Help Please, Concrete or Mortar?
Discussion in 'Home Improvement' started by fisherman951, Jun 18, 2018.
  1. Jun 18, 2018 at 1:37 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    Well im finaly going to do this task of filling in the DIRT area in the pic but now im just curious whats the difference and what would work best. Mortar is more of a sand right? But can it be used? or should i use just the concrete mix? I plan on making it as sticky as possible as i dont plan on framin and filling. I hope to be able to leave it thick and use at sculpting or clay and fill it in. What are your guys thoughts?
  2. Jun 18, 2018 at 1:55 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Concrete without a doubt. Mortar is normally used to "glue" stone together such as bricks, blocks etc...
  3. Jun 18, 2018 at 1:56 PM
  4. Jun 18, 2018 at 2:05 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Concrete
  5. Jun 18, 2018 at 2:07 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Concrete for the win. Thanks guys
  6. Jun 18, 2018 at 2:14 PM
    blizz86
    blizz86 New Member
    Are you doing this yourself? How thick is your wall and are you pouring the concrete in to match the wall thickness? Using pavers stacked up may look better along the bottom of your wall.
  7. Jun 18, 2018 at 2:18 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Yes i will as im tired of the neighbors dirt that ends up in my patio. Wall is no more then 3inches thick. Its square tube frame. I did think about pavers but its only about 4inches tall at the highest peak. Hoping concrete will just retain the dirt atleast.
  8. Jun 18, 2018 at 2:20 PM
    blizz86
    blizz86 New Member
    Depending on your mix, that may crack and look not too good down the road.. Would some sort of tall grass plants between work for your scenario? It would probably look better too. I noticed you're in riverside, maybe a blue fescue?
  9. Jun 18, 2018 at 2:27 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    No room for plants. Their house sits a bit higher the ours. My patio is all concrete. Just inbetween(under) the fence and their property is all dirt. Concrete is like 5 bucks i guess ill take the chance and hopefully it wont crak
