315/70-17 on RW wheels w/ Camburg UCA's
Discussion in 'Wheels & Tires' started by blizz86, Mar 6, 2018.
  1. Mar 14, 2018 at 9:04 AM
    [DELETED]
    [DELETED] New Member
    Jeff
    Better. I'm not sold, tho... :rofl:
    SoCal619 likes this.
  2. Mar 14, 2018 at 10:07 AM
    blizz86
    blizz86 [OP] New Member
    Funny cus I want the original finish
    Down to trade?? Lol
  3. Mar 14, 2018 at 10:58 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Yea except he doesn’t want to really trade haha. Thanks for the bro hookup
    SoCal619 and osidepunker[QUOTED] like this.
  4. Mar 14, 2018 at 12:06 PM
    blizz86
    Pics to follow, turns out they do slightly rub the camburg ucas at lock...
    equin and (deleted member) like this.
  5. Mar 14, 2018 at 12:06 PM
    TheBeast
    TheBeast The Beach
    @BlueBottle didn't you have the same issues when you had those UCAs ?
  6. Mar 14, 2018 at 12:29 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Methods or SCS
  7. Mar 14, 2018 at 12:37 PM
    blizz86
    What i really want are SCS ray10's in bronze in 17.. :l
    Normal road curves and turns i don't feel any rub, but tighter space maneuvers i can tell there is some. I'll likely run spacers in front until i see a wheel i fall in love with.
    So far on road feel is exceptionally smooth for an AT tire. I'll have pictures up later!
    Watt maker and SoCal619 like this.
  8. Mar 14, 2018 at 12:43 PM
    pschiller86
    Paul
    Temecula, CA
    I have the baby version of your tires (275s) and they are awesome :rofl:
    blizz86[QUOTED][OP] likes this.
  9. Mar 14, 2018 at 12:46 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Tires never rubbed on UCA. because of my caster, my sway bar rubbed on my coilovers.
    TheBeast[QUOTED] and SoCal619 like this.
  10. Mar 14, 2018 at 12:46 PM
    blizz86
    I am just hesitant to run spacers because i had spidertrax on my old 4runner.. they don't allow my rotors to free float and i developed a slight wobble whenever i applied the brakes. Any one face issues like this and was able to correct it?
    Seems i need to be especially careful when mounting them
  11. Mar 14, 2018 at 12:50 PM
    TheBeast
    TheBeast The Beach
    I had that too and the sway bar is gone :)
  12. Mar 14, 2018 at 1:01 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    My sway bar is gone now too lol
    TheBeast[QUOTED] likes this.
  13. Mar 14, 2018 at 1:11 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    You have free float rotors? :eek:
  14. Mar 14, 2018 at 1:11 PM
    TheBeast
    TheBeast The Beach
    I did grind the sway bar ends though ala "TRD front sway bar" so it doesn't poke anymore in my coil overs. In case one day i want to put it back on.
    BlueBottle[QUOTED] likes this.
  15. Mar 14, 2018 at 1:27 PM
    blizz86
    If you look at the way our brakes are setup, the rotors slip onto the hub and are contained by the caliper..
    they arent bolted on anywhere - thats what i mean by free float
  16. Mar 14, 2018 at 1:34 PM
    tomsinamerica
    Tom
    Wilmington, NC
    but the wheel spacer does the same job as your wheel... it's that which fastens the rotor to the hub. floating rotors are a little different... and they're pretty cool and if you had them for your tundy... i wanted them too!
  17. Mar 14, 2018 at 1:59 PM
    blizz86
    I think im just using the wrong word.. with the stock and rw wheels the lug washers seat the wheel dead onto the hub and thus the rotor. But with spacers, if you aren't exactly precise when installing, the rotor can be a few degrees "cambered" when the spacer is torqued down and it doesn't correct itself when you bolt on the wheel
  18. Mar 14, 2018 at 2:49 PM
    tomsinamerica
    Tom
    Wilmington, NC
    yup, agreed... that's why some of us, me included, love hub centric specific wheels/spacers and so on. Even so, you're right, spacers & wheels means you have to get two things right to make sure your rotors run with zero run out
  19. Mar 14, 2018 at 2:52 PM
    blizz86
    Pictures show the wheel turned driver full lock. These tires sure are bitching though
  20. Mar 14, 2018 at 3:08 PM
    #50
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    mmm that's snug!
    TheBeast likes this.
  21. Mar 14, 2018 at 7:06 PM
    #51
    blizz86
    the first picture its actually contacting the uca already...
    got home and slipped on 1/4 inch spacers i had previously installed for a while..
    reading about hubcentric spacers vs non hub centric got me a little worried so i put some antiseize on the mating lip of the wheel to see if it was sitting on my hub or not and it did get some grease on the hub.. about an the wheel sits on about 1/8 of the hub lip.
    this should be fine right?
    i really dont want to run 1.25 inch bolt on spacers and have my tires poking out that much.
  22. Mar 14, 2018 at 7:46 PM
    #52
    blizz86
    Thanks man. That gives me some confidence, when I mount the wheel I definitely feel it riding up the hub vs sitting on the studs. I can get a good 5 turns on my lug nuts on by hand before torqueing it, I think stock length is ok.
  23. Mar 15, 2018 at 4:35 AM
    #53
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Couple things:
    Hub centric spacers are a must. Spidetrax is hub centric.
    During install, I use blue loctite (not red or they will suck to take off). I torque, install wheel, drive down the street quickly and do a couple hard stops and s turns, then pull the tire and retorque the spacer while the loctite is still wet. This makes sure the rotor is properly seated.
    If anybody wants to sell their work warrior wheels, I am looking for another set.
  24. Mar 15, 2018 at 7:21 AM
    #54
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    As everyone said. Hubcentric is a must.
    Always keep an eye on them and maintanence them religiously. Do not over torque you’ll be good!
  25. Mar 15, 2018 at 9:02 AM
    #55
    TheBeast
    TheBeast The Beach
    looks close. time for new rims :)
    +18 or +25 should be good with backspacing of 5.75.
    zcarpenter92 likes this.
  26. Mar 15, 2018 at 12:15 PM
    #56
    blizz86
    lol definitely don't want to do that. With the 1/4 spacers im getting just a touch of rub at full lock.. i don't really want any other wheels on the market now, and i dont really want to add 1.25 spacers :annoyed:
    TheBeast and SoCal619 like this.
  27. Mar 15, 2018 at 12:25 PM
    #57
    TheBeast
    TheBeast The Beach
    I hear you. The wheels are nice
  28. Mar 15, 2018 at 1:24 PM
    #58
    blizz86
    SoCal619 and TheBeast like this.
  29. Mar 15, 2018 at 2:03 PM
    #59
    TheBeast
    TheBeast The Beach
  30. Mar 20, 2018 at 8:05 AM
    #60
    blizz86
    Drove up to mammoth this past weekend, super quiet on the highway - moreso than my toyo at2.
    Did fishtail a foot or so sideways when making a sharp left at slow speed on ice in 2wd, but when going straight these tires chewed through the snow/ice. Switched to 4hi for the peace of mind and it didn't slip at all even going through curvy hills.
    TheBeast and Watt maker like this.
