Tailgate lock stuck
Discussion in '2nd Gen Tundras (2007-2013)' started by Happybg81, Feb 22, 2018.
  1. Feb 22, 2018 at 11:14 AM
    Happybg81
    Happybg81 [OP] New Member
    William
    13’ Balcked Out Rock Warrior DC
    Switched backup camera, interior led’s, backflip g2, smoke led taillights, rhino liner, leveling kit, black powder coated rw wheel rings, weathertech mats, under seat storage, evo one remote start, flowmaster 50 series, S&B CAI, Focal 6x9 front doors, Rockford Fosgate 6.5” rear doors, JL Audio dash tweeters, Kicker hideaway under rear seat
    My tailgate won’t unlock on my 13’ DC. Normally I’d just start taking it apart from the inside. But, I have a Bakflip G2 on it and no way to get it open with the tailgate stuck closed. Anyone dealt with this and have a solution?
  2. Feb 22, 2018 at 11:24 AM
    15whtrd
    15whtrd Mr. Blonde
    Sorry I don’t have your answer, but that really sucks. You think it’s just frozen inside because the weather? Sorry I can’t tell where you’re from.
  3. Feb 22, 2018 at 11:27 AM
    Happybg81
    William
    No, it’s been 70’s here all week. It acted weird the last time I unlocked it, and I wasn’t going to lock it again. But, I forgot to tell the wife that.
  4. Feb 22, 2018 at 11:28 AM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I'd try some lock de icer then lubricate it with some graphite lubricant. I always grease my tailgate latches because that's where it always freezes on me.
    Voss likes this.
  5. Feb 22, 2018 at 11:30 AM
    15whtrd
    15whtrd Mr. Blonde
    So does it unlock but the handle just doesn’t work? For example does the handle move just nothing happens?Or is the lock itself not turning?
  6. Feb 22, 2018 at 11:42 AM
    Happybg81
    William
    The lock itself will not unlock.
  7. Feb 22, 2018 at 11:47 AM
    Happybg81
    William
    Just found a key I had cut a couple years ago and it opened it right up. Guess it was just wore out keys.
    Black Wolf and 15whtrd like this.
  8. Feb 22, 2018 at 11:50 AM
    15whtrd
    15whtrd Mr. Blonde
    Crisis averted! Make sure you always have a fresh key at home that you can go back to. Get new keys made from the good key. Actually I think in my paperwork I have a key code that they can use as reference. I actually had a key cut that will at least get me in my doors if I lose my keys I’m carrying. I keep a hide a key under the truck. Then I may or may not have a chipped ignition key stashed in the vehicle.
  9. Feb 22, 2018 at 11:53 AM
    Aurora CO
    Whew!!!
    GNTundra and 15whtrd like this.
  10. Mar 8, 2018 at 12:52 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Install the pop n lock tailgate lock to cure that forever. Then the bed is always locked/unlocked when the truck is! Part number PL8535 about $85. Did that and the LED bed lights under my solid fold. It is awesome seeing under there. part 00016-34089 fits 2nd gen just fine as the 2nd and 3rd gen have the same bed (on the inside of the bed at least)
    Black Wolf likes this.
