Thor Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Help, Apr 10, 2018.
  1. Apr 10, 2018 at 7:00 PM
    Help [OP] New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    I'm not entirely sure I have enough pics for a build thread... but eff it.
    September 2018: Just got back from Teluride CO. What a blast
    April 2018: Day Alot: Had it for just over a year now. Upgrades thus far:
    March 2017:Day 1: 2014 Double Cab w/ 34960 miles.
    Armor:
    Front Bumper: nFab M-RDS
    RCI Steel Engine Skid
    SDHQ ABS Guards
    Suspension:
    ADS 2.5 Remote Resi w/ 700lb Coils
    Camburg Tubular UCA's
    ADS 2.5 Piggybacks
    1.5" Adjustable Toytec Shackles
    (Springs are next, not sure what route yet)
    Tires:
    35x12.5R18 General Grabber X3's
    MB Wheels 352 (custom)
    Lighting:
    Rigid SR8 30" - hood bulge w/ custom mount
    Rigid Dually Pro's - x2 - Center
    Rigid SAE Fogs - Center
    Rigid Radiance (Amber) - Center
    Rigid Hi-Low - A Pillar
    Rigid E-Series 10" - Center
    Blue Sea fuse block in engine bay
    All new wiring loomed with some fancy blue/black stuff.
    Other:
    'Murica Tailgate Wrap
    Bedlined Grille/Bulge
    I'm currently designing a mount/brace to go over my transmission hump that will house a CB, bigger HAM, switch mount, and other goodies.
    monaco730, aperezsh, JC303 and 9 others like this.
  2. Apr 10, 2018 at 7:02 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Nice! Best color :muscleflexing:
    Help[OP] likes this.
  3. Apr 10, 2018 at 7:02 PM
    Tucson, AZ
    More stuffs here.. aka I need to take more pictures. @PLC721 , @TRON help!
    TRON, zcarpenter92, TheBeast and 2 others like this.
  4. Apr 10, 2018 at 7:06 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    What ball joint are you going to use? I just swapped in a set of ACDelco Pro Series on an extra set of lowers I have.
  5. Apr 10, 2018 at 7:09 PM
    thetroll262
    thetroll262 New Member
    2010 Black Tundra Limited TRD
    How do you like that wheel/tire combo?
  6. Apr 10, 2018 at 7:10 PM
    Tucson, AZ
    I hear Moog makes good stuff. How do you like the ACDelco's? Do they come with a new boot, too?
  7. Apr 10, 2018 at 7:12 PM
    BA rig!
  8. Apr 10, 2018 at 7:15 PM
    Tucson, AZ
    I have had a lot of issues with rubbing because the tread on these tires is ridiculously beefy and I'm only rockin a 3" ish lift. The tires are MT's so they're loud, but not obnoxiously so. After 10k miles I have only lost about 1-2/32nd tread. Traction is great, especially when aired down.
    thetroll262[QUOTED] likes this.
  9. Apr 10, 2018 at 8:47 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    The ACDelco Pros are good quality...made in Japan. I haven’t installed those arms on the truck yet, though. A lot of people hate on Moog these days because some of the stuff they put their name on is of a lower quality than what they used to sell back in the day. Their replacement ball joints for Tundras (K-series) are probably similar quality to the ACDelco Pros, assuming they are made in Japan. Moog also sells an entire lower control arm (r-series) with new bushings and ball joints. Those ball joints are probably lower quality. Beck/arnley is another quality ball joint that is made in Japan. Probably the same as the ACDelcos/k-series. All of them will come with a new boot, castle nut, and cotter pin.
  10. Apr 10, 2018 at 8:52 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    We’ve been looking for this one!!!
  11. Apr 13, 2018 at 7:46 PM
    Tucson, AZ
    @UTTundra thank you for the info sir! I found your write up on the differences between the manufacturers. :thumbsup::dancingbacon:
    UTTundra[QUOTED] likes this.
  12. Apr 13, 2018 at 8:00 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Looks good Ryan! I'm guessing your rubbing is in the rear of the wheel well? Camburg builds a lot of caster into their UCAs.
  13. Apr 13, 2018 at 8:04 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Where'd you find that tailgate wrap Ryan? Looks sick!
  14. Apr 13, 2018 at 8:05 PM
    Tucson, AZ
    Yeah, I need to have my CMC done by an actual shop cuz its definitely half assed. I only rub when I make a really tight left hand turn so its not too bad anymore. I'm running +5 degrees caster. I need to mess with the ride height adjustment on my shocks, too.
    So much to do. So little time.
    831Tun[QUOTED] likes this.
  15. Apr 13, 2018 at 8:05 PM
    Tucson, AZ
    Tucson company called Centerline Graphics did a custom wrap for me
    zcarpenter92[QUOTED] likes this.
  16. Apr 13, 2018 at 8:09 PM
    TheBeast
    TheBeast The Beach
    very nice.
  17. Apr 13, 2018 at 8:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    +5 caster sounds perfect IMO. But I don't know sh**.
  18. Apr 15, 2018 at 10:56 AM
    Tucson, AZ
    Its worked pretty good thus far. I went from -2 to + 5.. the drive down to get my alignment done was fun.
  19. May 1, 2018 at 7:29 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  20. May 1, 2018 at 9:13 PM
    Tucson, AZ
    @boardude thank you sir. Those pics are sweeeeeeeeeet
  21. May 1, 2018 at 9:16 PM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Ohhh HAYYYYYYY!!! :wave: didn't see your build till now
  22. May 1, 2018 at 9:23 PM
    Tucson, AZ
    That's probably cuz 70% of my build pics are on either yours or Kris' page haha
    boardude and TRON[QUOTED] like this.
