Transfer Flow vs. LRA (long range automotive) fuel tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by l3LUEFALCON, Mar 15, 2018.
  1. Mar 15, 2018 at 12:37 AM
    l3LUEFALCON
    l3LUEFALCON [OP] RIG MECHANIC
    Josh
    North Houston Area
    2014 5.7 FFV MGM CM SR5 4WD TSS-OR AKA: MILDRED
    (DIY) CB Radio, Tool Box, ESP Under seat storage, Husky front/ Weather tech rear floor mats, (DIY) Console Safe (Bio-metric), 275/60/R20 Conti Terrain Contact, Magnaflow Exhaust, Katskin leather seat covers, LRA 46 gallon replacement fuel tank, TRD Pro shocks Front/Rear.
    I live in Houston and regularly commute to Louisiana and back. I have been through several hurricanes and as most people in the south... and some in the north know, fuel can be a scarce commodity during an evacuation. My whole thought process is to get from Louisiana back home to Houston on one tank of gas. As it is now with my 2014's (I call her Mildred) 26 gallons of fuel, I have to at least make one stop, and that is not counting if I encounter traffic (Which is likely in a hurricane scenario). I want to know if anyone here has had experience with the LRA tundra fuel tank? I have looked at other forums and found plenty of people that have installed a Transfer Flow tank, but I come up with nothing for the LRA. The reason I ask is that the main complaint about the TF tank is how it protrudes past the frame and the rear axle. I have just been able to look at a few pictures of the LRA https://longrangeautomotive.com.au/Toyota-Tundra-175L-Replacement~344 and it looks to be beveled on all the ends as well as not having a flat bottom, but rising with the frame. Any thoughts? Anyone? P.S. This tank is made in AU. I sent an email to them and after a week I was finally contacted by a US distributor and this is what they sent me:
    Hi–
    I cannot speak to the TF product, but the LRA tank is 46 gallons, made of aluminized steel. The tank doesn’t care what fuel is in it and I am not sure what clearances are. I can only offer photos at this link https://longrangeautomotive.com.au/Toyota-Tundra-175L-Replacement~344
    We are in the process of establishing US warranty and will offer 5 years. Pricing is $1,295 plus motor freight.
    I would love to help you own a Long Range tank, so please feel free to call my direct number with questions or to place an order.
    You might also enjoy seeing our videos
    Thanks!
    Ward
    Samoan Thor likes this.
  2. Mar 15, 2018 at 1:06 AM
    l3LUEFALCON
    Josh
    North Houston Area
    LRA Above
    Transfer Flow Above
  3. Mar 15, 2018 at 1:12 AM
    LML 3500HD
    It’s nice to see a different option other than transfer flow. Priced about the same.
  4. Mar 15, 2018 at 2:21 AM
    l3LUEFALCON
    Josh
    North Houston Area
    Also. This is the US distributor:
    Ward Harris
    Cruiser Brothers, LLC
    ward@cruiserbrothers.com
    1-800-224-7801 - Main
    1-209-636-0831 - Direct
  5. Mar 16, 2018 at 6:34 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Still hangs lower than the frame or I would be interested in it
  6. Mar 18, 2018 at 10:17 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    LRA seems more tucked in and higher than the transfer flow
    15whtrd and TheBeast like this.
  7. Mar 18, 2018 at 1:09 PM
    TheBeast
    TheBeast The Beach
    looks good. Probably don't need a skid plate vs the oem gas tank.
    Black Wolf likes this.
  8. Mar 18, 2018 at 1:22 PM
    Aurora CO
    I definitely prefer that design over TF.
  9. Mar 18, 2018 at 3:42 PM
    Samoan Thor
    I’ve been back and forth whether I should buy a bigger gas tank or get jerry cans like those overland rigs, weight vs space(room with multiple jerry cans) ....hmmmmm?!!!!
  10. Mar 18, 2018 at 5:48 PM
    gosolo
    Ray
    NW Oregon
    The picture of the transfer flow tank makes it look like it is much lower than it is. At least,on mine. The front end is nearly flush with the frame and the rear is about 1 1/2” below the frame. Both the pumpkin and the lower shock mount are much lower so that should never be a problem. The tank is so strongly built that I don’t feel a skid is needed. The Australian tank does have a nicely beveled rear corner that I wish I had. It’s only a risk when backing up, but I’ve got some concerns that it could hit a rock or stump, when in reverse.
    As far as jerry cans or any variation of em, I will never do that again. Leaks and spillage, splashes on the truck, fumes and fire hazards make them a no-starter. I did that for years, but never again.
    86Scotty, aperezsh and Samoan Thor like this.
  11. Mar 18, 2018 at 7:48 PM
    Samoan Thor
    Thanks for the wisdom, I agree the shock mounts then the diff are still lower than the TF. I think the only time you’ll hit the tank is in a high centered situation, just cover it with line-x. line-x is strong, hell it survived a shotgun blast and C4 on an episode of myth busters.
    Ike74 likes this.
