Bully dog gt issues
Discussion in 'Performance and Tuning' started by mjAZ, Apr 7, 2018.
  1. Apr 7, 2018 at 4:47 PM
    mjAZ
    mjAZ [OP] New Member
    2017 tundra sr5 .
    3” level kit in front. 33” BFG all terrains kO2 on 20” raceline shifts.. bully dog gt tuner
    i just got a bully dog gt platinum tuner , for my 17 SR5.. I m updating the tuner but 10-14 is the only thing that shows up!... has anyone had this issue??
    Thx
  2. Apr 7, 2018 at 5:24 PM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    It will work fine with your 2017. I had the same question when I installed mine. But do yourself a favor and don't install until Monday when bullydog is open. In case you run into an issue during install like I did. You don't want to brick your ecu.
    darkknight2014 likes this.
  3. Apr 7, 2018 at 5:43 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Exactly what he said. Same thing I did. They will walk you through it.
  4. Apr 8, 2018 at 6:49 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Exactly. Always do your downloads with Bullydog on the phone.
  5. Apr 30, 2018 at 2:20 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What type of charger are you guys using while the bully dog tune being put it? Does it have to be certain amp charger or volt ?? Need to reinstall mine and need to get some type of charger to do it ? Help!
  6. Apr 30, 2018 at 2:25 PM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    I just use an 85 amp charger from Autozone
    Jsena likes this.
  7. Apr 30, 2018 at 2:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t have the same bully dog I have the BDX. I thought about just putting a battery tender on but I went ahead and put on my diehard battery charger. I did have it at 2 A but I noticed the battery level dropping a little bit so I charged it at 10 A.
    Jsena[QUOTED] likes this.
  8. Apr 30, 2018 at 2:26 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Just put any battery charger on it. You don't want the battery to go into low voltage when it's flashing or it will brick the computer. There is a voltage check it does before the flash as well to make sure it's not low voltage to start with. I had my charger set at 10 amps.
    Jsena[QUOTED] and 15whtrd like this.
  9. Apr 30, 2018 at 2:26 PM
    15whtrd
    15whtrd Mr. Blonde
    85 amp is just for 10 seconds at a time when you have it on jumpstart. Correct? That’s a lot of amps
  10. Apr 30, 2018 at 2:28 PM
    jberry813
    Lake Tahoe
    Correct. It's a timed high amp setting.
    15whtrd[QUOTED] likes this.
  11. Apr 30, 2018 at 2:28 PM
    BayRunner
    Correct, it's rated at 85 but auto delivers what is needed
  12. Apr 30, 2018 at 2:33 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So buy a charger that can go at lesser 10 amps?
  13. Apr 30, 2018 at 2:36 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I just want some cheap one since I carry
    My battery jumper with me always..
  14. Apr 30, 2018 at 2:36 PM
    jberry813
    Lake Tahoe
    I would. 2 amp is just a trickle charger and isn't really great for anything except maintaining a battery on a vehicle that isn't driven a lot.
    A nice charger with multiple charge settings (including jump start) is a great tool to have at home for many reasons. I've been using the same one for almost 10 years.
    15whtrd and Jsena[QUOTED] like this.
  15. Apr 30, 2018 at 2:38 PM
    15whtrd
    15whtrd Mr. Blonde
    I think you should be OK if you’ve got more than just a battery tender. If you’ve got a charger that’s meant to charge a battery from dead to full charge it’s probably sufficient. Shit for all I know it might work with one of those standard battery tenders. Back when I used to use Superchip I didn’t use a charger at all. But the bully dog takes quite a bit longer to fully download. Especially the initial set up of the device. I would think in the future it should just take a few minutes.
    I’d go with what Jason says. @jberry813
    jberry813 and Jsena[QUOTED] like this.
  16. Apr 30, 2018 at 2:40 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea mine has already been in before.. I just put it back to original when I took it in to Toyota. I got scared and unplugged everything. Anyone else just hide the bully when taking it in to Toyota or do you uninstall the tune back to factory??
  17. Apr 30, 2018 at 2:48 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    I have DAP tune now that was done in person so it can’t be detected by the dealer. I had bullydog prior and would revert back tonstock time when I took it in for free oil change. I still have the bd in the truck as a monitor and I still remove it when going tot he dealer, even though the tune isn’t installed. That and I remove my Traction Control Disabler as well.
  18. Apr 30, 2018 at 2:56 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Which one guys
  19. Apr 30, 2018 at 3:03 PM
    15whtrd
    15whtrd Mr. Blonde
    Both would work. But the upper one looks more versatile with more amperage.I like the looks of the bottom one but it doesn’t have jumpstart
  20. Apr 30, 2018 at 3:10 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I got the bottom one.. $50 cheaper than top and this is the only thing I’ll be using it for.. should be cool :thumbsup::thumbsup: thanx for all the help fellas
