Wiring a 1500PSW inverter from the ignition? Solved? Writeup to follow!
Discussion in 'Audio & Video' started by jeraldjunkmail, May 1, 2018.
  1. May 1, 2018 at 1:51 PM
    jeraldjunkmail
    jeraldjunkmail [OP] New Member
    Auction '08 Black Tundra TRD Offroad w. 109k km odo.
    Hi, I am looking for a wiring diagram of the ignition circuit. My goal is to make my inverter power on only when the truck has all it's power on as well (The last key stop before turning it over).
    I could do a run with a fuse in it right off the battery, but this seems more elegant and applicable if you don't want to kill your battery all the time.
    Thanks in advance!
    Jerald
  2. May 1, 2018 at 2:25 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    check any of the truck stops, many of them carry some pretty powerful inverters that just plug into cigarette lighter
  3. May 1, 2018 at 3:19 PM
    jeraldjunkmail
    Thanks for the replies. I bought a 1500w used Pure Sine Wave Inverter, looks pretty meaty. Bought it used. It tested up fine when I bought it, and now I am wiring it. It is a Go Power brand unit.
    I have 4ga. copper wire and am going to run this from past the fuse box if I recall what an old mechanic friend of mine once said was the best way to wire these.
    Just not sure about a wiring diagram, and the experience of others...
  4. May 1, 2018 at 3:20 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  5. May 1, 2018 at 3:21 PM
    jeraldjunkmail
    There are only 3 visible wire inlets. Pos, Neg, and I assume grounding.
    This is where this is headed folks if possible... switched off the start key.
    More details please... :)
    GNTundra likes this.
  6. May 1, 2018 at 3:32 PM
    jeraldjunkmail
  7. May 1, 2018 at 3:34 PM
    jeraldjunkmail
  8. May 1, 2018 at 3:38 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    It has a built in ON/OFF switch. You are correct, it is built for home use. You will need to work around it's intended use or move ON/OFF switch into the cabin and control it manually when you need it.
    If you use this setup, from battery positive through relay to inverter. Then find an ignition powered source to trigger the relay on, it will accomplish what you originally asked for.
    Disclaimer: I am not now nor have I ever been an electrician automotive or otherwise, I do however play one in bar rooms and on the internet.
  9. May 1, 2018 at 3:42 PM
    jeraldjunkmail
    OK, now we are getting somewhere. Anyone show me a picture of where to put the relay contact on the fusebox? I am similar. Not quite at the level of bar room or interwebs helping yet though. I have another 15 to 40 years to go... Someday...
  10. May 1, 2018 at 3:49 PM
    jeraldjunkmail
    the keyword search "ignition powered source" was fruitful... This will also be useful for when I run an amp for my stereo...
    Or this if you prefer... Dry but informative.
  11. May 1, 2018 at 5:56 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    A relay will not handle the 125 amp draw of your inverter. That's why you need a DC contactor. They're easy to wire, battery power to one of the big posts, power feed to inverter to the other big post, ground to one of the small posts, ignition wire to the other small post.
    Easy way is to grab an ignition source using a fuse tap like done above.
  12. May 1, 2018 at 6:59 PM
    Over the LINE
    New Orleans
    Again, not an electrician so my terminology looks to be wrong. @Festerw You made me go learn new stuff. So a contactor is a high load relay.
  13. May 1, 2018 at 7:13 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    jeraldjunkmail[OP] likes this.
  14. May 1, 2018 at 9:30 PM
    jeraldjunkmail
    Thank's Fester! Me as well. Funny, three names for similar items of different loads. I have done this before direct to battery with fuses and it was easy, but not ideal.
    Contactor requires a small power supply, under 15a. When a current runs through the relay via the small power supply, it acts as a switch and flips on the current path of the large draw item.
    So running from the ACC(esories) in the fuse box flips the Contactor on when the key is in ignition rest position and provides a circuit (power pathway) to the main load item.
    That sound about right? Not my strong suit...
  15. May 2, 2018 at 2:25 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yes sir you got it.
  16. May 14, 2018 at 10:13 PM
    jeraldjunkmail
    Well, found some time for the forum. I bought a couple 200A solenoids. Please, don't argue with me or Gregg Distributors. :cool: They are *solenoids*. . ... :canada: :rofl: They have over 200,000 products in their catalog and not one contactor. "Well, whats your biggest solenoid?" One "Hmmm, lemmecheck" later... "200A." I'll take 2... Contactor. lol... ;)
    Kinda cold out to be doing a wiring job. it is snowing right now. Will update with pics soon.
  17. May 15, 2018 at 4:27 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    As long as it works doesn't really matter what they call it. Just make sure it's rated for continuous usage or you'll be replacing them more frequently.
    Trombetta Bear series are the ones I've always used, 100% duty cycle at 225 amps and rated to 600 amp inrush.
  18. Sep 21, 2018 at 3:43 PM
    jeraldjunkmail
    Here is the install thread. Have a look:
