New key and fob programing
Discussion in 'General Tundra Discussion' started by JerseyTundra1260, Mar 19, 2018.
  1. Mar 19, 2018 at 10:11 AM
    JerseyTundra1260
    JerseyTundra1260 [OP] 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Does anywhere know where to pick up a spare key and fob to get programmed rather than Toyota? I just called them and they're looking for almost $300 to do the whole thing. Just trying to cut cost a little bit here. Anyone who may have done this already any help would be great :thumbsup:
  2. Mar 19, 2018 at 10:12 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    ebay, and techstream software.
    JerseyTundra1260[OP] likes this.
  3. Mar 19, 2018 at 4:08 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    Another option is a reputable locksmith. They carry replacement keys, fobs and will cut and program.
  4. Mar 19, 2018 at 4:42 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Genuine Toyota key blank $11 from Amazon and cut at local hardware store, aftermarket fob $15 from Amazon. Had both programed by friend with techstream
  5. Mar 19, 2018 at 5:06 PM
    JerseyTundra1260
    Marc
    New Jersey
    Would anyone happen to have a link to this techstream that I need to use?
  6. Mar 19, 2018 at 6:18 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
  7. Mar 19, 2018 at 6:57 PM
    JerseyTundra1260
    Marc
    New Jersey
    boostedtrdpro[QUOTED] likes this.
  8. Mar 19, 2018 at 7:06 PM
    JerseyTundra1260
    Marc
    New Jersey
    Would this do the trick?
    NewImprovedRon likes this.
  9. Mar 19, 2018 at 7:13 PM
    boostedtrdpro
    Jeremy
    Buy the 2.0 version firmware cable. It captures live data.
  10. Mar 20, 2018 at 3:13 PM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    I was looking but can't tell the version. Will this one work? Screenshot_20180320-180843.jpg
  11. Mar 20, 2018 at 3:16 PM
    boostedtrdpro
    Jeremy
  12. Mar 28, 2018 at 4:15 PM
    heytat
    heytat New Member
    Florence CO
    How does all this work? If I buy a key blank, have it cut at home depot, what do I do with the cable and software to make the key and fob work?
  13. Mar 28, 2018 at 6:26 PM
    ChucklesToy
    Chuck
    Round Rock, TX
    First, realize that the Tundra keys for newer trucks are not like older models where you can get a key at Home Depot, have it cut and off you go...these keys have a security chip in them, so you have to get the correct key to match the year of truck (2018 takes a different key code than 2016 - 2017 for instance). So, after you get the proper key and have it cut, then you use the cable and software to set up the key security chip to be recognized by the ignition. Finally, if you have a key fob along with the key or all in one key, you have to set up the fob to be recognized by the truck.
    I bought my key from an eBay seller (key for my specific year Tundra) and had a locksmith cut and program key and fob. You can have 4 keys total; this made 3 for my truck. Hope this helps.
  14. Mar 28, 2018 at 6:33 PM
    heytat
    heytat New Member
    Florence CO
    Thanks for that info. Where does the cable and software referenced earlier in this thread come into play? Like what do you plug the cable into?
    Thanks again.
  15. Mar 28, 2018 at 6:41 PM
    boostedtrdpro
    Jeremy
    The PC/Laptop and the trucks OBD port
  16. Mar 28, 2018 at 6:48 PM
    heytat
    heytat New Member
    Florence CO
    Copy thanks. So you're actually talking to the truck when you program a new key, rather than talking to the key....?
  17. Mar 28, 2018 at 7:10 PM
    ChucklesToy
    Chuck
    Round Rock, TX
    Yes, you follow the instructions from the software on the PC and insert the key into the ignition and the truck looks for the chip in the key. Then you are programming the truck to accept the key fob transmission.
    boostedtrdpro likes this.
  18. Mar 28, 2018 at 7:11 PM
    heytat
    heytat New Member
    Florence CO
    Thanks
  19. Mar 28, 2018 at 7:23 PM
    ChucklesToy
    Chuck
    Round Rock, TX
  20. Jan 18, 2019 at 9:48 AM
    reefcomber
    reefcomber New Member
    New England
    2018 Platinum
    Does anyone know if the tech stream software is available for Mac? If not, is there any other software that I can use to keep from having to get this done at the dealership?
