Oem running board brackets
Discussion in '2.5 Gen Tundras (2014-2021)' started by Grnjetta6, Mar 20, 2018.
  1. Mar 20, 2018 at 6:59 PM
    Grnjetta6
    Grnjetta6 [OP] New Member
    Darin
    Hudson Valley New York
    2018 Cement TRD Off Road DC
    So I totaled my 2017 dc that has the factory optional cast aluminum running boards part # pt767-34160. My insurance company said that they would not give them a value and that I should remove them if in good shape. They where perfectly fine so the body shop did but I'm missing one bracket to be able to put them on my 2018 dc. Does anyone have an idea where I can get just one bracket. Toyota only has an install kit for $200 with all the brackets and bolts.
  2. Mar 20, 2018 at 7:02 PM
    Grnjetta6
    Darin
  3. Mar 20, 2018 at 7:02 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    Maybe try a junk yard near you? When I totalled my 2011 they hauled it off with the RB still on the truck.
  4. Mar 21, 2018 at 3:14 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Good luck. I have yet to see a late model Tundra in a junkyard; I tried to find a driver grab handle the cheap way.
  5. Mar 21, 2018 at 4:09 AM
    Kevin1741
    Kevin1741 New Member
    I ordered a bracket kit for my oem highlander running boards from roman. Dont remember the dealership. Im sure someone can chime in with info.
