My 2005 Tundra Build
Discussion in '1st Gen Builds (2000-2006)' started by Matty4wd, Mar 20, 2018.
  1. Mar 20, 2018 at 8:35 AM
    Matty4wd
    Matty4wd [OP] Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    I have a 2005 Toyota Tundra limited, that i got with only a 2” leveling kit. Here it is before i put my own touch, and i am absolutely no where near done.
    Mods so far(update as i go):
    Lighting:
    Auxbeam/Beamtech Led bulbs for fogs and headlights.
    Led RGB in cab lights, and ran some to the outside of truck too. Vid:
    https://youtu.be/HhkZ6OCdHng
    LED Under Tailgate light strip:
    https://youtu.be/bbjqpzpfbEU
    https://youtu.be/MiLKJUNBJDw
    Exterior:
    Blacked out Badges, roof and grille (pic used for this was when i was in process of getting bumper built and test fitting it)
    Also rear bumper, and bed trim
    Removed fender flares and mud flaps (plan on filling those holes)
    And finally, my favorite part of the exterior- my front bumper. 100% custom , was going for that prerunner look with durability.
    Tire Specs:
    285/70r17
    Mayhem 8015 Warrior Wheels +18 offset wrapped around a basically 33” Lion Sport M/T
    Performance:
    Flowmaster Super 10 Muffler, Single in single out. Basically a straight pipe right after two cats meet, muffler, then straight pipe out the side.
    First cold start:
    https://youtu.be/P5W-wJedbuE
    Update after approx 500 miles:
    https://youtu.be/qF-RweRZr6s
    And now i have put at least 5k miles since super 10 was installed, here is the cold start now:
    https://youtu.be/BQuys2OTimI
    Spectre Cold Air intake:
    Please excuse my dirty engine bay...
    Future Plans:
    I really want to go long travel, with King shocks, camburg UCA’s, and BTFFabrication Lowers. Also would like to upgrade the sound system with possibly two 10’s. Also want to do more performance wise, and upgraded engine components. Cams?? Want a straight lightbar on the roof, a small one on the bumper, and (4) led pods total, (2) as ditch lights mounted near a-pillars, and (2) on the sides of the lightbar going on bumper. Custom bed rack also a possibility.
    Picture Dump :
    Sunnier, Y0TA PR0, Brown Bear and 2 others like this.
  2. Mar 20, 2018 at 9:11 AM
    MookTastic
    MookTastic Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    That's pretty sick looking truck!
    Matty4wd[OP] likes this.
  3. Mar 20, 2018 at 9:13 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Are ya planning on keeping the spacers in the front? Also, as one our resident suspension experts says, Tundras don’t have struts. And those tires look taller than 30”.
    Sunnier likes this.
  4. Mar 20, 2018 at 9:32 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    I may have mispoke but i know there is a slightly larger, well looks larger, “thing” in there that lifts the truck a tiny bit. The tires are 30”, they look small because of the fender flares i think, and because they arent as meaty as other 30” tires
  5. Mar 20, 2018 at 9:34 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    I read that post wrong, and i gave false information again, i actually have 32” tires.
    zcarpenter92 likes this.
  6. Mar 20, 2018 at 9:37 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Here is a photo of it as it sits, i painted the frame work behind the bumper so that it looks better, i think.
  7. Mar 20, 2018 at 9:23 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    E5E9BF79-4D3E-4386-BE1B-702DD5CF1EA0.jpg My friend got this picture and from this angle it looks like i have baja rims? The ones with the little chrome trims on the edge. Debating if i should peel the plasti dip off those edges that have the little holes in the following pic to give it that look, any opinions? 0F197A90-B5AE-4651-A749-5E3D1C40FC13.jpg
  8. Mar 21, 2018 at 7:30 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    @zcarpenter92 upon further review, it is an above the coil spacer lift that is installed. Might get some bigger ones :curls:
  9. Mar 21, 2018 at 7:46 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    If it were me, I’d save up for replacement coilovers instead. Will have a better ride, and eliminates any of the potential issues that come with spacers.
