Towing a 7000 lb RV
Discussion in 'Towing & Hauling' started by BassMan, Jun 11, 2018.
  1. Jun 11, 2018 at 10:55 AM
    BassMan
    BassMan [OP] New Member
    2016 White 1794 Crew Cab Tundra
    I just recently bought a 2016 Tundra crew cab 1794 series after owning a 2004 Limited crew cab sense 2007. Excellent truck, hated to get rid of it but it was not set up for towing. I own a 7000 lb. 30 ft. travel trailer that the new Tundra handles quite well but the rear of the truck drops several inches when the trailer is attached. Is this ok and normal or should I beef up the rear suspension. If so how? Thanks.
  2. Jun 11, 2018 at 10:56 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If you wanted to bed up your rear suspension i'd go with new leaf springs.
    Y0TA PR0 likes this.
  3. Jun 11, 2018 at 10:59 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Or airbags/sumosprings/tibrens
    FlightMedicRN and Jason808 like this.
  4. Jun 11, 2018 at 1:05 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME! like @040Tundra said new leaf springs would work.
    4x4_Angel likes this.
  5. Jun 11, 2018 at 1:15 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    Are you using a properly set up weight distribution hitch. If so then I would look into air bags or timbrens.
    If your using the same wd hitch from your old truck then you should double check everything and readjust as needed.
    Nice truck and welcome
  6. Jun 11, 2018 at 1:19 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Properly used WD hitch will solve the problem. I got a good WD hitch and did air bags also, just in case. I’m towing a similar trailer and the hitch solved my sag problem.
  7. Jun 11, 2018 at 1:22 PM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    Seconding this, although I'm also going to install an add-a-leaf to stiffen up the rear.
    Bappa[QUOTED] likes this.
  8. Jun 11, 2018 at 2:38 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    What is your tongue wt? How often do you tow? Is the back raised in any way?
  9. Jun 11, 2018 at 2:45 PM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Weight Distribution Hitch, Anti-Sway, SumoSprings or Firestone Airbags and Add-a-Leaf springs.. I have towed for the last 7 years and ALL these combos make it easy, and provide less sag and a safer/better ride!
