Best place to buy Camping Trailer ?
Discussion in 'General Tundra Discussion' started by SuperSilverTundra, May 29, 2018.
  1. May 30, 2018 at 10:45 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    It’s all DIY, although a breaker bar, cordless impact drill and torque wrench makes things easier. If installing Timbrens like me, a jack and stands help to separate the leaf from the frame.
    There’s already a harness in the Tundra tow package under the steering wheel, you just need the P3 adapter, and P3 controller itself of course. I only put the P3 sitting on the center console, no permanent install.
    You could probably buy everything from etrailer.
    The key is to have both TV and TT level. Prevent sag/sway/bobbing in the TV and the towing experience is much better. You don’t want a fish tailing trailer.
  2. May 30, 2018 at 11:49 AM
    SuperSilverTundra
    SuperSilverTundra [OP] i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    good to hear thanks for the good advice I will look into the timbrens
  3. May 30, 2018 at 12:52 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    This is the way to go if you want a new camper. We bought our last two this way. The 2019 models came out in ~April 2018 so dealers should be looking to offload their new 2018s now. We bought a 2014 Jayco Jayflight Swift 184bh in April of 2014 and got $4,800 off MSRP since they wanted to make room for their 2015s. It's been four years since we bought ours but I assume the same logic still applies. As many others have said, CL is another good way to go.
  4. May 30, 2018 at 1:16 PM
    417Tundra
    417Tundra New Member
    Levi
    2013 platinum
    I have to ok agree with you. I'm glad we did the brand new with a warranty. Just got ours back last Saturday for warranty work. They replaced the awning, 4 stabilizer Jack's and all the counter tops for free. I've got 1 month of warranty left. I searched C.L. for 6 months looking for a fiberglass hybrid. And I gave a couple thousand more than a 5-10 year old used one.
    757TUNDRA[QUOTED] likes this.
  5. May 30, 2018 at 3:33 PM
    TheBeast
    TheBeast The Beach
    those Baja trailers are nice :)
    For you Socal guys, there are few RV dealers along the 405 in OC. Costa Mesa/ Fountain Valley area.
    They also have those RV shows all over L.A. couple times a year. They give great discounts at those shows. My buddy bought his toy haulers there
  6. May 30, 2018 at 4:57 PM
    SuperSilverTundra
    that's a good idea I need to see if there are any RV shows coming up @TheBeast
  7. May 30, 2018 at 5:05 PM
    TheBeast
    TheBeast The Beach
  8. May 30, 2018 at 5:25 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    There are several options to help with rear sag. For trucks with permanent loads, those people usually get extra leafs or helper leafs.
    For those that occasionally tow, there are Sumo's vs Timbrens vs Airbags.
    9537ba563c3d0eeca557091e4cacddfc.jpg image.jpg firestone-ride-rite-air-helper-spring-installation-2009-toyota-of-toyota-tundra-air-bags.jpg
    The first 2 are install and forget about it, they are supposed to have 1 to 1.5" of free space. In theory when not towing, they ride like stock IF roads were perfectly flat without speed bumps and potholes. We know roads aren't and you'll smack them once in a while (it's like having giant tall bumpstops). Blue Sumo's are more forgiving, Timbrens have a harsh rebound. I went with Tims because I have 1.5" lift in the back, and 3" of free space because I remove the spacers when not towing, ie; they never hit (when towing, you ride ON them).
    Then there's AirBags, they are inflated per load weight, therefore most comfortable on long trips BUT there is no free space, they connect leaf to frame and should have 5 psi when not towing, you'll feel them day-to-day driving. They have air lines and require maintenance, could possible leak.
    I also went with Timbrens because their spacers are stock order, Sumo spacers are special order. And I have more tongue wt than what you're looking at so I wanted something stiffer back there when I'm ON them to prevent nose bobbing. Buy what's right for you :)
  9. May 31, 2018 at 10:35 AM
    SuperSilverTundra
    im going down to the RVspa this weekend maybe they will have some good deals on the lot :spending:
    TheBeast and Y0TA PR0 like this.
  10. May 31, 2018 at 10:44 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Lots of options in So Cal. Google it and you will have many choices. I would stay focused on a double axel
  11. Jun 1, 2018 at 11:30 AM
    SuperSilverTundra
    why double axel? @Tony v
    jeremyd and TheBeast like this.
  12. Jun 1, 2018 at 12:29 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    Crankyape.com or Craigslist. eBay maybe too. Good luck. D
  13. Jun 2, 2018 at 3:47 PM
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    Much more stability and better handling.
    Also give you the ability to buy something a little longer and better equipped.
  14. Jun 2, 2018 at 7:50 PM
    SuperSilverTundra
    Look what i found today its pretty much exactly what i had in mind and the color is silver so it will match the Tundra perfect :woot:
    blue16, JoshuaA, Casper3 and 6 others like this.
  15. Jun 2, 2018 at 8:22 PM
    SuperSilverTundra
    Did you need to do anything to your truck as far as a duel sway or suspension support?
  16. Jun 3, 2018 at 6:35 AM
    417Tundra
    Levi
    2013 platinum
    I did not. It only weighs 2700lbs empty. I figure I'm still under 3500lbs with all of our stuff inside. I had a 4 door Tacoma that I pulled it with before I got the Tundra and the Taco pulled it fine. I do utilize the electric breaks though.
    Watt maker and jeremyd like this.
  17. Jun 3, 2018 at 12:06 PM
    SuperSilverTundra
    This one weighs in at 3,750 pounds so im going to try and tow it around and see if i need any extra support i think it will be fine
    417Tundra likes this.
  18. Jun 4, 2018 at 12:28 PM
    SuperSilverTundra
    anybody have any experience with Coachmen Viking Trailers they are under the same umbrella as Forest River
  19. Jun 4, 2018 at 12:41 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    As others have said, get a few makes / models that you are looking for, then look on craigslist. You can almost always find trailers that are 2-3 years old and only used a few times. Most people don't camp as much as they think they will when they buy one. Save yourself the depreciation on buying a new one, trailers are not like our Tundras and retain value lol.
  20. Jun 6, 2018 at 11:44 AM
    #50
    SuperSilverTundra
    I decided on a trailer I went with the 2018 Viking its about 22 feet its being prepped at the dealer so I pick it up Friday :burnrubber:
    757TUNDRA, 417Tundra and Watt maker like this.
  21. Jun 6, 2018 at 12:18 PM
    #51
    417Tundra
    Levi
    2013 platinum
    Congratulations. Nice to have that warranty, just in case.
  22. Jun 6, 2018 at 12:22 PM
    #52
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    What’s the weight of the trailer?
  23. Jun 6, 2018 at 12:31 PM
    #53
    SuperSilverTundra
    the weight is 3756 lbs
  24. Jun 6, 2018 at 12:31 PM
    #54
    pschiller86
    Paul
    Temecula, CA
    That should tow easily
  25. Jun 6, 2018 at 12:32 PM
    #55
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I have camped for about 9 years..went from a 1994 fr rockwood to a 2011 rpod 176t and last year a 2016 shasta flight 30 footer.. had to install air bags..love my wd and and anti sway bar in 1. I have a slide out, can sleep 8 to 10..full bath with tub.
    Watt maker likes this.
  26. Jun 6, 2018 at 12:33 PM
    #56
    SuperSilverTundra
    Thanks yea glad I went with a new one instead of used
  27. Jun 6, 2018 at 12:35 PM
    #57
    SuperSilverTundra
    yea should be a piece of cake
  28. Jun 6, 2018 at 6:10 PM
    #58
    SuperSilverTundra
    Do you think i need a anti sway ?
  29. Jun 6, 2018 at 6:31 PM
    #59
    417Tundra
    Levi
    2013 platinum
  30. Jun 6, 2018 at 6:33 PM
    #60
    417Tundra
    Levi
    2013 platinum
    I'd pull it some first and see what you think. The anti Sawyer bar helps if your getting a lot of cross wind.
    SuperSilverTundra[OP] likes this.