    Sunnier likes this.
  10. Mar 21, 2018 at 8:10 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    I was thinking of doing that too, but i dont really know of some good brands that arent on the expensive side. Of course i can save up but i dont want to spend over 900-1k. Know any good coilovers that fit below that range?
  11. Mar 21, 2018 at 8:53 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Well on the lower end of prices you’ve got Bilstein 5100’s, those are probably in the $500-600 range. You’ve also got the @ToyTec Lifts Boss kit in the $900 range for front coilovers, believe you’d be sitting around $1200 if you got their rear shocks as well. But you could always just add the coilovers and wait on the rears. I’ve got their 2.5 Radflo coilovers and 2.0 Boss rear shocks on my second gen, and don’t have anything bad to say about them.
    Matty4wd[QUOTED][OP] likes this.
  12. Apr 9, 2018 at 6:28 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Got the skid plates installed finally :bananadance:
  13. Apr 9, 2018 at 2:53 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Here are some pictures of it on the truck :yay:
    Sunnier and 18robinson.jacob like this.
  14. Apr 15, 2018 at 1:50 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Did some offroading Saturday evening :headbang:
  15. Apr 15, 2018 at 1:57 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
  16. Apr 15, 2018 at 2:05 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
  17. May 3, 2018 at 8:21 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Havent had money to do anymore than clean her :confused: and put the tundras.com sticker on
    Bob likes this.
  18. May 5, 2018 at 4:47 PM
    Catman
    Catman New Member
    Angel
    2004 tundra
    looks like a nice build
  19. May 18, 2018 at 2:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah buddy. Looking good.
    I’m in this same boat. I can do the Monroe Premium Coil Overs (gasps from the peanut gallery!). Rancho has some coilover leveling shocks that fit. Another option is buy new springs and new shocks and let the shop do it. I just want that cushy ride these 1st Gens are know for. Need new front coils for sure.
  20. Jun 10, 2018 at 3:30 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Today i took the fog light canisters off my stock bumper and zip tied them to my current bumper, and it came out way better than expected. I blacked them out so it doesnt look as noticeable :)
    Sunnier, Brown Bear and Outbound like this.
  21. Jun 10, 2018 at 3:36 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Looks good. LED headlights? Which ones did you get and how do you like them?
  22. Jun 10, 2018 at 3:40 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Yes sir, led headlights and fogs, both are AUXBEAM and they are amazing. Got them on Amazon for like $20-$30. They are still very very bright even though i need to restore my headlights. Cant even imagine how bright they would be if i had clear headlights.
    Outbound[QUOTED] likes this.
  23. Jun 10, 2018 at 3:58 PM
    Outbound
    Aaron
    Northern Alberta
    Any idea which model you got? Their website doesn't seem to let me search by vehicle.
  24. Jun 10, 2018 at 4:06 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    For headlights it is H11 and for foglights it is 9006 i believe. :thumbsup:
  25. Jun 10, 2018 at 4:07 PM
    Outbound
    Aaron
    Northern Alberta
    Sweet, thanks!
  26. Jun 10, 2018 at 5:28 PM
    Nice build!
  27. Jun 12, 2018 at 10:13 PM
    18robinson.jacob
    18robinson.jacob New Member
    Jake
    Phoenix, Arizona
    2000 Toyota Tundra Access Cab 4x4
    Very nice start to the build man! Keep it going! I am thinking of building some rock sliders for mine!
  28. Jun 12, 2018 at 10:41 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Damn nice truck! :muscleflexing::muscleflexing:
  29. Jun 13, 2018 at 8:18 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    I want some new ones, lmk what you come up with man!
  30. Jun 15, 2018 at 8:15 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Here’s a pic of the range, my lenses are pretty fogged up so its not as good as it should be
    18robinson.jacob likes this.
