Long Tube Headers, Low End Torque
Discussion in 'Performance and Tuning' started by UTTundra, Mar 30, 2018.
  1. Mar 30, 2018 at 4:14 PM
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    Those with long tube headers, how did your low end torque change after install? Significantly better? About the same? Worse? What's the rest of your exhaust look like? Single? Duals? 2.5" tubing? 3" tubing? X-pipe? H-pipe?
  2. Mar 31, 2018 at 9:17 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Dual 3”, X pipe, bamufflers 3 catback and tailpipes, naturally aspirated makes the absolute best low end torque. Huge change very noticeable.
  3. Mar 31, 2018 at 9:29 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    ^^Same. Running JBA long tubes, stock cats in custom mid section by @dirtydeeds, trd dual replacement system with turn downs. Best mod to date hands down! You'll notice a huge improvement across all ranges not to mention it sounds absolutely BA! I have some sound clips on my build
  4. Mar 31, 2018 at 9:44 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    Not trying to thread jack or anything but I am very interested in this mod. Talked to my mechanic who owns-runs a small auto repair shop. Also built and his son races a flat track sprint car. I talked to him about headers and he said there are a lot of problems with exhaust leaks and cast headers cracking? Are these problems of the old days or is there still some concerns? Peace. D
    UTTundra[OP] likes this.
  5. Mar 31, 2018 at 10:02 AM
    UTTundra
    Lou
    Utah
    Exactly what I was looking for. Thanks.
    boardude[QUOTED] likes this.
  6. Mar 31, 2018 at 10:07 AM
    UTTundra
    Lou
    Utah
    Seems like something you might run into with a cheap set off eBay, but I’m certainly no expert. I haven’t heard of any Tundra owners running JBA, Doug Thorley, OBX, or American Racing having any issues.
    trdprobped17 likes this.
  7. Mar 31, 2018 at 10:20 AM
    dirtydeeds
    Keith
    USA
    I’ve knstalled 30-40 sets. My shop foreman has installed 20-30 sets. Not a single problem or leak.
    When we started having other guys install them for us the leaks began and the installer would alsways blame the headers.
    Moral of the story, of a guy is afraid to tighten them down, they’re gonna leak. Torque spec with a 12mm box end wrench is TAF
  8. Mar 31, 2018 at 10:24 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    No leaks so far and I did my own install. If you get in there and check the bolts every so often you'll be ok. When you have a good leak you'll hear it too, sounds like $hit
  9. Aug 1, 2018 at 7:29 AM
    swain00
    swain00 New Member
    What kind of torque gains would you see just changing to long tube headers. What difference with long tube headers and exhaust
  10. Aug 2, 2018 at 8:45 AM
    showtime240
    showtime240 New Member
    When you change out the headers, I'm assuming you have to get a custom down pipe made if you want to keep the stock cats...
    I am also assuming making a custom down pipe incorporating your factory cats is not something that happens over night.
    What are you guys doing? just not driving your trucks?
  11. Sep 1, 2018 at 12:12 AM
    zackbremer
    zackbremer New Member
    Da Z
    so excited just ordered my JBA LT through @dirtydeeds, along with shipping him my cats for a custom3" mid pipe and Auburn Pro LSD..cant wait for this to go on
  12. Sep 1, 2018 at 3:00 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    Awesome I was just talking to Keith @dirtydeeds on Wednesday about building this system for me with a dump over my axle on my build truck.
  13. Sep 1, 2018 at 4:34 AM
    tundras00
    tundras00 New Member
    Most header leaks are from bubba mechanics that dont use torque specs, torque tightening method (I torque them like wheels),, or bad gaskets. I'm not a mechanic, but I used to wrench on turbo cars, so those are even more prone to leakage due to the massive amount of heat around the turbo area.
  14. Sep 1, 2018 at 6:40 AM
    zackbremer
    Da Z
    nice, mine is going to be dumped before the axle...cant wait
  15. Sep 1, 2018 at 6:54 AM
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Gears and headers I'm excited to see how it turns out for you. Before the axle is how my 8" system is now. Keith and I spoke about it and with the headers and me wanting the least amount of noise and drone possible ( I'm an old guy) he explained the longer the exit pipes the better as it cancels out certain frequencies that cause drone. Since I'm not running a spare or anything in that area I figure well just go ahead and run it up high from the mufflers and straight back and dump it somewhere in the spare tire area.
  16. Sep 2, 2018 at 8:55 AM
    zackbremer
    Da Z
    agreed i hate drone too, if its to obnoxious on the highway ill have a local exhaust shop dump it over the axle like yours..im in the process of cutting my cats out today to ship to keith to build the mid pipes
