JBA Upper Control Arm Ball Joint Recall & Replacement
Discussion in 'Suspension' started by UTTundra, Apr 3, 2018.
  1. Apr 3, 2018 at 4:35 PM
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    For anyone that purchased a set of JBA upper control arms that have developed rusty ball joint housings, JBA has developed new bj's that are Cerakoted. They look awesome and should hold up much better. They will exchange your old bj's for the new ones. See the photo for directions. Top notch customer service.
    OBXTundra, TheBeast and GNTundra like this.
  2. Apr 3, 2018 at 4:45 PM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Damnit. I just installed a set of these. Mine aren't rusty so I wonder if I can get in on the recall or have to wait for rust.
  3. Apr 3, 2018 at 4:47 PM
    UTTundra
    Lou
    Utah
    Someone commented on the facebook post that they are in that same boat. JBA replied on the post that they had sent them an email. So, I'd say go ahead and give them a shout about the exchange.
    IndyTundra[QUOTED] likes this.
  4. Apr 3, 2018 at 4:57 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    I just responded to their Facebook post asking if mine can be replaced. Thanks for posting this.
    UTTundra[QUOTED][OP] likes this.
  5. Apr 18, 2018 at 11:10 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Followed his instructions. Mine arrived. Swapping on saturday. Then returning the rusty ones. He will refund once received.
    UTTundra[OP] likes this.
  6. Apr 18, 2018 at 11:41 AM
    UTTundra
    Lou
    Utah
    They refunded me within a few hours of the rusty joints being delivered back to them. Great service.
  7. Feb 26, 2022 at 5:46 PM
    Woland
    Woland New Member
    I installed jba UCA's on my 2004 4Runner - finally decided to set correct caster after over 15 years of driving with 4 deg off with no issues.
    When I got the UCA's, I noticed that the boots are not tight on the bolts and there is an aluminum bushing between the knuckle and the boot. I called jab and asked about this unconventional "solution", and they assured me that everything was fine and as intended. I assumed that for that kind of money, they would do it right. WRONG!
    In less than a year, the ball joints have failed (yes, I lubed living hell out of them every time I did an oil change) because the boot was loose, and water/sand got inside and ruined the joint. It was not an accident - it was a case of lousy design and/or implementation.
    Needless to say, their warranty doesn't cover ball joints...
    I was told that chevy silverado joints have the same configuration without jba's defect. As much as I hate putting anything chevy on my Toyota, I have no choice.
    BUYER BE WARE!!!
  8. Feb 26, 2022 at 5:52 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Installed mine 1 week of January.
  9. Feb 26, 2022 at 6:55 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Message marlin, I am more than sure he will take care of you. I ruined a set of ball joints by over torquing them a while back, when I asked if he knew the best way to remove the stripped nut he offered to send me a new set no questions asked knowing my problem was self inflicted. He even paid for free 2 day air for me. Jba is top notch as far as customer service goes
    OBXTundra likes this.
