@Cali Raised LED Full Product Line Launch and Pre-Sale (LED's, Mounts and Grilles)
Discussion in 'Deals & Group Buys' started by Caliraisedled, Mar 26, 2018.
  1. Apr 17, 2018 at 1:31 PM
    #91
    Caliraisedled
    Caliraisedled [OP] New Member
    Jake
    Another person with our lo profile ditch brackets
    Muleycrazy13 and stolentricycle like this.
  2. Apr 19, 2018 at 2:16 PM
    #92
    Caliraisedled
    Jake
  3. Apr 23, 2018 at 7:55 PM
    #93
    Caliraisedled
    Jake
  4. Apr 24, 2018 at 1:20 PM
    #94
    Caliraisedled
    Jake
  5. Apr 25, 2018 at 6:37 PM
    #95
    PMG
    PMG New Member
    Can you describe the top mounting of the fog bracket. Does the little tongue on the bracket go into the top tab of the bumper or is it supposed to slide into that tab somehow? I tried installing it right now and I cant push the bottom of the bracket in enough to put the bolt through if i just put that little tab on the top of the bracket into the hole on the tab on the top mounting area of the bumper. I'm not sure if I'm communicating that properly.
  6. Apr 26, 2018 at 6:01 PM
    #96
    PMG
    PMG New Member
    Well, it looks like you have to hammer a few areas on the bumper opening to make it fit, but not so much as to not have friction fit.
    The powder coat is a little thin.. after install, bare metal was exposed. Also, it's difficult to tighten the pod into the bracket enough where there's no vertical movement. I used some lock washers to solve it, but it was a tight fit.
    Overall, I'm happy with the look and cost.
    EDITED TO ADD:
    CaliRaised sent new brackets after I mentioned the PC in an email. Awesome customer service. No questions asked and they dropped them in the mail the same day! Thank you.
  7. May 1, 2018 at 10:11 AM
    #97
    Caliraisedled
    Jake
    Thanks for the review if you need anything let us know.
  8. May 5, 2018 at 12:14 PM
    #98
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Any output pictures?
  9. May 5, 2018 at 1:22 PM
    #99
    PMG
    PMG New Member
    I still haven't adjusted the aim. It would also be more beneficial if I had the independent fog mod as the headlights washes it out some. The ambers are definitely not as bright as the white lights, but lumens is not really what you're after when it comes to amber fogs. I will update with some pics when I do have them aimed properly.
  10. May 7, 2018 at 2:37 PM
    #100
    Caliraisedled
    Jake
  11. May 7, 2018 at 3:06 PM
    #101
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Come out with brackets for a straight bar behind the grill as we talked via PM and consider my money gone lol
  12. May 7, 2018 at 3:15 PM
    #102
    14burrito
    2014 SR5 CM 4x4 5.7
  13. May 7, 2018 at 5:47 PM
    #103
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
  14. May 8, 2018 at 8:38 AM
    #104
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Woot Woot...
    Just pulled the trigger on a set of the grill brackets with a combo and a spot, as well as a switch panel (pre-order).
    Caliraisedled[OP] likes this.
  15. May 8, 2018 at 9:18 AM
    #105
    Caliraisedled
    Jake
    Thanks for choosing us!
  16. May 10, 2018 at 10:50 AM
    #106
    Caliraisedled
    Jake
    Here’s a customers truck showing off all of our products!
    040Tundra, stefan702 and Black Wolf like this.
  17. May 11, 2018 at 11:08 AM
    #107
    Caliraisedled
    Jake
    One of our favorite customers photos!
  18. May 15, 2018 at 1:13 PM
    #108
    Caliraisedled
    Jake
  19. May 15, 2018 at 1:36 PM
    #109
    MOQS
    MOQS New Member
    Gary
    Missouri
    2017 SR5 4WD Crew Max
    3/1 leveling kit, DV8 front bumper, Smitty Built X20 winch, Spyder head lights, Eagle Eye tail lights, American Racing ATX 18" rims, General Grabber x3 33x12.5x18 tires. TRD Pro front grille. Rigid Industries 's R2-46 Driving Pair, BAK Revolver X2 Tonneau Cover, GoRhino RB10 Running Boards, Rugged Ridge 3.5" Fog Lights, Rear painted bumper(Black), Tinted windows, Weather Tech window deflectors
    Is the hood bulge light still on the board?
  20. May 15, 2018 at 2:29 PM
    #110
    Caliraisedled
    Jake
    Slowly but surely :annoyed:
    MOQS[QUOTED] likes this.
  21. May 16, 2018 at 1:46 PM
    #111
    Caliraisedled
    Jake
    Great looking tundra!
    mjgonz1 and OceanSkyWolf like this.
  22. May 16, 2018 at 2:09 PM
    #112
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Can u post pictures of output at night?
  23. May 16, 2018 at 2:30 PM
    #113
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    People actually buy completely copied & knocked off products?
  24. May 17, 2018 at 3:22 PM
    #114
    DividedSky
    Jeff
    Copy of what, sPod?
    No need to be a hater... If you have an issue with the Cali products, bring it up with them. Or go file a patent infringement suit.
    :sadviolin:
    So I guess there is no place in this world for:
    • iPhones AND Android?
    • Coke and RC Cola?
    • X-box and Playstation?
    • Taco Bell and Del Taco?
    • Duracell and Energizer?
    Get a grip dude and stop trying to start a fight.
    Though I won't see your resp bc you are officially the first on my ignore list.
    :dancingbacon::broccoli::bananadance:
  25. May 20, 2018 at 3:44 PM
    #115
    ChrisTRDPro
    MT
    You're right, completely different products.
    [​IMG] https://i.imgur.com/EFaQZV5.jpg
  26. May 20, 2018 at 5:26 PM
    #116
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  27. May 21, 2018 at 8:50 AM
    #117
    DividedSky
    Jeff
    Did you guys hear something?
    I thought I heard some kinda whine sound. Musta been the wind I guess...
    Well I'll just go continue to go spend the money I work really hard to make in the way I see fit.
    831Tun and rustynail11 like this.
  28. May 27, 2018 at 3:03 AM
    #118
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    Happy to say I just picked up a set of the mounting brackets for LED fog replacements. Shoutout to manofsteele2003 for the recommendation. I returned the Rigid brackets since I got them on Prime. Since I didnt the Rigid fogs on Prime, I'm waiting to see if they'll accept the return. I hope they do so I can just purchase the entire setup and maybe other goodies from you guys as well. Just in case tho, what is the exact measurement/ opening of the opening for the fogs? If they dont fit the Rigids then I'll use that as more motivation for them to take them back. =)
  29. May 27, 2018 at 8:24 AM
    #119
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Keep us posted on how these fog brackets work out. Both with fitment of the rigid lights and how sturdy the lights are when mounted. Thanks
  30. May 27, 2018 at 11:52 AM
    #120
    Caliraisedled
    Jake
    Hello,
    Unfortunately the rigid pods will not with work our brackets due to the positioning of pod
