New from Sacramento
Discussion in 'New Member Introductions' started by Al D, Mar 22, 2018.
  1. Mar 24, 2018 at 9:19 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Bilstein 5100 up front will give you about 2.5" and looks level, rides very much like stock. Toytec Boss or OME will get the 3/1, try to use shackles instead of a block in the rear. With an 8" wheel a +25 - +30 offset will have your wheels just barely poked out of the fenders. A 1.25" spacer on a stock wheel does the same.
  2. Mar 24, 2018 at 10:21 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    Welcome from CO!
  3. Mar 24, 2018 at 11:27 PM
    pvdubber
    pvdubber New Member
    Auburn CA
    2017 Silver Sky
    Auburn C.A. is correct. Come on up we will be happy to have you.
