295/70 or 35/12.5??
Discussion in 'Wheels & Tires' started by Hermel, Apr 24, 2018.
  1. Apr 24, 2018 at 6:31 PM
    Hermel
    Hermel [OP] New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    Anybody get 35’s and wish they went smaller or vice versa?
    I like how 35s look and and trying to decide if I want to go through all the work of making them not rub before I pull the trigger on a set of tires. Or should I just get 295s and call it a day?
  2. Apr 24, 2018 at 6:37 PM
    TheBeast
    TheBeast The Beach
    they are very close in size. Pretty much same height but slightly wider for the 35"s. The 295/70 will fit the spare tire spot without extra work, also a bit less stress on the suspensions/steering components.
    I have 295/70.
    Hermel[OP], Black Wolf and joonbug like this.
  3. Apr 24, 2018 at 7:57 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    I didn't think it worth the hassle trying to get that 12.5 wide tire in there. The 295's look perfect but I will admit I had to do quite a bit of trimming to get them to fit, It would have been worse if I had went 12.50
    Hermel[OP] and TheBeast like this.
  4. Apr 24, 2018 at 8:04 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Part of me wishes I'd of went with 35x12.5's, but I'm pretty damn happy with 295/70/s. If the selection gets better in 285/75's I may go to those for my next set.
    Hermel[OP] likes this.
  5. Apr 24, 2018 at 10:53 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've got 295s and am going to 305 70 18. I want a little more width to protect the wheels offroad and a little more height won't hurt either. Just haven't decided between Micky Thompson MTZ of Yoko Geo G003.
  6. Apr 25, 2018 at 5:15 AM
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    I tried 35's on mine and did not fit. Went to a 295 and fit perfect, with minor trimming of course and body cab mount grind.
    This was with 295 Toyo MT's, now she has 295 Nitto Ridge Grapplers, didn't need MT's
  7. Apr 25, 2018 at 5:36 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I would run 295's and be done with it! I think the size is going to be close enough that it won't be a big difference, especially with after market wheels. 295's would be easier to fit and still look great.
    XPTUNDRA and Hermel[OP] like this.
  8. Apr 25, 2018 at 5:57 AM
    Hermel
    Mark
    Virginia Beach
    295s seem like the way to go. Guess there really isn’t much argument for the 12.5 wide tire
  9. Apr 25, 2018 at 5:58 AM
    parker44
    parker44 New Member
    Another benefit too, tires are usually cheaper in the 295's!
    XPTUNDRA likes this.
