  1. May 18, 2018 at 12:12 PM
    #1951
    Punisher17
    Punisher17 New Member
    What kind of rotors and brake pads are you using?
  2. May 18, 2018 at 12:43 PM
    #1952
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    So its been a while but I am fairly certain we used Powerstop rotors, and 100% we used Akebono Pads.
    Punisher17[QUOTED] likes this.
  3. May 18, 2018 at 7:14 PM
    #1953
    Punisher17
    Debadged.. and black rims in near future. On the fence about getting grill and bumpers wrapped white20180512_165456.jpg
    obgod3 likes this.
  4. May 18, 2018 at 10:51 PM
    #1954
    Troynjade
    Troynjade Beast mode 5.7
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 5.29 Nitro Gears. Auburn Posi Rear End. Dirty Deeds Budget Dump.
    Installed 4.88 revolution gears, not what I was hoping for. 4.30 stock. A little faster shifting but, the power is almost the same. Running 38's probably why, I need 5.29..someday
  5. May 19, 2018 at 6:15 AM
    #1955
    Ericsopa
    Ericsopa Old man and the sea
    Nuttin' fancy.....flushed the tranny @ 83.5K miles w/14-15 qts of fresh. Made a minor mess.
    Prostar 190 likes this.
  6. May 19, 2018 at 8:10 AM
    #1956
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    DIY? Go synthetic or back to WS?
  7. May 19, 2018 at 10:04 AM
    #1957
    Ericsopa
    GI Joe likes this.
  8. May 19, 2018 at 10:28 AM
    #1958
    Trooper2
    JR
    Sweet. Considering a drain and refill at this time, 130k miles, not sure if tranny has been serviced. Thinking of refilling with Amzoil. Would you think ok to mix? Most likely WS in service.
    Thoughts?
  9. May 19, 2018 at 10:50 AM
    #1959
    Ericsopa
    Amsoil is supposed to be compatible for just a partial fill. They say that all their products are compatible with conventional and most other synthetics. And it meets the Toyota WS specs.
  10. May 19, 2018 at 1:10 PM
    #1960
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I planned on installing my TRD CAI today but the one I got wasn't in the condition I expected, so it's being replaced.
  11. May 20, 2018 at 11:45 PM
    #1961
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I started wrapping the interior trim with carbon fibre. It’s fair from perfect being my first vinyl wrap attempt. I bought lots so I will rewrap after more practice of easier prices in the truck. Also added some red accents.
  12. May 21, 2018 at 3:35 PM
    #1962
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Not that anyone can tell under all this dirt and pollen- but I blacked out the door handles and mirrors. Also paints the hooks red.
    Gotta get the skid plate back on soon!
    rons23 likes this.
  13. May 21, 2018 at 3:51 PM
    #1963
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Looks good Dan :thumbsup:
    Mountun Goat[QUOTED] likes this.
  14. May 21, 2018 at 3:53 PM
    #1964
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks
  15. May 21, 2018 at 4:07 PM
    #1965
    Ericsopa
    To revisit my earlier post re: tranny flush and new fluid .... It sure does shift smooth now. It was just fine before, but there is a noticeable difference. It might be 75% subjective, but feels like there's less slippage in the torque converter, feels like it pulls stronger, shifts are more positive under moderately hard acceleration, can't even feel it shift when easy on the pedal (only way I can perceive the shift under easy acceleration is the sound of the engine RPMs dropping and the tach drop). I don't know whether it's the Amsoil I filled with or just the fact that it has all new fluid. But it is definitely nice!
    kparrow and Mountun Goat like this.
  16. May 23, 2018 at 9:26 PM
    #1966
    Aron9000
    Aron9000 New Member
    Aaron
    Tried doing a burnout today(just bought the truck about a week ago). It was not having it, as I don't think there is any way to fully shut off all the electronic nannies. I held down the traction control(button on the right) and stability control(button on the left) for a few seconds each until the lights in the dash came on. Floored it from a stop, just a couple feet of spin, saw the yellow "Oh my god the wheels are spinning and the computer is losing it shit" light flash for a bit, not sure if it cut power, applied rear brakes or what. Maybe I should have bought the 5.7 instead of the 4.6, but whatever, if I wanted to do burnouts I would've bought a Dodge Challenger or a Corvette.
    It did let me do a brake stand though, with much more satisfying results. Only held it for like 3-4 seconds then let off the brake and floored it, spun the tires through 1st up to about 30mph. Still not sure if it was doing a 1 wheel peel or actually spinning both wheels.
    Figured that's enough abuse until I need new tires in about 30,000 or 40,000 miles. Just kind of curious as to what she'd do, as I normally don't drive that douchy/beat on my cars that hard. Also I don't think these trucks are nearly light in the ass end as my old 2wd Tacoma or a couple of the 2wd 80's/90's Toyota mini-trucks I've had before.
  17. May 23, 2018 at 9:30 PM
    #1967
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Welcome!!
