Aftermarket headlights?
Discussion in '1st Gen Tundras (2000-2006)' started by Matty4wd, May 11, 2018.
  1. May 11, 2018 at 9:58 PM
    Matty4wd
    Matty4wd [OP] Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    i have a 2005 Tundra Access Cab and i can not find any aftermarket headlights that stick out to me. Have you found any that you were looking into?
  2. May 11, 2018 at 10:02 PM
    Carid.com has some blacked out ones
    Matty4wd[QUOTED][OP] likes this.
  3. May 11, 2018 at 10:15 PM
    Just go get a 3rd gen Tundra
    mudslinger79 and Matty4wd[OP] like this.
  4. May 11, 2018 at 10:45 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What about building yourself some retrofits? I don't think the '05 headlights are as hard to pull apart as the 3rd gens.
  5. May 11, 2018 at 10:47 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  6. May 11, 2018 at 11:09 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    You’re right! Thats way cheaper :spending:
    War Machine likes this.
  7. May 11, 2018 at 11:11 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    This was what i was debating on doing, shouldnt be too hard :cool:
    831Tun[QUOTED] likes this.
  8. May 11, 2018 at 11:22 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    @MotoTundra did a nice DIY write up. I'm planning on doing mine fairly soon. D2S 4.0 projectors, probably from TRS.
  9. May 11, 2018 at 11:33 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
  10. May 11, 2018 at 11:33 PM
    Brown Bear
    Nor cal
    03 TRD offroad
  11. May 11, 2018 at 11:36 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Ok I don't know why it is not posting the whole address. The part with the *** is supposed to say **************
  12. May 11, 2018 at 11:39 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Wow it really won't let me type that. That is weird. Lets try this. ( hidretro fitkit ) take the space out.
  13. May 11, 2018 at 11:41 PM
    Brown Bear
    Nor cal
    03 TRD offroad
  14. May 11, 2018 at 11:48 PM
    Brown Bear
    Nor cal
    03 TRD offroad
  15. May 12, 2018 at 6:16 AM
    MotoTundra
    MotoTundra The Ocho
    Don
  16. Jul 23, 2018 at 10:03 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you want HID with projectors just do a retrofit yourself. You have to be patient and careful not to get that butyl everywhere that you don't want it.
    The kit itself is easy to set up, just takes some time to clock the projectors before you tighten them and seal them back up. Wiring is plug and play once you find spots to mount the boxes. Check out The Retrofit Source (TRS) for a kit.
    I did my own, I would have to go digging for build pics but could get some finished pics if you want. If possible use genuine Toyota housings. I used cheap ones and the clear coat they had has been peeling away, can't take the heat lol.
    Matty4wd[OP] likes this.
  17. Nov 9, 2020 at 3:49 AM
    SHUZAAM
    SHUZAAM www.anointed-automotive.com
    Aaron
    2005 Toyota Tundra SR5 AC 4x4
    Rex Kramer likes this.
  18. Nov 9, 2020 at 8:38 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
  19. Nov 9, 2020 at 8:52 AM
    SHUZAAM
    Aaron
    Oh, I’ve already messaged him but it he said it might be a minute before he can fulfill an order for me.
