Gear ratios and transmission specs.
Discussion in 'Performance and Tuning' started by Mountun Goat, Apr 4, 2018.
  1. Apr 4, 2018 at 5:57 PM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Anyone now how I can find out which transmission and gear ratio my truck has? Like in the vin number or something?? Are there codes on the truck somewhere showing what’s in it? I know my old Chevy did... but I’m a Toyota newby.
  2. Apr 4, 2018 at 6:05 PM
    LML 3500HD
  3. Apr 4, 2018 at 6:23 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Filthyphil and MDHinSD like this.
  4. Apr 4, 2018 at 6:29 PM
    LML 3500HD
    I think 4.10s were offered in certain drivetrain configurations. Not real common though. If you have the 5.7L motor and tow package, 4.30 gears.
  5. Apr 4, 2018 at 6:32 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ok thanks for the info. The lack of drivetrain options is good in a way. At least I know what I have haha. :thumbsup:
    831Tun and ColoradoTJ[QUOTED] like this.
  6. Apr 4, 2018 at 6:41 PM
    LML 3500HD
    I agree. Toyota puts together a really good all around package for a set price. With other manufacturers, you have to pay extra for maybe what you don't need/do need. Like getting the max tow package on an F-150. I just love how they give you 7 lug wheels as of 2015, haven't looked into it since. (yes, you read that right). Do you know how retarded expensive that is for buying aftermarket wheels or just wanting factory originals?
  7. Apr 4, 2018 at 6:53 PM
    Nick T
    Nick T New Member
    Toyota AB60F transmission gear ratios:
    1st: 3.333
    2nd: 1.960
    3rd: 1.353
    4th: 1.000
    5th: .728 (First overdrive)
    6th: .588 (Second overdrive)
    That is for the 5.7 doesn't matter 4:10 or 4:30 rear end
    The 4.6 has slightly different ratios
    MDHinSD and Mountun Goat[OP] like this.
  8. Apr 4, 2018 at 8:31 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks fellers
  9. Dec 17, 2018 at 2:11 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    3.91 Rear Differential
    Mechanical & Performance
    4.6L i-FORCE V8 DOHC 32V with Dual Independent VVT-i 310 hp/327 lb-ft 6-Spd Automatic Trans w/Sequential Shift TripleTech(TM) Frame Tow Hitch Rcvr, 4 & 7-Pin Connector 3.91 Rear Differential w/9.5" Ring Gear Automatic Limited-Slip Differential Dbl Wishbone Frnt Susp w/Stabilizer Bar Trap Leaf Rr Susp, Staggered O/B Shocks Power-Assisted 4 Wheel Disc Brakes 18" Styld Stl Wheels w/P255/70R18 Tires
    Mountun Goat[OP] likes this.
  10. Feb 8, 2019 at 1:08 PM
    Clay Grazer
    Clay Grazer New Member
    2017 Ruby Red 5.7L 4WD
    SiberianTundra likes this.
  11. Feb 8, 2019 at 2:27 PM
    SiberianTundra
    Greg
    War Machine
    This is very good info! Thanks.
    Here is direct link to the file.
    https://toyotanews.pressroom.toyota.com/releases/2018+toyota+tundra+product+info.download
  12. Jun 28, 2019 at 10:56 AM
    AnthonyC
    AnthonyC TAKE IT EASY WHILE YOU"RE GOING FAST
    Anthony
    Virginia Beach, VA
    2010 Tundra SR5 TRD DOUBLE CAB
    TRD DUAL EXHAUST, FIRESTONE AIR BAGS
    Hello to all. I drive a 2010 SR5 4X4. 430 gear ratios. We are thinking of a toy hauler. I was thinking 5th wheel. Because they handle so much better, I use to drive the big trucks for a living. How much weight can I add to the axle? I’m reading from RV places that 1/2 ton fifth wheels exist.
  13. Aug 9, 2019 at 3:45 PM
    mass-hole
    mass-hole New Member
    You must not have looked too hard when you did:
    1. 2015+ F150's do not have 7 lug wheels. At all. They have 6 lug wheels even with the HD Payload Package
    2. F150's before 2015 all had 6 lug wheels UNLESS you special ordered the HD Payload Package. Then you did get 7 lug wheels along with a 8200 lb GVWR and north of 2300 lbs of payload in a crew cab 4x4. What GVWR and payload capacity does a 4x4 crew cab tundra have?
