Truck feels like it's shaking
Discussion in '1st Gen Tundras (2000-2006)' started by Matty4wd, Apr 25, 2018.
  1. Apr 25, 2018 at 5:48 AM
    Matty4wd
    Matty4wd [OP] Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    whenver i hit the exact speeds of 45-50mph, the truck starts to almost bounce, i mainly only feel it when accelerating through those speeds, or decelerating through that speed. I wanna say has to do with an alignment? Or i need to get my tires rotated? Could that be what it is? Any help is appreciated.
  2. Apr 25, 2018 at 5:51 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Do a tire rotation and have them balanced. Speed dependent vibrations are typically a balance problem.
    ColoradoTJ, Sunnier and Matty4wd[OP] like this.
  3. Apr 25, 2018 at 6:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    truck's getting jiggy wit it!
  4. Apr 25, 2018 at 6:36 AM
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    Tire balance
    U-joint
    Worn suspension bushing
    Worn motor mount
    My list I would trace.
    Good luck
    Matty4wd[OP] likes this.
  5. Apr 26, 2018 at 4:20 PM
    05newb
    05newb New Member
    '05 SR5 Access Cab-2wd-4.0L
    K&N intake, Removed badges
    Tire balance
  6. Apr 26, 2018 at 5:21 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Sounds like....
  7. Apr 26, 2018 at 5:27 PM
    hbanthony3
    hbanthony3 New Member
    Eastern, Pennsylvania
    2016 Toyota Tundra SR5 CM
    If you haven't washed your vehicle in a long time there could be a lot of dirt on the tires/wheels that are throwing off the balance. I actually went to the shop for this same exact thing and after there inspections he laughed and took it through the car wash and said good as new lol.
    Hbanthony3
  8. Apr 26, 2018 at 5:32 PM
    l3LUEFALCON
    l3LUEFALCON RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    A clean truck is a happy truck.... not too clean though! like you need to have a little scruff on your face so people don't assume that you're a pansy. No offense to all the clean cut guys out there though. ;0)
    GODZILLA, Black Wolf and Matty4wd[OP] like this.
  9. May 25, 2018 at 1:18 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Unbalanced tires mostly make the steering wheel vibrate, don't make the truck bounce
  10. May 25, 2018 at 1:23 PM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I had similar issues with my 2010 4Runner, I had the tires given a "road force" balancing. I think that is a balancing that compensates for tires that are a little older and have worn unevenly. I think. Anyway, it did the trick.
  11. May 25, 2018 at 1:53 PM
    koditten
    koditten New Member
    Death wobble?
    TXRailRoadBandit73 likes this.
  12. May 25, 2018 at 2:11 PM
    15whtrd
    15whtrd Mr. Blonde
    Carrier bearing
  13. May 25, 2018 at 10:03 PM
    Chadwig103
    Chadwig103 New Member
    Chad
    2004 2wd
    Ball joints
  14. May 25, 2018 at 10:11 PM
    Isn't that Dodge related?
    Law323 and 15whtrd like this.
  15. May 25, 2018 at 10:12 PM
    @Matty4wd so what was it? been a while since ya posted
  16. May 25, 2018 at 11:07 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    @ARamirez73 I actually havent been able to try fixing it, its not as bad , but its still there
  17. May 25, 2018 at 11:22 PM
    You still don't know what it is?
  18. May 26, 2018 at 12:07 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sounds like you might have lost weights from a wheel?
  19. May 26, 2018 at 3:43 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Anything with a solid front axle pretty much. It's also much more severe, like rip the wheel out of your hands bad. It happened to my Jeep doing 65 on the interstate and it's terrifying.
  20. May 26, 2018 at 5:49 AM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    I believe its a tire rotation/balance that i need, i havent done it every x amount of miles
  21. May 26, 2018 at 6:11 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    YES it is!!
    Especially in a wrangler with no top or doors LOL
  22. Jun 10, 2018 at 10:48 AM
    RLHtundra06
    RLHtundra06 New Member
    I had this problem on my 06 Limited Crew Cab. It occurred as accelerating. Shook the U joints on the drive shafts and found play in the center drive shaft support bearing. Problem gone replacing U Joints and new center support bearing. Took my son and I about 5 hours on the driveway! Check the joints for play by moving with your hands!
  23. Jul 9, 2018 at 4:42 PM
    VaClutch
    VaClutch New Member
    Saul
    2006 Tundra Double Cab SR5
    Camper shell
    Does the truck sit a lot? Tires could have flat spots.
  24. Jul 23, 2018 at 8:45 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    The support bearing on the rear shaft would be where i.looked first
  25. Sep 22, 2019 at 8:54 AM
    Mr. Pink
    Mr. Pink New Member
    Ontario, CA
    06 DC 4x4
    Tint, stereo system, lift , more to come
    I'm getting a vibration and a a violent shaking randomly at freeway speeds on the right front of the vehicle. It gets worse with braking but then goes away after slowing down. thought it might have been bad rotors but just put new ones on and still having the issue. Going to try pads next.
    New wheels and tires, wheel bearings, LBJ, ubj, otr, and toytec lift have less then 10k miles.
    Could this be the CV axle starting to go out ?
    It's just so weird that shaking randomly comes and goes
  26. Oct 8, 2019 at 12:13 AM
    Jessiezam
    Jessiezam New Member
    2007 tundra limited edition 2wd
    My truck had been doing this for 4+ years and no one could seem to figure it out! I took it to an off-road shop, the dealership, my mechanic, a few other mechanics, I changed the rotors and pads, installed new tires, balanced the tires, got an alignment, had the joints inspected, I tried everything and nothing fixed it!
    FINALLY, I took it to a transmission shop and he knew right away what it was. The TORQUE CONVERTER went bad and that caused the shaking around the 45mph especially when going in a bit of an incline. I had the torque converter replaced along with a few other pieces. Since I “waited” so long to get it replaced it caused additional damaged to other components .
    I’ve been driving it and so far have put about 100 miles on it an I haven’t felt it!
    It cost about $2900.00 yikes.... but truck is now at 260k miles, I got it when it had 30k miles and (knock on wood) that the only thing I’ve ever had to fix.
    Hope this helps anyone who’s been struggling with this for years like I have.
    Sunnier likes this.
  27. Oct 8, 2019 at 1:55 AM
    Twise
    Twise More punk than you...
    Trever
    Temecula, California
    2017 Tundra Cmax TRD Off-road
    Fox 2.5 /w DSC CO’s and Rear Shocks, Total Chaos UCA’s, 17” Rock Warriors /w 35 12.5 17 BFG AT KO2’s, Powerstop Rotors and Pads Front And Rear and The stereo is really nice.
    Check your tires for signs of uneven tire wear (usually tells the story). You could have a problem with your toe adjustment and or camber. Most likely an alignment is in order.
    Rotate + Balance + Alignment, should do the trick.
  28. May 20, 2021 at 5:46 AM
    TundraNYJetFan
    TundraNYJetFan New Member
    Sully
    2010 TRD Off Road 5.7L
    Just bought my 2010 Tundra and have noticed a whirring, sounds like coming from tires and feeling a shimmy, sometimes light and other times much more aggressive. Getting tires this weekend put on along with alignment so hopefully that takes care of it. Would hate to find out it was the converter.
  29. May 20, 2021 at 9:49 AM
    bmf4069 Yup, that's car parts in a dishwasher
    Must..... resist.......ban.....
  30. May 20, 2021 at 9:49 AM
    Also,
    Darkness and GODZILLA like this.
