Quick stock shock question
Discussion in 'Suspension' started by Tracker, Jun 4, 2018.
  1. Jun 4, 2018 at 1:08 AM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    I just got a stock suspension kit from a 2017 Limited. It has the Blue/yellow shocks. Are these better than my 2016 SR5 shocks? Worth a swap?
  2. Jun 4, 2018 at 5:24 AM
    Slightly better yes, but probably not by much.
    Tracker[OP] and 15whtrd like this.
  3. Jun 4, 2018 at 5:40 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Blue/yellow shocks are, as far as I know, TRD Off-road package shocks.
    They ride firmer than regular SR5 shocks and perform better off road. Obviously not as good as expensive kits, but they are definitely better than the SR5 shocks off road. If you want smooth ride on road, stay with the ones you have now.
    Tracker[OP] likes this.
  4. Jun 4, 2018 at 5:48 AM
    Aurora CO
    I swapped those same shocks/coilovers in for awhile until I had the extra money for my OME setup. They were OK off road. Basically good enough to get by with for a while.
    Tracker[QUOTED][OP] likes this.
  5. Jun 4, 2018 at 7:38 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I don't know if I would worry about swapping those out for the difference you will see. If you are handy and doing it yourself, possibly, but I definitely wouldn't pay someone to swap the stock sr5 shocks for the stock trd's.
  6. Jun 5, 2018 at 2:21 PM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    They will fit and would be a great option if you are looking for replacements or to freshen up/for some high mileage units. Not much as far as an improvement over the stock units you have if you are comparing side by side to one another.
  7. Jun 24, 2018 at 8:53 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Not worth labor cost if not replacing worn components, but they are a little better than the black shocks