  18. May 24, 2018 at 7:24 AM
    #1968
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Well got the new Spyder V2 lights in, the light bar looks great actually, I was pleasantly surprised. Now to get it wired up to a switch or the DRL’s
    Probably go LED at some point. High beams are bright for certain. Plug and play. Bought them on Amazon for $275.99 from AKKON.
    iPhone pics suck, I still have some adjusting to do - drivers up/down is a bitch to get to so I just take the light out, adjust and see where it lands.
  19. May 24, 2018 at 7:37 AM
    #1969
    Punisher17
    You can get a ratcheting wrench to adjust them I'm sure..
    obgod3[QUOTED] likes this.
  20. May 24, 2018 at 10:36 PM
    #1970
    Punisher17
    After
    First time I ever wrapped anything. Tint film was 10 bucks on Amazon. Came out pretty good. The best I'd expect from myself for never doing it before. The contour of the tail lights was hard to wrap and I used a hair dryer not a heat gun. The edges are what was the hardest and it's not perfectly smooth but the only way to tell is to actually look for it or know what your looking at lol. I love them!
    And I only wrapped the red section of the tail lights and got them off ebay.
  21. May 30, 2018 at 5:03 PM
    #1971
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    Not really "To My 2nd Gen" yet, but close... I'm also considering putting some yellow surface mount LEDs on top of the IFS skid to back light the RCI emblem
  22. May 31, 2018 at 1:10 PM
    #1972
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    Finally got some time on the ROCK warrior wheels! I cleaned the Crap out of them first....70E32259-BD32-4E53-9818-E8DD0E9AF0D8.jpg
    After....EA7C5038-2354-4756-9B3F-0F0BE4084945.jpg then did a test fit, to make sure they would clear the brakes!D7DB997E-9502-4CE1-94FF-9345D41584C3.jpg
    6C698685-669E-4836-BAA7-86B7374F19DE.jpg Then scuffed with a scotch brite pad and purple power to remove any traces of wax/grease. Then primed the spokes(inside and out).640316F1-6426-4FB1-B2A6-5A7E605E964B.jpg. I also wet sanded my headlights in order to give them fresh clear coat, when I clear the wheels! C63BCC62-1215-4EDC-8FF3-07064C6398A6.jpg. that’s all I have for pics right now.. another update to follow!
  23. May 31, 2018 at 5:10 PM
    #1973
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Tease.
    Mountun Goat likes this.
  24. May 31, 2018 at 11:30 PM
    #1974
    Aron9000
    Aron9000 New Member
    Aaron
    ^ Serious wheel envy here, I want a 17" set of those rock warrior wheels with the white letter BF Goodrich tires on my truck. Those wheels/tires simply look the business on our trucks but still ride nice and are quiet cruising down the interstate.
  25. Jun 1, 2018 at 6:56 AM
    #1975
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
  26. Jun 1, 2018 at 10:34 PM
    #1976
    VegasTundra
    VegasTundra New Member
    Henderson, NV
    After a few dances...
    New Shoes and Socks for the OLD girl.
    After ALL we have been through...
    She looks like... well, a little better. Unlike ME !!!
    Think I'll stay married a little longer to her.
    SO Glad I didn't marry one of those Flex-fuel bitches.
    Not, that there is ANYTHING Wrong with Flexible Bitches...
    As Newly weds:
    After a Little work to smooth out our wrinkles:
    parker44, JTP, obgod3 and 4 others like this.
  27. Jun 2, 2018 at 9:54 PM
    #1977
    TheBeast
    TheBeast The Beach
  28. Jun 3, 2018 at 10:48 AM
    #1978
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Ok well finally got the grille in, grille lights not hooked up yet but maybe tomorrow. Did all the prep and paint myself.
    Thanks to @JerseyTundra1260 for some advice and help, made a small change to stay slightly different lol....had to see but ....
  29. Jun 3, 2018 at 10:51 AM
    #1979
    Rica25
    Ricardo
    Tulare
    20180603_093721.jpgnew ijdm Fog lights
    Bassmonkey67 and obgod3 like this.
  30. Jun 3, 2018 at 5:23 PM
    #1980
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    Last week got all twisted, and I wasn’t able to get things done in time to get my tires on the Warrior wheels... SO... I decided to do some more LED swaps. I’ve got Low beam, High beam, and Fogs, as well as Tail/brake and rear indicators. I also Finally got my OPT7 three row tailgate bar(with sequential indicators) installed! (Still need to do front indicators and reverse lights).
    Please do yourself and Anyone that rides in your truck a solid and pay the higher cost for Legit LED bulbs. I first went cheap, and bought the $5/pr set off eBay... they aren’t very Bright at all, and cause hyper flash(left one in pic below). The other one is the Zevo, and they are Bright!! *****Edit for correction**** “And No hyper flash!” Should read, “still hyper flash..‍♂️..”. Guess I’ll just get an LED flasher module!!(pic above has Zevo on DS and cheapo on PS)...
    Lastly, I installed this shiny little bit, pictured on top of the strut! 1” level kit! I’m certain this will get the appearance I want once the tires and Warriors are on!(hopefully tomorrow!)E2117749-508C-4746-9577-37794208C146.jpg
    Prostar 190 and myt1 like this.
