16. Apr 7, 2016 at 2:25 PM
    #76
    LML 3500HD
    Lol. Well it was his birthday sometime in the past 365 days.
    Good times!!!
    A smart person would get so very drunk right now.
    T-Rex266 likes this.
  17. Apr 11, 2016 at 6:25 PM
    #77
    Tracker
    Shane
    So I finally got a test drive in. I would say there is less bounce by the amount of 60-65%. There is still some bounce but not to the amount of the jarring I got before. The ride is still stiff of course but much better handling. I only got to go through the rough spot once and would like to try another round before my final verdict. I want to make sure the benefits have been confirmed. As of now I am happy with the performance and I think some upgraded shocks would really take care of whats left. I will post up after the confirmation ride.
    zcarpenter92 likes this.
  18. Apr 11, 2016 at 6:28 PM
    #78
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    @Tracker, Glad to hear our Products are doing there job and am looking forward to your full review. thanks for posting :)
  19. Apr 11, 2016 at 8:21 PM
    #79
    TruckyTruck
    Gary
    Y'all must have the shattiest roads out that way. I drive 8 hours a week in my truck and as of the last week have been paying attention to most of those hours driving. Still no sign of any bed bounce. There are rough roads where the whole truck moves and does jar from my stiff coilovers, but none of the rapid bounce in the rear end like i had before before.
    Shane, your bed moves up and down and sometimes jars, but are you getting that quick repeated bounce?
  20. Apr 11, 2016 at 8:49 PM
    #80
    jlee
    jerry
    Bay area CA
    Oh one or two.
    It's roads and your speed. I only get it on some really rough spots at 70+ and slower and it doesn't happen. I'm pretty sure I have a lot less then most people. The guys saying they don't have bed bounce have just never seen the right conditions for it to happen. I would bet if every Tundra on the road took the same spot I get it at the speed it happens they will experience it as well.
  21. Apr 11, 2016 at 8:58 PM
    #81
    TruckyTruck
    Gary
    You either know what bed bounce is or you don't. I am that guy saying I don't have bed bounce anymore, at least on the 480 miles of highway I drive every week. I had bed bounce on these roads before, at the same speeds I currently drive, and now I do not. I have stock rear suspension except for the shackles and bushings.
  22. Feb 6, 2018 at 11:01 AM
    #82
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    My +2 shackles are on. Tougher than I thought it would be. Can anyone else say they were able to do this:
    joonbug likes this.
  23. Feb 6, 2018 at 4:25 PM
    #83
    geno0506
    geno0506 New Member
    Michael
    David,
    I still have my +2" CB shackles I got last year stored in my garage! Just wondering if I would need to install the CB drop kit on the +2" shackles!
    I just wonder if the drop kit would be necessary on the #2
    Any input thanks
    Michael
    Sorry for the thread jack :threadjacked:
    Rica25 likes this.
