My take on amp upgrade on my 2015 DC non-jbl
Discussion in 'Audio & Video' started by Straight6NC, Jan 21, 2017.
  1. Jan 21, 2017 at 8:13 PM
    Straight6NC
    Straight6NC [OP] New Member
    2015 Tundra X-SPS DC
    Been lurking around trying to get ideas on upgrading the stereo on my 2015 DC.
    Stock system just does cut it . And it seems everyone was going the LCi route but I wanted to
    skip that. Here's my take and it sounds great!
    Soundstream Picasso 5 channel amp
    Polk Audio components in the front
    Kickers in the rear (I will be replacing those)
    JL Audio sub under the seat (will post pic later)
  2. Feb 5, 2017 at 4:11 AM
    Captainvfr
    Captainvfr New Member
    2016 Platinum -Midnight Black
    LED Interior
    I have a 2016 Platinum with the JBL stereo and it is just not loud enough. I do not want to replace the head unit. Did you replace the amp? Any suggestions would be appreciated. Thank you
  3. Feb 5, 2017 at 5:07 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  4. Feb 5, 2017 at 7:48 AM
    Straight6NC
    Yes I kept my stock head unit. Basically replaced the stock amp, speakers and installed a sub. The soundstream Picasso 5 channel amp is a good match because it uses the stock speakers wires as input and it's enough to power all your speakers and a single sub. Cheap way up upgrading the system and doesn't take a lot of space.
    dandailey likes this.
  5. Jan 22, 2018 at 5:33 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Hey, how you like that amp? Been holding up?Looking at same 1 for my kicker 10 and stock speakers.
  6. Jan 22, 2018 at 6:13 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    One must never stop thinking..I went a different route on my 17 dc.
    Had the hu from my previous car..
    That amp fits in palm of your hands..
    Still need to upgrade the door speakers and sub amp..
    https://www.ebay.com/i/302169235307?chn=ps
    Mountun Goat and Berdine like this.
  7. Jan 22, 2018 at 6:14 PM
    Berdine
    Frank
    Binghamton, NY
    You use the same amp?
  8. Jan 22, 2018 at 6:19 PM
    xj2202009
    x
    Lutz, Fl
    The pbr300 runs my factory doors speakers and I have a cheap amp that runs the subs
    That 8 inch is not loud outside the truck but inside your seat feels like is moving..
  9. Jan 22, 2018 at 6:28 PM
    Berdine
    Frank
    Binghamton, NY
    Thanks, still on the fence of what I want to do. Ordered another android style radio, not sure if I want to keep it. Have to cut the iso plug off and wire a harness on for the Tundra.
  10. Jan 22, 2018 at 6:39 PM
    xj2202009
    x
    Lutz, Fl
    I have an android radio that I used but was not happy with the sub output..might install it in the camper..
  11. Jan 22, 2018 at 6:50 PM
    Straight6NC
    Ended up dumping that amp and getting a JBL amp. Sound stream was descent but wanted more umph. I also added an LC7i line converter. Much happier with the system now. Pretty good set up and does not break the budget
  12. Mar 19, 2018 at 6:39 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Why a LCI7 and not a 6?
  13. Mar 21, 2018 at 5:03 PM
    Straight6NC
    I’m sure the 6 is fine, only bought the 7 coz i got a deal on it
  14. Mar 21, 2018 at 6:39 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Looks like the 7 has bass adjustment that the 6 does not.
  15. Mar 21, 2018 at 8:12 PM
    Straight6NC
    If I had to do it over I would probably get the EQL. Atleast u can tweak it some more
