RCI front skid plate--Aluminium or Steel ?
Discussion in 'General Tundra Discussion' started by TheBeast, Oct 17, 2017.
RCI skid plate
  1. powdercoated steel
    91 vote(s)
    58.0%
  2. Aluminium
    66 vote(s)
    42.0%
  1. Feb 4, 2018 at 2:30 PM
    #121
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I had no problems communicating with RCI. They emailed me back within a few hours. A buddy of mine was able to change his order pretty fast as well.
    Sunnier[QUOTED] likes this.
  2. Feb 4, 2018 at 2:37 PM
    #122
    Sunnier
    Sunny
    San Diego, CA
    Glad to hear this! Maybe it's isolated but, since more than a couple guys have chimed in reporting they had problems, it'd be awesome if @RCIoffroad could chime in to reassure us that, whatever stuff might have been going wit on behind the scenes, that's fixed now....
    I sure hope so, since they're one of the big Go-To off-road suppliers... and that one-piece is awesome!
    15whtrd likes this.
  3. Feb 4, 2018 at 4:07 PM
    #123
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    Was easy as long as you don't mind sliding around under the truck. I used a jack stand with a towel over it to support one end as I held up the other. Used sockets on my drill to speed things up. Was all straightforward.
    RCI is local to me, but still had it shipped. Came in a couple of days. Haven't had to contact them, so can't speak to that aspect.
    Sunnier and T-Rex266 like this.
  4. Feb 4, 2018 at 5:36 PM
    #124
    Agitated1
    Los Angeles
    Install was pretty easy. Took me about 1.5 hours to install the front and transmission skid. No floor jack needed.
  5. Feb 4, 2018 at 5:38 PM
    #125
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    Sorry to hear that man. Hopefully @RCIoffroad will make it right for you.
  6. Feb 27, 2018 at 3:48 PM
    #126
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Those with aluminum skids. Can you look at the bottom of your engine skid.
    Are the bottom perimeter of your upright supports welded?
    Look at mine that arrived today, is this incorrect or a change that RCI made recently?
    Most of the aluminum skids that I've seen on here have the bottom perimeter of those upright support tubes welded.
  7. Feb 27, 2018 at 3:59 PM
    #127
    TheBeast
    TheBeast [OP] The Beach
    is it welded on the inside ?
    joonbug likes this.
  8. Feb 27, 2018 at 4:01 PM
    #128
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    if not, they're just gonna pop off the first time you hit something.
  9. Feb 27, 2018 at 4:17 PM
    #129
    OBXTundra
    OBXTundra Member
    Southeast USA
    The inside is welded, pretty solid. I guess I just expected the outside perimeter to be welded as well.
    I figured there were a few others who got the aluminum plate recently and might be able to compare.
  10. Feb 27, 2018 at 4:21 PM
    #130
    TheBeast
    here is a recent steel one...looks to be the same . they probably use the same process.
    Agitated1 and OBXTundra like this.
  11. Feb 27, 2018 at 4:36 PM
    #131
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I have the 1st gen two piece
  12. Feb 27, 2018 at 8:56 PM
    #132
    Gtfour43
    Gtfour43 New Member
    Oahu
    Looks incomplete not being welded on both sides. That would never fly where I'm at. I'd call and see what the reason was since @BlueBottle s was welded on both sides.
  13. Mar 2, 2018 at 10:49 AM
    #133
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    UPDATE- RCI Has refunded me the extra shipping charge that they charged me. I wanted to give them one more chance and provided the information and so all is good now. I will not hesitate to buy from them again and will absolutely do so. Thanks RCI for making it right!!!
  14. Mar 11, 2018 at 2:52 PM
    #134
    wh4x4
    wh4x4 New Member
    Just got my RCI skid plate installed -- I went with the powder coated steel. Easy install, though tough to maneuver with just one person. I added a few 1/8 inch rubber washers to leave a gap between skid plate and cross member so water could drain and not get trapped inside cross member. See pics of the OEM steel plate, aluminum foil can compared to the RCI, though the OEM does provide a bit more side coverage.
  15. Mar 11, 2018 at 3:15 PM
    #135
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    For the trans/transfer skid? I did it.
  16. Mar 11, 2018 at 4:11 PM
    #136
    GodlessPro
    Matthew
    NorCal
    I struggled with it a little bit, but it is totally possible. The bolts on the Pro skid plate have these captive cylinder spacer things, not sure what they are really called. After finally figuring that out and fighting with it a little bit, I grabbed a flat head screw driver to hold the spacer up while I aligned the transfer skid.
    joonbug and SoCal619 like this.
