TRD PRO GRILL LED BACKLIT LETTERS
Discussion in 'Deals & Group Buys' started by Sting Ray, Mar 13, 2018.
  1. Mar 13, 2018 at 4:18 PM
    Sting Ray
    Sting Ray [OP] New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Alright folks, after a lot of arm twisting by folks in this forum and others I have decided to put a feeler post out to see how much real interest there is in these LED back lit TRD Pro Grill letters. I was hesitant only because these things take a lot of man hours to build and build right and because of that the price would need to reflect all of that time spent.
    Initial price for first 5 sets: $350 + $8 shipping. Payment required up front to hold your spot.
    Manufacturing lead time 3-4 weeks.
    Letter Colors available: Damn near any Toyota color made.
    LED colors available: white only
    If you are interested or have questions please post here.
    Letters are 3D printed, sanded, primed, and painted. Then lined with chrome tape, LED strip lights installed, wired, and soldered. Acrylic backing is laser cut, laser etched along the edge to refract the light, and epoxied onto the letters. Letters are attached to the grill using double sided 3M tape just like stock letters. Wiring harness with an in line fuse is built to run behind the grill and tap into a 12V power source (parking lights) and ground. Letters will plug into the wiring harness using male/female molex style pins.
    To Install:
    -Remove existing grill letters, using braided fishing line and a heatgun/hair drier, just like a normal badge
    -Remove grill
    -Run the wires for each letter through the existing alignment pin holes
    -Stick the letters to the grill using the double sided tape
    -Plug the letter wiring into the wiring harness and heat shrink the connections to seal out any moisture
    -Install grill
    -Install t-tap onto a 12V power wire (parking light wire is a good option) or if you want the lights on all the time you could utilize and add a circuit and tap into the fuse box to a keyed on circuit, or t-tap into any keyed on 12v power wire.
    -Install ground ring terminal to the ground that is located on the driver’s side fender well/engine bay wall.
    Again this is just a feeler thread. If we get 5 folks interested then we will proceed with the build.
    IMG_6680.jpgIMG_6679.jpgIMG_6677.jpgIMG_6672.jpgIMG_6671.jpgIMG_6664.jpgIMG_6650.jpgIMG_6681.jpgIMG_6680.jpg
  2. Mar 13, 2018 at 4:19 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    1. Ely010606 quicksand
    2. aramirez73 mgm
    3.Matthew Goosic super white
    4. Toyotoholic MGM
    5. Justin Sullins MGM
    Poheller-unpainted, with backs
    Tim Daugherty-unpainted with back
  3. Mar 13, 2018 at 4:54 PM
    Like a PRO
    Like a PRO New Member
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    6 inch Rough Country lift fuel 20×9on 35s , TRD Pro Grill TRD Pro exhaust dual Extang 2.0 tonneau cover
    Interested ! Been trying to figure out how to do just this ! So you'll supply the grille ?
    Sting Ray[OP] likes this.
  4. Mar 13, 2018 at 5:18 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No I supply the letters. You install them on your grill.
  5. Mar 13, 2018 at 5:20 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Just saw ur post on t.c lol
    Sting Ray[QUOTED][OP] likes this.
  6. Mar 13, 2018 at 5:53 PM
    Like a PRO
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    350.00+8.00 shipping for the letters ?
  7. Mar 13, 2018 at 6:04 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Yes thats correct.
  8. Mar 13, 2018 at 6:15 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  9. Mar 13, 2018 at 7:00 PM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
  10. Mar 13, 2018 at 7:08 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Replied
  11. Mar 13, 2018 at 7:17 PM
    Put me on list!
  12. Mar 13, 2018 at 7:30 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  13. Mar 13, 2018 at 9:03 PM
    Like a PRO
    Rodney
    Slidell Louisiana
    2016 lifted 4×4 SR5
    I'm in !
  14. Mar 13, 2018 at 9:03 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Pming
  15. Mar 14, 2018 at 7:06 PM
  16. Mar 16, 2018 at 9:06 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    3rd person pre paid. 2 more and we'll kick this off
  17. Mar 16, 2018 at 9:38 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    So tempting. Hmmmm
  18. Mar 16, 2018 at 9:59 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    pretty cool
  19. Mar 16, 2018 at 10:10 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Will look amazing on your truck painted in white. ....
  20. Mar 16, 2018 at 10:11 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Thanks.
  21. Mar 16, 2018 at 12:41 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
  22. Mar 16, 2018 at 1:06 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
  23. Mar 16, 2018 at 1:17 PM
    @Sting Ray More difficult if diff color lights?
  24. Mar 16, 2018 at 1:36 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No but not doing that right now. Keeping it simple at first before changing up the design. Maybe at at some point in the future can do different colors and or rgb with a color change blue tooth controller or something.
  25. Mar 16, 2018 at 1:39 PM
    Gotcha
  26. Mar 16, 2018 at 2:59 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    4 sold. 1 more spot to go.
  27. Mar 21, 2018 at 6:41 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Printing. Still have 1 spot left.
  28. Mar 21, 2018 at 6:44 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    C'mon guys! Who is going to join us with this super unique and Badass mod!!!
    Ely010606 likes this.
  29. Mar 21, 2018 at 8:03 AM
    BayRunner
    BayRunner I’m here, except when I’m not
    2017 Tundra Platinum
    If I was running a Pro grille, I'd do this in a heartbeat. As you said, very unique.
    Toyotoholic[QUOTED] likes this.
  30. Mar 21, 2018 at 4:33 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