  23. May 14, 2018 at 6:23 PM
    Tucson, AZ
    Tundras to Sedona Photo Dump!!!!! @TRON @PLC721 @boardude what's Christian's tag on here?
    Christian please thank your wife again. These turned out great.
    I've got a bunch to add, but as it turns out, my internet blows. took 20min for 1 pic lol I'll add more as I can
    blue16, aperezsh, Prostar 190 and 3 others like this.
  24. May 16, 2018 at 7:55 PM
    Tucson, AZ
    Finally got the last of the 3/1 leveling kit off, with help from @boardude. Holy crap, so much smoother on the rear end. Chopped the exhaust just above the axle, aaaaaand finally yanked out the stock spare/chopped off the spare mount holder chain thingy.
    Next up, re-wiring electrical to a more permanent set up and playing musical pods with my lights. Turns out the amber back light on the radiance pods sucks - could be from the rest of my lights being so bright. Or they just suck. Not really at all impressed either way.
    Current engine wiring:
    -Changing out to blue/black braided loom (cuz OCD)
    -Adding Blue Sea 12 circuit blade fuse block in place of in-line fuses.
    -150A 4 stud bus bar for grounding
    -Not really sure what to do with the relay blocks yet, but the double sided tape on top of the fuse box seems to be doing a hell of a job
    Musical lights:
    - A pillar - From Dually Floods to Hi/Low
    - Fogs #2 - From Radiance pods to 2nd set SAE pods
    - nFab bumper gap -
    2 sets of Duallys w/ amber covers, (Maybe a 3rd set of pods :bananadance:if they'll fit. Not sure yet.)
    20" rigid bar​
    I'll try my best to remember to take pictures of all this as I go. I may have to hire a photographer so I don't forget.
    If anyone has any ideas for bracing a hood bulge mount, I'd appreciate input. I built my own and bolted it straight through the bottom of the hood. It flexes A LOT when going over bumpy shit so my bar flops up and down.
    blue16, boardude, TRON and 2 others like this.
  25. May 17, 2018 at 6:59 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think the propper term is spare tire dangle dongle
    blue16 and 831Tun like this.
  26. May 17, 2018 at 7:09 AM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    what radio are you putting in? curious to see what you come up with.
  27. May 17, 2018 at 3:28 PM
    Tucson, AZ
    That project keeps getting pushed back in favor of other stuff. I'll let ya know as soon as I figure out what route I want to go
    got some suspension things to figure out first
    TRON and smslavin[QUOTED] like this.
  28. Jun 20, 2018 at 8:43 PM
    Tucson, AZ
    Been busy. Here's a few pics and a list of mods over the last 3 weeks:
    Broke my driver side shock which led to a whole slew of upgrades and fixes
    The shop that replaced my LCA ball joint for me turned it into a mini smore's roast cuz it was stuck haha. They broke one of their handheld presses trying to get it out.
    New:
    -ADS Rebuilt my driver side shock
    -Upgraded to 700lb coil springs
    -Replaced driver CV joint
    -Replaced driver LCA Ball joint
    -Front Diff flush
    -LIGHTS LIGHTS LIGHTS (Thanks a TON for all your help @eccracer104!!)
    -10" Rigid bar w/ amber cover
    -Dually floods w/ amber covers
    -Moved Hi/low dually's to A-Pillar
    -Moved SAE, Spots, and Floods w/o amber covers to center of NFAB bumper​
    -Loomed wiring in engine bay
    -Added fuse block and secured relays
    -Will be adding in-line fuse between battery and fuse block shortly​
    -Fixed Hood bulge light bar mount so it no longer shakes when on bumpy roads
    -Fixed/Replaced hood bulge + repainted (broke too many clips to reuse old one)
    -Repainting/replacing grille (broke several clips) - In progress
    -Added TRD Punisher decals to bed sides for a gain of +1776 HORSE POWWWAAHHHHH. 'Murica!
    -Fixed/Repainted NFAB's shitty aluminum skid that comes with the bumper. I bent the hell out of it on a log at T2S haha
    To do:
    - Alignment semi-corrected steering pull to the right.
    - Find what's causing vibration at high speed (probably driver tire, haven't had time to have them balanced after my mishap)
    - Detail interior/exterior
    - Build center console bracket to house lighting switches, HAM/CB, & other goodies
    - Replace/tint front windshield
    - Fix remote start (or be lazy and make one of my co-workers do it since they installed it haha)
    - Adjust angle of lights
    - Rear diff, Tranny, Transfer flush
    - Figure out what HAM and/or CB to go with and then install it. And the antenna(s).
    I swear, its never ending.
    aperezsh, Ike74 and eccracer104 like this.
  29. Jun 20, 2018 at 9:46 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Hell yeah the lights turned out great! Good call swapping out the bar :thumbsup:
    Sub’d for night output shots :popcorn:
    And how’d you break a shock?
  30. Jun 20, 2018 at 10:24 PM
    krazyTundra
    krazyTundra New Member
    Vinny
    Houston
    2021 Cement 4x4 - 5.7L CM
    TRD Front and Rear Sway Sides and back AMP steps BAM Exhaust Tailgate LED Remote Starter Cat shields (all four) Retrax MX Pro - sold TRD Pro Headlight Planned - Deck drawer system, RCI Bed Rack
    curious. what did you end up doing with the original front bumper and the black end caps (assuming those were dipped)?
