Trd swaybar install ?
Discussion in 'Performance and Tuning' started by SocaliTundra958, Dec 11, 2017.
  1. Apr 8, 2018 at 10:13 PM
    #61
    chefbutthead
    chefbutthead New Member
    Albert
    Canyon Lake, CA
    2017 TRD offroad
    I’m curious. I can use the extra handling but I do like to go Offroad. Why shouldn’t I install one of these if I go Offroad?
  2. Apr 9, 2018 at 5:48 AM
    #62
    Alptbird
    Alptbird SR5, Limited, TRD, Mutt.
    Glen
    Houston Tx
    2016 crew max SR5
    Too many to list, I actually have an excel spread sheet!
    limits wheel travel, droop to be specific. more for a crawler or trail runner. if you are just doing light off road it probably won't affect you.
    nk1794 likes this.
  3. Apr 23, 2018 at 11:51 PM
    #63
    counselor
    counselor New Member
    2017 Cement Tundra TRD Pro
    Does this affect or limit the benefits of the TRD Pro suspension? I do some off-road work hunting, also buying a RV trailer so some towing.
  4. Apr 24, 2018 at 7:18 AM
    #64
    Alptbird
    Glen
    Houston Tx
    2016 crew max SR5
    I thought it was a part of the TRD Pro kit? if not It shouldn't hurt anything other than a little bit of the travel. It may limit it. But If you are only doing minor off road and not rock crawling, you will notice the better handling on the road. Probably won't notice the limits on trail driving or minor off roading
  5. Sep 18, 2018 at 8:53 PM
    #65
    Wildtroutriver
    Wildtroutriver New Member
    Atop the Palmer Divide Colorado
    Does it interfere with the use of the air bags? I only fill them up to keep it level when I tow my toy hauler, not to lift it.
  6. Sep 19, 2018 at 3:53 AM
    #66
    Alptbird
    Glen
    Houston Tx
    2016 crew max SR5
    Not on mine. I have the same thing for the same reason.
    Wildtroutriver likes this.
  7. Sep 19, 2018 at 4:03 AM
    #67
    Tuckerman048
    Tuckerman048 New Member
    Western Pennsylvania
    2014 CM 4x4
    I installed the TRD swaybar on my 14 CM yesterday. Man what a difference in the corners! Fairly easy install on my own. Wish I would have done this earlier.
  8. Sep 19, 2018 at 5:52 AM
    #68
    Wildtroutriver
    Great, thanks so much!
    Rica25 likes this.
  9. Sep 19, 2018 at 9:12 PM
    #69
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Love mine too. Only regret was waiting so long to get one
    NewImprovedRon and Rica25 like this.
  10. Oct 6, 2018 at 2:39 PM
    #70
    Pudge
    CT
  11. Feb 22, 2021 at 1:13 PM
    #71
    Dubshack
    Dubshack New Member
    ‘19 Magnetic Gray Platinum
    For those that have installed this on their own, I have a few questions.
    - Does the truck need to be on a level surface when installing, or can this be done on a driveway with a slight slope?
    - Did you put the rear wheels on blocks, or can it be done without any lift?
    Thanks.
    Rica25 likes this.
  12. Feb 22, 2021 at 1:34 PM
    #72
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    I don't believe it would be an issue installing the rear sway bar on a slope, but it may be best to be on level ground. Also, no lift is needed for the install, you can crawl underneath and perform the install (assuming your truck is at least stock height).
  13. Feb 22, 2021 at 2:38 PM
    #73
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I loosely installed the drop links to the frame and then to the sway bar. I then used a floor jack from in front of the rear wheel to raise the sway bar into position under the axle. The install is very easy, it just takes quite a few 1/4 turns with the torque wrench before you hit 48 ft/lbs on the ubolts.
  14. Feb 22, 2021 at 3:33 PM
    #74
    Dubshack
    Dubshack New Member
    Thanks.
    2112OFFROAD and TxLock21[QUOTED] like this.
  15. Feb 22, 2021 at 4:01 PM
    #75
    chefbutthead
    Albert
    Canyon Lake, CA
    2017 TRD offroad
    I have Bilstein 5100’s on the rear. It handles really well. Will it handle any better with the anti sway bar. I’m not getting much sway even at 90 mph.
  16. Feb 22, 2021 at 4:09 PM
    #76
    2112OFFROAD
    2112OFFROAD New Member
    socal
    2020 Tundra CM 4x4 Off Road
    Even with the 5100's on the rear, if you slap one on there you'll notice a difference without any sacrifice to ride quality.
