Spyder Headlight thread
Discussion in 'Lighting' started by RasTafari48, Aug 28, 2017.
  1. Oct 2, 2017 at 7:57 AM
    Spook46
    Spook46 New Member
    Tundra TRD PRO
    Are you running the 35w or 55w set up? I'm about to pull the trigger on a set of spyders, are those the black version or black smoke? Thanks!
  2. Oct 2, 2017 at 8:00 AM
    35w
    Black I believe. I don’t recall a black smoke version at the time.
  3. Oct 2, 2017 at 8:35 AM
    Spook46
    Spook46 New Member
    Tundra TRD PRO
    Great, thanks, your set up is the best I've seen. I'll run with that!
    T-Rex266[QUOTED] likes this.
  4. Oct 3, 2017 at 9:37 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Not the best angle, but here they are in the black with smoke lense, the smoke on the lense is very light. Running 35w 5500k HIDs.
    da_jeep_luva, drhntr, Berdine and 2 others like this.
  5. Oct 7, 2017 at 2:36 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Can you show a close up? I'm thinking black and smoked also
  6. Oct 7, 2017 at 5:46 PM
    Cuzican
    Cuzican New Member
    Louisiana
    She gets a bath tomorrow, so excuse the bugs, but see it these are what you are looking for.20171007_193414.jpg 20171007_193425.jpg
    Spook46 and Berdine like this.
  7. Oct 7, 2017 at 5:47 PM
    Berdine
    Frank
    Binghamton, NY
    Really like the way they look. The smoke isn't as dark as I thought.
  8. Oct 8, 2017 at 5:54 PM
    Spook46
    Spook46 New Member
    Tundra TRD PRO
    Installed a set of spyders on my Tundra today. Thanks to everyone who contributed to the thread I the install was easy. Also installed a set of Toyotec 35w HIDs. I marked the cut offs of the original lights with tape and adjusted as needed. 46ecce28e797566d2c112f1a5e0d0adc_ffd5b305d6f1da03e83e976f4517a0fcb6e23814.jpg9c9ecda89f0f05900a8ce28873522019_02d39cafc825a35be9d5e3a088ebd1de4ee44605.jpg
  9. Oct 8, 2017 at 6:11 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Looks great!!!
    FlashCulprit and T-Rex266 like this.
  10. Oct 8, 2017 at 9:03 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    I've tried both HID and LED on my spyders and I just couldn't stand the output on the LEDs. It's just not enough for the projector housings. Or at least the LEDs I tried didn't have the output.
    Morimoto is what I have now. 35w and they are briiiiiiiigggghhhhhtttt. Zero complaints. Did have a slight polarity issue. But I ended up cutting and soldering the ballasts to the conversion wires and since then it's been one click on everytime.
    Berdine likes this.
  11. Feb 10, 2018 at 10:28 AM
    cjcarter1254
    cjcarter1254 New Member
    Would this same setup with the toyotec 35w hid and spyders work on a 2008 tundra? I see mainly newer model tundras with this set up.
  12. Feb 10, 2018 at 10:35 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
  13. Feb 11, 2018 at 9:10 AM
    Davidwayne22
    Davidwayne22 New Member
    Anyone know how to change the bulbs to these Spyder headlights? Just had my driver side go out. Noticed both low and high beams are out. I try to remove the white piece that is coming out the back and it only comes out a little ways. Thanks in advance
  14. Feb 11, 2018 at 10:01 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  15. Feb 11, 2018 at 11:32 AM
    Cuzican
    Cuzican New Member
    Louisiana
    What white piece? The one with 3 ears and a bolt head in the middle? If so, that is the retainer for the headlight adjuster bolt, leave it alone. The bulbs are under the big rubber cap with the wires going into it. See pic below.
  16. Feb 11, 2018 at 2:37 PM
    Davidwayne22
    Ah, thanks. So let me guess. This means I will have to remove the grill and headlight to get to it?
  17. Feb 11, 2018 at 5:16 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Most likely, I never found another way to do it.
  18. Sep 17, 2018 at 3:26 PM
    GreyWVLF
    GreyWVLF New Member
    2013 Rock Warrior
    What LEDs did you end up getting for heads and fogs? Also what light bars are you using in tour grille? Love the look of your lighting setup.
  19. Sep 26, 2018 at 11:30 AM
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    Sounds like HIDs are the way to go. Couple of questions...
    How do you go about using the existing leveling motors?
    For a 2017 (1794), do you have to do anything for the LED bar to run like the DRL?
    Anyone have picks of them with the chrome platinum or 1794? Really love the look of these!
  20. Sep 26, 2018 at 1:30 PM
    #50
    War Machine
    War Machine SSEM # 5 3MW
    For the motors, just take them out of the stock lights and put them in the Spyders. It’s pretty easy. There’s a thread here somewhere showing it.
    ScooterInNV[QUOTED] likes this.
  21. Sep 26, 2018 at 5:03 PM
    #51
    Cuzican
    Cuzican New Member
    Louisiana
  22. Sep 26, 2018 at 5:07 PM
    #52
    Cuzican
    Cuzican New Member
    Louisiana
  23. Oct 13, 2018 at 3:50 PM
    #53
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    having the spyder headlights does that eliminate the adjusting of the headlights?
  24. Oct 13, 2018 at 3:51 PM
    #54
    You can adjust manually, or get the motor to it so u can adjust inside cab for upper / lower headlight alignment.
    You still need to adjust accordingly for proper aiming
    MRQZTNDR93[QUOTED] likes this.
  25. Oct 13, 2018 at 3:52 PM
    #55
    MRQZTNDR93
    San Diego CA
    thank you boss
    Rica25 likes this.
  26. Oct 13, 2018 at 6:12 PM
    #56
    Rica25
    Ricardo
    Tulare
    Will the HID light from Toytec tir properly on the spyder headlights for the second gen?
  27. Oct 16, 2018 at 2:50 PM
    #57
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    I bought one of these new version headlights for my sequoia and i was not impressed. After installation, the cutoff line was not leveled. It (cutoff lines) droop in the middle of both headlights. No way to correct it. There were excessive sealant that oozed on the edge, which caused the headlight to "stick" to the fender. Kind of like string cheese when you pull the light off the car. There were clear tape covering the excess selant around the headlight. No amount of adjustment could make the cutoff to level out. Came to the conclusion that the projectors themselves were mounted misaligned from factory. Only way to correct the cutoff would to disassemble the headlight and turn the projectors. End up returning it and had the oem headlights retrofitted.
  28. Oct 16, 2018 at 3:43 PM
    #58
    TheBeast
    TheBeast The Beach
    yeah..hit or miss on the spyders unfortunately
    BrandonL812 likes this.
  29. Oct 16, 2018 at 3:53 PM
    #59
    BrandonL812
    Brandon
    2017 Sequoia LTD
    I really did like the style of it. Looks good. With HID bulbs in it, it had really good output. Their halogen h1 bulb were terrible. Worse then oem headlights.
    I tried to get quotes for retrofit service on the spyder headlights and it wasnt worth it. I really tried to like them, but can not stand the crooked cutoff..
  30. Oct 24, 2018 at 2:32 PM
    #60
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    How exactly do you adjust the aim on a 2nd gen?
