Rear axle out of alignment?
Discussion in 'Suspension' started by MistrRoboto, Apr 17, 2018.
  1. Apr 17, 2018 at 7:20 AM
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    I'm at a shop getting the front aligned and they brought be back to show me the rear is actually slightly out of whack, likely causing some of my gripes with the front. Anyone ever seen this and can it be fixed? My guess is maybe loosening one side of the axles ubolts and and nudging the entire thing forward or backwards. 2017 Tundra, 17k miles.
    Thanks!
    jeremyd and ColoradoTJ like this.
  2. Apr 17, 2018 at 7:25 AM
    LML 3500HD
    Yes I have seen this issue. Very common.
    Thrust angle is what the shop is talking about and you’re correct on how to fix it. The tech will loosen the u-bolts from the side out and adjust accordingly.
    You have a good shop. Some don’t do anything about it.
    TheBeast, NewImprovedRon and jeremyd like this.
  3. Apr 17, 2018 at 7:30 AM
    MistrRoboto
    Virginia Beach, VA
    Well, they are good to identify it, but they said they can't change it at the moment, I'd have to leave it. They are going to compensate with the front and I suppose I'll take it up with the dealer. That a warranty elligible fix?
    Thanks!
  4. Apr 17, 2018 at 7:39 AM
    LML 3500HD
    Depends on the severity of the thrust angle. Has the truck been in an accident or curbed lately?
    On one of my Tacoma’s, I replaced the spring packs and the rear axle shifted a little. The techs just shifted the axle back and I was good to go. This was at a Toyota dealership.
    NewImprovedRon likes this.
  5. Apr 17, 2018 at 7:50 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I have this issue after replacing my leaf packs. I've corrected it only to have it move back, out of whack again. I need to adjust it one more time but I'm feel I should replace my U-bolts when I do. I don't like the way they sound when I tighten 'em. They don't feel smooth when I tighten them.
    joonbug likes this.
  6. Apr 17, 2018 at 8:06 AM
    MistrRoboto
    Virginia Beach, VA
    No accident, and I don't remember and major curb hits, but maybe something soft coming out of a parking spot at the store.
    Alignment is done but they admitted they had trouble getting it to drive completely straight while keeping front in spec. Any reason I can't just jack up the rear this weekend, loosen the 4 nuts on the axle u bolts, and give it a small whack?
    831Tun likes this.
  7. Apr 17, 2018 at 8:08 AM
    LML 3500HD
    Do you know what side is out and how many degrees it needs to go?
  8. Apr 17, 2018 at 8:09 AM
    MistrRoboto
    Virginia Beach, VA
    Are you able to view the image I posted? It appears to me that the right side would need to be pushed forward a bit.
    Both left and right rear wheels have a slight right angle, .30 and .15.
  9. Apr 17, 2018 at 8:10 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No reason why you can't do it. The alignment place quoted me $700 to adjust it. I don't my doctor charges that much?
    TheBeast and joonbug like this.
  10. Apr 17, 2018 at 8:14 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Ignore the back, it will always be out. Even if you loosen u bolts(don’t recommend, u bolts are 1 and done), adjust, it will end up right where it was in about 200 miles.
    Your rear camber is out, no way to adjust. Loosening/adjusting rear end has no effect on camber. The toe is fine.
    TheBeast, joonbug and 831Tun like this.
  11. Apr 17, 2018 at 8:17 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Dang. I was hoping I could straighten out my rear. But, I have tried and like you said, it went right back.
    TheBeast, Vizsla[QUOTED] and joonbug like this.
  12. Apr 17, 2018 at 8:21 AM
    LML 3500HD
    Like Vizsla said, u-bolts are a one time use. Once torqued, a new set is required. Kinda like cylinder head bolts.
    I would have a shop do the work. I have used a frame shop for alignments, with great results.
    831Tun likes this.
  13. Apr 17, 2018 at 8:33 AM
    MistrRoboto
    Virginia Beach, VA
    Bummer. My issue is with my front in spec, if I hold my steering wheel dead straight, I drift slightly left. Its slight, but enough to bug me.
  14. Apr 17, 2018 at 8:37 AM
    Vizsla
    Vizsla ☠️☠️☠️
    No bummer. Take it back and tell them slight left pull. They can adjust your caster split to compensate.
    TheBeast and 831Tun like this.
  15. Apr 17, 2018 at 8:43 AM
    MistrRoboto
    Virginia Beach, VA
    Here is where its at now. What would I be requesting they change? Unfortunately - it seems like they are very stuck on the "specs from the system".
    My symptom is when holding the wheel dead straight, the truck turns slightly left. I have to hold the wheel a few degrees to the right for a perfect straight line.
  16. Apr 17, 2018 at 8:55 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Caster needs split side to side, your vehicle pulls toward the side with less caster. So instead of 2.7 on both sides, 2.8 on the left, 2.6 on the right. Tech needs to adjust and drive, adjust drive again as needed. If they aren’t doing that, find a shop that does. Otherwise it is a crap shoot, every truck is different. Additionally, and this is my preference, camber should be even side to side, toe as low as possible.:thumbsup:
  17. Apr 17, 2018 at 9:04 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have never heard that u-bolts are one use only. Once tightened you cannot loosen and tighten again. Why is that?
    I had blocks. Removed the blocks, used the same u-bolts and cut the extra length out of them when i went to shackles.