    3. The only reason Toyota went 4.30 gears in their axle is because the transmission ratios are insanely tall. Even the old 6 speed F150 has a better overall gear ratio in 1st gear with only a 3.55 axle ratio(4.141 x 3.55 = 14.81) than the Toyota with 4.30's (3.333 x 4.30 = 14.33). Now that the F150 has the 10 speeds its not even close, even 3.15 axle gears in the F150 have a greater gearing advantage. So basically, Toyotas package is about equivalent to the average 6 speed F150 without the Max-tow package.
  14. Aug 9, 2019 at 5:12 PM
    LML 3500HD
    Oh you got me....by one year. Did I say anything that wasn't true except what year the stupid 7 lug wheels were offered? No. Do you have to pay extra for the Max Tow Package? Yes. Does Toyota offer a good all around package for a better price? Yes.
    Don't be a masshole on here.
    snivilous, 1RONMAN81 and Getmeacoors like this.
  15. Aug 9, 2019 at 5:15 PM
    LML 3500HD
    You most likely do not have the capacity for a 5th wheel unless you have a 2wd, reg cab.
    https://www.tundras.com/threads/tow-ratings-guide-the-how-to.39211/
    Rex Kramer likes this.
  16. Jan 8, 2021 at 12:12 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Excellent information.
    Do you happen to know the maximum speed recommendation for each gear?
    Never exceed ** mph while in * gear.
  17. Apr 6, 2023 at 7:54 AM
    tundra beaste
    tundra beaste New Member
    kris
    07 tundra crewmax limited 5.7 sklver
    loud system 3/1.5 level 35s on stock rims 1/4spacers
    Hey all tring to figure out what I should do. At 75 to 80 mph my rpms hovers at 19 to 2100 tring to bring back down to around 12 1300. I have heavy tires 35s. Stereo in the truck subs and stuff and then I've also got some motor stuff done also full long tube headers cat delet pipes and y pipe to out pipe no muffler. I have the 07 5.7l crewmax 2wd any ideas
  18. Apr 6, 2023 at 10:20 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Trying to bring the rpm BACK DOWN? They shouldn't have been lower than that to begin with...
  19. Apr 6, 2023 at 1:47 PM
    tundra beaste
    kris
    After doing high compression pistons, top end stuf and a tune while on the dyno. At 80mph my rpms would hover at 1300 with the straight exhaust it sits around d 1900.
  20. Apr 6, 2023 at 5:41 PM
    snivilous
    SW UT
    I don't know if anyone offers numerically lower gears, let alone you would need like a 2.7 gearing assuming you have 4.10s now. I'd be amazed if the truck would even have enough torque at that rpm to do anything let alone go the speed you want at that rpm.
    tundra beaste[QUOTED] likes this.
  21. Apr 7, 2023 at 6:30 AM
    AnthonyC
    Anthony
    Virginia Beach, VA
    Hello, I drive a 2010 Tundra SR5 5.7 4X4 TRD. I can't tell you what the ratio is in the transmission. But I can share light on what I do know. 2010 Tundra's 2WD 3.91 AXLE RATIO, 2010 TUNDRA 4X4 4.10 AXLE RATIO, TUNDRA 4X4 TRD 4.30 AXLE RATIO. Hope this helps
  22. Apr 12, 2023 at 5:37 AM
    T-MAC
    T-MAC New Member
    Westernesse
    2023 Tundra
    Icon stage 7, Dobisons rear springs and track bar, Icon Rebound Pro wheels, MT Baja Legend 40s, JB4, Pedal Commander, AFE intakes and hot pipes
    Does anyone know if 2nd Gen gears are compatible with 3rd Gen Tundras? I've been asking gear shops and they have no answer yet, and they have no gears specifically for the new Tundras.
  23. Apr 12, 2023 at 1:32 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    The only way this makes sense is if the 1,300 RPM @ 80 MPH was read while letting off the throttle, as the torque converter would be unlocked and RPM would drop. Changing engine internals will not alter your operating RPM at specific speeds.
    You're claim of 1,900 is damn close to perfect. With 4.30 stock gears and 35" tires, you'll be at 1,915 RPM in 6th gear.
    snivilous likes this.