  17. Mar 12, 2018 at 8:04 PM
    #137
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I looked at the RCI but I feel like the 1/8” isn’t thick enough for our trucks. I’m planning on ordering a set of 3/16” steel skids from BudBuilt on Friday. Does anyone else make skids for Tundras? All I know of are RCI, BudBuilt and PP engineering, but PP doesn’t have a 26g gas skid...
    Sas likes this.
  18. Nov 16, 2018 at 5:38 PM
    #138
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    Been struggling with this the last half hour. Not sure how you were able to hold those spacers up to align it. Got one side, then lost that one while fighting with the other. Those spacers don’t really slide up easily at all
    joonbug and GodlessPro[QUOTED] like this.
  19. Nov 20, 2018 at 7:22 AM
    #139
    GodlessPro
    Matthew
    NorCal
    Did you get it? If you need help, let me know.
    joonbug and Cemented[QUOTED] like this.
  20. Nov 24, 2018 at 7:57 PM
    #140
    Cemented
    Manuel
    2017 Cement TRD Pro
    Thanks. Gave up that night and then have been out of town. Will try again on that and the fuel skid once it’s it raining.
    GodlessPro[QUOTED] and joonbug like this.
  21. Nov 24, 2018 at 8:09 PM
    #141
    Aurora CO
    I Gorilla glued the spacers in place on the skid. Made all the difference.
    GodlessPro and Cemented[QUOTED] like this.
  22. Nov 24, 2018 at 8:12 PM
    #142
    Cemented
    Manuel
    2017 Cement TRD Pro
    Good call
  23. Nov 24, 2018 at 9:22 PM
    #143
    goffredo
    goffredo Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    I can't believe I just read 145 messages about skid plates!
  24. Nov 24, 2018 at 9:29 PM
    #144
    Aurora CO
    146 now...heh....heh..
    RollCage, TheBeast[OP] and T-Rex266 like this.
  25. Nov 24, 2018 at 10:39 PM
    #145
    TheBeast
    welcome to the forum :)
    goffredo[QUOTED] likes this.
  26. Nov 24, 2018 at 10:57 PM
    #146
    RollCage
    RollCage New Member
    Alex
    2002 Tundra AC, 4x4, V6, Auto
    Probably would have buckled just as bad if it were steel. Explanation below (for those that care):
    Some quick maths for y'all:
    Yield strength (YS) of:
    1018 Steel = 53,700 PSI
    5052 Aluminum = 28,000 PSI
    So now we get the cross sectional (CS) area (assuming 1" wide):
    10ga Steel Piece = 0.141 in^2
    1/4" Aluminum Piece = 0.25 in^2
    Multiply YS and CS and cancelling out units gives us each piece bending (and not bending back) at:
    Steel = 7,551 lbs of force
    Aluminum = 7,000 lbs of force
    So in this instance, they're pretty much comparable. Considering they're so close, it would come down to QC on material mfg control, and how well they were welded. That's about it.
    Admittedly I'm assuming RCI uses 1018 steel, which they may or may not. It's not listed on their site, so the steel they use could be weaker or stronger. Maybe they can jump in and tell us. But then I'd have to ask about their weld types/sizes/fillers, etc. cause I'm a nerd like that...
    tl;dr:
    GENERALLY speaking... Aluminum is a third the weight, and half as strong. So if you double the thickness of the aluminum part, it makes up for the weaker tensile strength. Generally.
    For me personally, I like the lighter weight of Aluminum, and the fact it wont rust.
    Just my unsolicited 2 cents...:pccoffee: :D
  27. Nov 27, 2018 at 1:53 AM
    #147
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I don't speak your language, but I get what you are saying. I assume you are a fabricator/engineer? They usually speak your type of lingo. I do agree with ya. A jump like that would buckle both, I'm sure, would it buckle less and cause less damage? That I can't really say, but from what you just stated, it would be just as bad or close to the same result. I would love to see a truck jump comparison. Even then, there would be a debate over that.
    BlueBottle and RollCage[QUOTED] like this.
  28. Nov 27, 2018 at 1:56 AM
    #148
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  29. Nov 27, 2018 at 1:15 PM
    #149
    RollCage
    RollCage New Member
    Alex
    Pretty well sent :D
    And yeah, basically what I'm saying, is that assuming that RCI designed these right, steel or aluminum, it probably would've buckled the same.
    Just remember, a skid plate ≠ a bash plate. Can these skid plates handle abuse? Sure. But if they were designed so that we could drop our trucks at speed or height onto rocks all day long, they'd be a hell of a lot thicker and heavier.
    dcsleeper408 likes this.
  30. May 1, 2019 at 7:22 AM
    #150
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    This thread is pretty old and was a lot of reading. I am shocked that RCI never joined in the conversation to put to rest concerns/issues members have/had. I did not realize the metal was so thin. Hmmm, onward with my search
