Spyder Headlight/Taillight installation?
Discussion in 'Lighting' started by Lhershner7, Feb 12, 2018.
  1. Feb 12, 2018 at 8:22 AM
    Lhershner7
    Lhershner7 [OP] New Member
    2014 Tundra Platinum
    So I'm having a lot of trouble installing the Spyder headlight and taillights on my 2014 Tundra Platinum. They said they would work with my truck when I purchased them. I put both of them in and so far all the following lights work (high beams, turn signal for both rear and front, brake lights, and reverse lights) but the DRL lights don't work for both the back and front lights and also the OLED strip on the headlights does not come on. Does anyone know what I need to do?
    Berdine likes this.
  2. Feb 12, 2018 at 8:41 AM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    Did you but them direct or from a member on here? I don't want to sound rude, but did you check to make sure there are actual bulbs in all the sockets? When I installed mine the DRL's were not in there as well as the side lights(I don't know what they are called). It also took me a minute to realize that I needed to turn my truck on to a certain point to have the turn signals work. But mine were plug n play and the OLED strip wokred right from the get go. I did notice it flicker one time and I made sure the connections were good after that so maybe check the connections one more time? Also, what bulbs did you install, LED's, HID's or Halogens? That's all I got for you. Hoping someone more savvy than myself will hop in for advice.
  3. Feb 12, 2018 at 10:01 AM
    Lhershner7
    I bought the headlights off of Amazon which came and the taillights on craiglist. Ill probably have to go back and check to make sure I have all the bulbs in. I have no idea what bulbs I installed, I took the bulbs out of the stocked headlights/taillights and used those.
    ccdawnpatrol likes this.
  4. Feb 12, 2018 at 10:03 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    They look great though, hope you work it out!
  5. Feb 12, 2018 at 2:17 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    The LED strips don’t turn on unless the parking light or the headlights are on. I’m assuming you already know that
  6. Feb 12, 2018 at 2:32 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    :smack: :smack: :tinfoilhat:
  7. Feb 12, 2018 at 2:39 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    Welcome! Nice looking truck!
  8. Feb 12, 2018 at 3:04 PM
    Berdine
    Frank
    Binghamton, NY
    Got another pic of the headlights from farther out? I' liking the look
  9. Feb 12, 2018 at 4:25 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    on my 08, front, I had to tap into my side marker light for the front LED to come on when I use my stalk.
    For the rear flip the plug in to reverse the polarity..... The brake and turn bulbs will work normally as you didn't remove them. the LED you had to remove the bulb and plug harness into the spyder.....so flip it around
    hola back
  10. Feb 12, 2018 at 4:32 PM
    Welcome from Texas! MGM WRECKIN' CRÜE!
  11. Feb 12, 2018 at 6:36 PM
    Lhershner7
    It was a fuse under the steering wheel..... all the lights are finally working!
    Berdine, ccdawnpatrol and Les7311 like this.
  12. Aug 29, 2018 at 6:50 AM
    VAQuicksand
    VAQuicksand New Member
  13. Aug 29, 2018 at 11:20 AM
    Berdine
    Frank
    Binghamton, NY
    That's weird, mine were plug and play, I also upgraded the bulbs to hikari leds, which were also plug and play
  14. Sep 21, 2018 at 6:11 PM
    GreyWVLF
    GreyWVLF New Member
    2013 Rock Warrior
    What am I doing wrong? ‘13 tundra, switching to spyder gen 2. Everything lines up great except these two guys. Bottom is from spyder, top is tundra.
  15. Sep 21, 2018 at 6:48 PM
    Berdine
    Frank
    Binghamton, NY
    Bottom looks like 194 bulb plug, so that should be where your 194 side marker light. Did you have level motors on your stock headlights? Looks like the 2nd plug
  16. Sep 21, 2018 at 7:32 PM
    GreyWVLF
    GreyWVLF New Member
    2013 Rock Warrior
    I did have level motors. Top is where I unplugged stock side marker light. Picture attached of that bulbs connector. Bottom is coming out from the new spyder lights, It looks like it might be for the led bar. Picture another picture attached of this. This plug doesn’t go into the factory harness, also doesn’t plug into bulb I pulled out from side marker connector.
    I also added a picture of the back of the spyder.
  17. Sep 21, 2018 at 7:52 PM
    Berdine
    Frank
    Binghamton, NY
    It's weird cause it needs a twist type plug for it. Got a pic of the front or link to the lights you bought?
  18. Sep 21, 2018 at 7:55 PM
    GreyWVLF
    GreyWVLF New Member
    2013 Rock Warrior
  19. Sep 21, 2018 at 7:57 PM
    Berdine
    Frank
    Binghamton, NY
    There's a few people running those on here. Must be they're not up in a friday night
  20. Sep 21, 2018 at 8:05 PM
    Berdine
    Frank
    Binghamton, NY
    ChiefMiro15 and GreyWVLF like this.
  21. Sep 21, 2018 at 8:11 PM
    GreyWVLF
    GreyWVLF New Member
    2013 Rock Warrior
    I just figured it out. I guess I just had to stare at it and talk about it. Thanks for the help and this video is right on!
    NewImprovedRon likes this.
  22. Sep 21, 2018 at 8:13 PM
    Berdine
    Frank
    Binghamton, NY
    Great! No problem
  23. Sep 22, 2018 at 1:11 AM
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    Can we get some pics of the lights front and back please? I'm curious to see how it all looks!
  24. Sep 22, 2018 at 11:14 AM
    GreyWVLF
    GreyWVLF New Member
    2013 Rock Warrior
    Here it is. Front and rear. I’ll post more tonight when it’s dark.
    ScooterInNV, Berdine and fulanoderock like this.
  25. Sep 22, 2018 at 12:23 PM
    fulanoderock
    Ventura County
    LOOking good man! thanks for the pics!
    GreyWVLF[QUOTED] likes this.
  26. Sep 22, 2018 at 4:34 PM
    Berdine
    Frank
    Binghamton, NY
    Yeah looks great!
