BakFlip F1 installed!
Discussion in 'Tonneau Covers, Caps and Shells' started by tyk4, Jun 22, 2018.
  1. Jun 22, 2018 at 5:46 PM
    tyk4
    tyk4 [OP] New Member
    2018 Tundra Platinum Crewmax 4x4
    I just installed my BakFlip F1. Pretty easy install. Still need to figure out a solution for the drain tubes. (They don’t fit in the holes in the bed side). All in all pretty happy with the way it looks, wondering how waterproof it will be - only time will tell.
    234C589D-A848-4049-A294-AE63D0B7BFD8.jpg CBC572C5-2A01-4B21-98A8-2205618A1F78.jpg
    jc153, equin, H-TownTundra and 3 others like this.
  2. Jun 22, 2018 at 5:48 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    looks good!:thumbsup:
  3. Dec 25, 2018 at 8:26 AM
    LI Tundra
    LI Tundra New Member
    2018 Black SR 4 dr. long bed
    Thinking of getting the Bakflip F1 for my truck. Any updates on how waterproof it is? I have a long bed so I am limited to the number of tonneaus I can get.
  4. Dec 25, 2018 at 8:03 PM
    Vwathen
    Vwathen New Member
    Kentucky
    I have owned 3 bak flip covers. I drove 14 hours in the rain and there was a little water on the bed but none of my luggage was wet. I just purchased a 19 tundra and will be installing a bak flip cover and possible pop lock which Will lock the tailgate every time I lock the doors
  5. Dec 29, 2018 at 5:30 AM
    Textoytun
    Textoytun New Member
    2019 Blacked Out GST SR5 4x4 CM
    Figure out the drain issue? I just got a 2019 and an F1 cover, installing today.
  6. Dec 29, 2018 at 12:28 PM
    gman31
    gman31 New Member
    New Orleans
    Don't get the mX4. Mine leaks horribly on the sides from a mild rain and light hose. I took it off and reinstalled it and it still leaks. I had the G2 on my Sierra and was happy with it.
  7. Dec 29, 2018 at 12:35 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    There are plastic covers on the front wall of the bed. Pop the most outer one off on each side, drill an appropriate size hole in each one, pop them back into place, route the drain tubes through them.
  8. Dec 29, 2018 at 12:36 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I have the F1. It’s a nice cover. Mine leaks a little near the front on the sides in the rain or car wash but everything stays dry inside.
    @tyk4 i used a step drill bit to make the holes in the bed a little bigger so the drain hose would fit. I sprayed some bed liner to cover up the bare metal. It’s working good for me.
  9. Dec 29, 2018 at 12:37 PM
    Fishman57
    Wayne
    Bucks County, PA
    I have the MX4. No problems with it. When it rally pours, I get just a tiny bit in the bed.
    Dr.Nut likes this.
  10. Jun 8, 2019 at 6:55 PM
    PeterB_Lost_Boy
    PeterB_Lost_Boy New Member
    2019 Black TRD Pro
    Just did the F1 on nine as well. Not bike dry, but fine for my use. Nice cover. Got the box too it works great.
  11. Jun 9, 2019 at 7:59 AM
    Dr.Nut
    Dr.Nut New Member
    2011 Tundra CrewMax 5.7L
    How's the MX4 so far? My neighbor is looking at MX4 as the lund tonneau covers he like does not have any stock last time he checked. F1 seems a great choice as well.
  12. Jun 9, 2019 at 4:27 PM
    Fishman57
    Wayne
    Bucks County, PA
    Still rally like it. I recommend it.
  13. Jun 19, 2019 at 6:49 PM
    TundraDan15
    TundraDan15 New Member
    2015 White Tundra Limited CrewMax
    Has anyone experienced the rubber weatherstripping peel off of the BakFlip tonneaus? I just bought a 2015 CrewMax Limited with a BakFlip F1 installed from CarMax on Memorial Day & noticed it peeling off. The truck is in great shape, except for the BakFlip tonneau.
