4X4, 4Hi 4Lo ?
Discussion in 'General Tundra Discussion' started by geno0506, May 23, 2018.
  1. May 23, 2018 at 9:45 PM
    geno0506
    geno0506 [OP] New Member
    Michael
    Ok,
    Heres a 4x4 newbe question, I'm to lazy to search for it or read the manual!
    I have not yet been true 4 wheelin yet, I know your supposed to at least run it on 4x4 straight aways once in a while!
    1st I do in 4Hi, and I usually stop and while in drive switch knob to 4Hi, is this correct and do I need to stop or can I do it while driving like 20mph or slower!
    2nd I stop and while not moving I try to engage the 4Lo but all I hear is beeping sound so i just switch back to 2wd. Is there a certain method for 2Lo!
    Any advice on the best methods for Lo and Hi switching!
    Sorry for being lazy and not researching, ok no I'm not sorry just lazy! :bored:
    Thanks for any input!
    Y0TA PR0 likes this.
  2. May 23, 2018 at 9:57 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
  3. May 23, 2018 at 10:04 PM
    geno0506
    Michael
    Y0TA PR0[QUOTED] likes this.
  4. May 23, 2018 at 10:07 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    :thumbsup: No problem bud:cheers:
  5. May 24, 2018 at 4:26 AM
    FSUTundra
    FSUTundra Misplaced Texan
    Cody
    2018 MGM 4x4 CM TRD
    There should also be a card on the driver side windshield visor that has all the instructions on how to use as well.
  6. May 24, 2018 at 5:12 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Based on the package the truck in the video us a 2017 or earlier. What model has that external temp display? Am I missing something in my settings?
    geno0506[OP] likes this.
  7. May 24, 2018 at 5:18 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I also have a reminder set in the Entune Maintenance screen. Once a month it will pop up and remind me to use the 4WD. Easy way to not have that " O Shit I totally forgot" moment 2 years later. I regularly use 4WD anyway on construction sites, but just in case we go through a dry spell and it is not needed for a while.
    040Tundra, geno0506[OP] and 15whtrd like this.
  8. May 24, 2018 at 5:21 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t get a chance to use it off road as often as I’d like. I also don’t run it in 4x4 10 miles a month LOL. But I do turn it on for about 2 miles on a straight stretch of road on my way to work at least once a month.
  9. May 24, 2018 at 8:00 AM
    geno0506
    Michael
    :cheers:
  10. May 24, 2018 at 8:02 AM
    geno0506
    Michael
    Thanks, I’ll do the same!
  11. May 24, 2018 at 8:08 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Gotta get out of D to switch to 4lo
  12. May 24, 2018 at 8:41 AM
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    Is that reminders ability only an Entune Premium (app suite) feature? Didn't notice when I was browsing my display system settings.
  13. May 24, 2018 at 10:49 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I couldn't tell ya I only have the premium
  14. May 25, 2018 at 11:00 PM
    geno0506
    Michael
    LMAO, I thought you were waiting for me to say whats D, so you could say, Deeze Nuts..........!
  15. May 25, 2018 at 11:27 PM
  16. May 26, 2018 at 12:00 AM
    geno0506
    Michael
    :facepalm:
  17. May 26, 2018 at 12:04 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Auto LSD works well too, press the drunken driver (trac) button once and it should come on. But yea from 4hi to 4lo you have to put it in neutral, then turn the knob to 4lo. Same thing going from 4hi to 4lo, 4hi from 2wd you can switch anytime.
  18. May 26, 2018 at 12:17 AM
    geno0506
    Michael
    :cheers:
  19. May 26, 2018 at 11:50 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I think so.
  20. May 26, 2018 at 12:11 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    As long as you’re going under 62 MPH. Don’t switch it into 4HI going faster than that....
  21. May 26, 2018 at 12:55 PM
    geno0506
    Michael
    Awesome info, on the top screen which tab did you use!
    Much thanks Brother! :cheers:
  22. May 26, 2018 at 3:05 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Select APPS , then the right arrow to go to the next screen, then MAINTENANCE. In the bottom row are 3 custom/personal buttons that can be used for anything not in the pre-set options.
    It can be programmed with reminders for either time or mileage.
  23. May 26, 2018 at 4:02 PM
    geno0506
    Michael
    Great, thanks for your time :thumbsup:
    Boerseun[QUOTED] likes this.
  24. May 26, 2018 at 4:05 PM
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    Thanks. Appears to be. I don’t have a maintenance app.
    Good idea though