  17. Feb 28, 2021 at 11:03 AM
    #77
    Dubshack
    Dubshack New Member
    Got mine installed last night. Pretty easy, except for removing the factory bolts. Borrowed a neighbor's breaker bar and no problem.
    As everyone has said, the handling is much better.
    2112OFFROAD, Rica25 and YardBird like this.
  18. Feb 28, 2021 at 11:11 AM
    #78
    Professional Hand Model
    Fred
    Hand Protectors
    Get the beefy solid Sway Bar if you do this. I have the Hellwig 7700 and it has 3 settings which are adjustable depending on your preference. This Rear Sway Bar is a huge handling improvement at all speeds. Great on higher speed lane changes and for tow/haul.
    YardBird likes this.
  19. Apr 16, 2021 at 1:50 PM
    #79
    Dubshack
    Dubshack New Member
    Likely a dumb question, but I'm new to this.
    When retorquing after 500 miles, do you loosen up the bolts first and then retorque, or just retorque from the current position?
    Thanks.
  20. Apr 16, 2021 at 1:52 PM
    #80
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    current. You are double checking your work basically
  21. Apr 16, 2021 at 1:54 PM
    #81
    Dubshack
    Dubshack New Member
    Thanks.
  22. Apr 16, 2021 at 2:30 PM
    #82
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Next mod for sure, front and rear!
  23. Jun 5, 2021 at 7:40 PM
    #83
    bigmout
    bigmout New Member
    17 Inferno SR5 TRD-OffRoad
    I installed a friend's rear sway bar and the U-bolt nuts bent up like this but never reached 48 ft-lbs of torque.
    I quadruple checked the torque wrench and it worked fine for the frame bolts and the bolts on the hanger rods.
    I checked it against the one I just installed on my own truck and my hangers don't have any bend like this.
    I am wondering if there is a problem with the hangers. I've seen that many have noticed it takes a lot of turns to torque these, but that is a bit ridiculous.
  24. Jun 5, 2021 at 8:18 PM
    #84
    crewmaxlmt
    scott
    Did you lubricate the threads? If so, lubrication throws off the torque numbers. I ask because it looks like there is never seize around the area.
  25. Jun 5, 2021 at 8:43 PM
    #85
    bigmout
    bigmout New Member
    I put a dab of never seize between the touching metal parts and some must have gotten on the threads. I didn't think it would have that much of an effect. The right side isn't as bad and did torque out eventually.
    Now I wonder if I can get a pair of replacement brackets without buying the whole shebang again. I may have to take it off and degrease it and see if I can get it right. Maybe bend the ears back in a bit.
    So anyone else doing this, really listen when they say don't put any lube on this area.
  26. Jun 5, 2021 at 9:28 PM
    #86
    crewmaxlmt
    scott
    The mount is more than likely mild steel. I say pound it out and install some larger steel washers. Should be fine. Worst case is it squeaks and you need to replace the mount.
  27. Jun 5, 2021 at 9:33 PM
    #87
    Elduder
    Elduder New Member
    You most likely will never get it to 48lb/ft now. Once that mount bends it has give. As youre torquing down the nut the mount will just bend before you reach 48lbs, so rather than reaching the torque spec youre just applying that force to the failing mount.
    If you want you can buy new hardware, but its not cheap.
    https://parts.toyota.com/p/Toyota_2019_Tundra/Hardware-Kit-Sway-Bar/69528937/PTR1134091.html
  28. Jun 6, 2021 at 5:18 AM
    #88
    Black
    2014 Tundra Limited CrewMax
    Simple antiseize and torque numbers this low will not make a difference.
    You will have more variance in the calibration of the torque wrench than will be effected by antiseize.
  29. Jun 6, 2021 at 5:52 AM
    #89
    bigmout
    bigmout New Member
    I picked up a replacement kit from McGeorge Toyota. I screwed up, so I want to make it right. Looks from the existence of that kit I'm not the first to bork it.
    I'm just surprised that the bracket is that weak to bend like that if the slightest bit of lube gets on the u-bolt and nylock nut. 48 ft-lbs doesn't seem like much.
    Thanks for the link Elduder.
    Elduder likes this.
  30. Jun 6, 2021 at 7:25 AM
    #90
    Black
    Antiseize did not cause the bracket to bend.
    I would have backed the nut off slightly and ran it just like that.
    Worse thing that would happen is a noise maybe.