    I mean asking for a friend.
    texasrho83, 831Tun, TheBeast and 2 others like this.
  18. Apr 17, 2018 at 10:34 AM
    LML 3500HD
    Brian, great question and you should always ask “why”. This is from Eaton Detroit Spring, and I quote so my thumbs don’t hurt for a week.....
    “Quality aftermarket u-bolts are made to SAE standard J429 using SAE1541 steel. 1541 provide a 150,00 PSI minimum tensile strength, and 130,000 PSI minimum yield strength and a 120,00 PSI proof load. So stretching, or exceeding the yield is not something one needs to be concerned with.
    The reason u-bolts should be replaced after they have been torque is because the threads are rolled, not cut.
    Because of this the threads are distorted when torqued. This distortion will not allow the torqued to be maintained when the nuts are loosened then retightened.
    Because loose u-bolts are the main cause of broken springs, we suggest that they be re-torqued. While the springs are new and the u-bolts are new, the rest of the suspension is aged and will have wear. It is common that the new parts receive additional stress than the older parts.
    Re-torqueing continues to move the nut up to new threads.
    Bottom line is we recommend that the u-bolts be replaced once they have been torqued to spec. Whether one does so or not is their choice.”
    Skew12, Vizsla and (deleted member) like this.
  19. Apr 17, 2018 at 10:34 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Mostly because the threads are rolled instead of cut on most u bolts. We use cut nuts on rolled u bolts so it deforms the thread when torqued by design. They are cheap, not worth it imo. I had some work done at a spring shop a few years back, they even made the u bolts in front of me. Learned a lot.
    *TJ beat me*
  20. Apr 17, 2018 at 10:37 AM
    LML 3500HD
    I learned this lesson the hard way.
  21. Apr 17, 2018 at 10:58 AM
    MistrRoboto
    Virginia Beach, VA
    Otherwise, numbers look ok? I was pretty impressed with them, just don't like the left tendency. I guess Ill just say it still pulls left with the wheel straight at highway speed - please add .1-.2 to the left caster, and remove .1-.2 from the right caster.
    Thanks,
  22. Apr 17, 2018 at 11:04 AM
    TheBeast
    TheBeast The Beach
    I thought I saw a recent Tacoma video with bad U bolts :)
    831Tun likes this.
  23. Apr 17, 2018 at 11:04 AM
    TheBeast
    TheBeast The Beach
    :spy:
    831Tun[QUOTED] likes this.
  24. Apr 17, 2018 at 11:07 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Are you suggesting that I should replace before T2S? LOL
    TheBeast[QUOTED] likes this.
  25. Apr 17, 2018 at 11:13 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Yes, I would run minimum toe personally. It is impossible to say how much of a caster split to correct. Between .1 to .5 total split, probably start at .2. Just be aware, splitting caster, camber etc. in an alignment is normal, but completely lost on most alignment techs. I run a .5 caster split with bigger tires, can let go of the wheel and it stays dead straight. Your truck can drive straight, your shop should want it too as well.
    ColoradoTJ likes this.
  26. Apr 17, 2018 at 11:16 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Great info! Searching for new bolts I found Wheelers. They're grade 5. I'm surprised they're not grade 8. Does 5 sound about right to you? And, @Vizsla . Thank you both for todays seminar.
    TheBeast likes this.
  27. Apr 17, 2018 at 11:22 AM
    Vizsla
    Vizsla ☠️☠️☠️
    Your good. U bolts need to flex without breaking. Grade 8 does not do that very well.
    ColoradoTJ and 831Tun[QUOTED] like this.
  28. Apr 17, 2018 at 11:41 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thank You.
  29. Apr 18, 2018 at 6:51 AM
    MistrRoboto
    Virginia Beach, VA
    They are going to get me back in tomorrow, but are a bit reluctant about splitting the numbers. "We will make the adjustments you request, but if it doesn't work out we can't spend hours playing with it without extra cost." I get it - a $70 alignment cant stay on the lift for 4 hours... so hopefully it works out. My left drift is pretty slight. So I am going to do as you recommended... "instead of 2.7 on both sides, 2.8 on the left, 2.6 on the right."
    Hopefully that takes me most of the way there.
    Thanks again for the advice.
    831Tun likes this.
  30. Apr 12, 2022 at 10:04 PM
    Flockem
    Flockem New Member
    Remington
    2016 Crewmax 4x4
    6112/5160 +CB shims SPC UCA and Diff Drop Toytec Shackles 35x12.50 BFG ATs on factory 20s Spidertrax 1.25s BMC Headlight Revolution SM LED Breather Mod Dents in the body due to trees...
    Bump
    trying to get some answers on my rear specs
    So I think I have an idea on the numbers I need for the front. The rear is my concern…
    Recently had icon suspension installed (front and rear) and it was driving pretty bad. Took it back to have it realigned and these are the numbers I got. At first the front numbers annoyed me but then I looked further and the rear numbers bugged me.
    I asked around and read some posts… still as confused. I’m sure I can get the front corrected but what about the rear?
    They replaced the leave packs and I’m curious how far off I am from stock, -.37 and .37 don’t seem right. Even though my toe is “0” is the -.37 and .37 something to stress over? And -.37 thrust angle?
    If the leaves need adjusting I’m assuming U bolts need to be replaced?
    35x12.5 on 17x8.5 0 offset
    Icon RXT leaves setting 2 (2”-3”)
    Icon tubular UCAs