  12. Mar 18, 2018 at 8:00 PM
    gosolo
    Ray
    NW Oregon
    Absolutely! I had it fully line-Xed before install
  13. Mar 18, 2018 at 8:20 PM
    l3LUEFALCON
    Josh
    North Houston Area
    I like the 46 gallon LRA because of the bevel, and I like the 46 gallon TF because of the Line-X option. I think I will just take the best of both worlds and buy an AU LRA tank then get US Line-X put on it. Yep.... I think that will do that. Seems good. I should make deals with Trump!
    Ike74 likes this.
  14. Mar 18, 2018 at 8:22 PM
    l3LUEFALCON
    Josh
    North Houston Area
    Maybe I could take Old Rex's spot?
  15. Mar 18, 2018 at 9:32 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Jerry cans are cool butttt- Fuel goes bad faster in small amounts. You have to figure out a good way for theives to F off. And they take up valuable room for other fun evacuation party supplies.
    Just sayin
  16. Mar 19, 2018 at 4:08 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I've been using jerry cans for 5 years. My fuel cans are NATO with metal flex spouts and my water are US military water cans. I can carry up to a total of 7 cans in any combination of water/fuel. I never spill a drop of fuel, I can dump an entire 5 ga can of fuel in 30 seconds, and they have survived tens of thousands of miles of the hardest wheeling you can imagine in the most extreme desert environments on earth. I strap them down with a single ratchet strap and floor mounted cargo rails and they never move or shift. I make sure to dump them every few months and I have never had a bad fuel problem
    There is a reason NATO cans have been in use for over 60 years. The only reason I would be interested in an extended tank is to move the fuel weight from the bed behind the cab (which is a very good location from a CG point of view), to below the bed in order to free up a little bed space. But I would only gain about 14" x 32.5" of bed space and I would lose important ground clearance in front of the rear wheel where I need as much clearance as I can get. Hence the reason I am still using the cans...
  17. Mar 19, 2018 at 9:25 AM
    gosolo
    Ray
    NW Oregon
    @osidepunker
    How do you keep your spout/nozzles clean and dust free? This was always a hassle for me. I also occasionally had gaskets dry out and fail. Probably because I was running exclusively around AZ and Mexico.
    Working with, and supervising many projects with large earth moving requirements, I became acquainted with a saying (regarding profitability). “Moving dirt twice costs 2 times as much”
    To paraphrase, “moving fuel twice creates 2 times the risk” regarding hazard or contamination.
    Dumping a can in 30 seconds is amazing!
  18. Mar 19, 2018 at 9:28 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I wrap the nozzle in a rag and store it in my in-cab gear boxes. No fuel smell in the cab. Seals are 5 years old and still seal. I've never had a problem dumping cans. No spills no leaks no bad fuel no dirty fuel.
    If these cans are good enough for miltary troops all over the world, they are good enough for me. The only reason they aren't used in the US is because of environmental concerns.
    Brocksw likes this.
  19. Mar 19, 2018 at 9:41 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    I think i might look at getting one of these and have it tied into the main line, would be way cheaper and you would have the same capacity.
    i am sure they could make it so it tucks tight beind the fender well.
    they make custom tanks, the 15 gallon one is only $260.
    15 gall. plus 26 would get you to 41 with nothing hanging below frame.
    http://www.fueltankparts.com/15-gallon-universal.html
  20. Apr 29, 2018 at 2:09 AM
    l3LUEFALCON
    Josh
    North Houston Area
    So... I decide to get the LRA tank. I will have to wait till the June order comes in from AU. I am ordering one tomorrow. So come June, I will be installing the LRA 46 gallon tank. I will do a write up and instructions on it. (with pictures, cause I know how much yall guys like pictures.) Hopefully that will help if anyone else is undecided on one of these things. For all that I can see, this tank has all the attributes of the transferflow.... but with better clearances and bevels.
    kparrow likes this.
  21. Apr 29, 2018 at 3:48 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Will you get tank Line-x'ed?
  22. Apr 29, 2018 at 3:54 PM
    l3LUEFALCON
    Josh
    North Houston Area
    Undecided. I have to figure how much that will cost.
  23. Jun 6, 2018 at 8:59 PM
    l3LUEFALCON
    Josh
    North Houston Area
    Yes, I will get it Line-x'ed when I get home. Unless someone knows of a better coating that could be applied to it?
  24. Jun 6, 2018 at 9:57 PM
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
  25. Jul 10, 2018 at 4:29 PM
    l3LUEFALCON
    Josh
    North Houston Area
    Update:
    Cruiser Brothers fully line-xed tank before it left Stockton.
    Update:
    Tank did not arrive at my location untill the day I left to go offshore. It will be another 3 weeks before install. (I will get my wife to take pictures and I will post them)
  26. Jul 11, 2018 at 5:07 PM
    l3LUEFALCON
    Josh
    North Houston Area
    There it is. Waiting for me to install!
  27. Jul 11, 2018 at 5:23 PM
    Ericsopa
    Ericsopa Old man and the sea
  28. Jul 11, 2018 at 8:46 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  29. Jul 12, 2018 at 5:01 PM
    l3LUEFALCON
    Josh
    North Houston Area
    FYI
  30. Jul 12, 2018 at 6:09 PM
    PapaGrizz
    PapaGrizz MGM CRÜE
    Derek
    Spokane Valley, WA
    2016 MGM Tundra TRD Off Road Crewmax
