2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Dec 31, 2017 at 9:00 AM
    #721
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes.
    I provide information with my installation instructions on how to connect the FRAC harness with a SwitchPros system. It takes three of the switchpros switches; Fwd cam, Aft cam, and VIM (if you have OEM Nav). There is an additional relay/diode harness required for the VIM interface. I provide the wiring instructions for that so you can build your own, or I can build it for you for an additional $25.00 plus shipping.
    dcsleeper408 likes this.
  2. Jan 8, 2018 at 10:17 AM
    #722
    delta6b
    delta6b New Member
    2016 limited TRD 4x4
    Backflip Tonneau Cover Bilstein 5160/6112 Fuel Maverick 20x9 +20 Offset Toyo Open Country RT 305x55 R20 Pop & Lock Tailgate Lock Husky X-Act Contour Mats TRD 4x4 Off Road replacement Husky Logo Center Console Safe AJT Design Key Fob ESP Rear Seat Storage FRAC V2 Oh Shit Handle
    Has anyone used this camera for their front emblem! Didn’t come with instructions and there doesn’t seem like there’s a way to secure it in place except to use some hot glue or something! I also have the other version that sticks out a bit n it has a bolt and plate to secure it in place! Or am I missing something? 54A57678-687A-4E27-A45D-6AC377D17898.jpg
  3. Jan 8, 2018 at 12:51 PM
    #723
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I have both cameras and used the one that sticks out just for the same reason. I could not figure out a good way to mount securely.
    -Mike
    delta6b likes this.
  4. Jan 8, 2018 at 2:31 PM
    #724
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I think a couple guys have glued it in place. You might also be able to use a small hose clamp type device installed around the camera body and behind the emblem to secure it in place.
  5. Jan 8, 2018 at 2:52 PM
    #725
    delta6b
    delta6b New Member
    Cool, I’ll try that!
  6. Jan 8, 2018 at 3:15 PM
    #726
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Excellent. Takes some pics if you would. I've suggested that approach before, but I don't think anyone has tried it yet.
    And you might need to fab a backing plate with a hole to fit over the camera body. This will give the clamp a surface to press against.
    619Tundra likes this.
  7. Jan 13, 2018 at 5:59 PM
    #727
    Al92toyo
    Al92toyo New Member
    Alex
    2018 White Tundra Crew Max Platinum 4x4
    Hey @TundraTex what is the best front camera you have seen out there?
  8. Jan 14, 2018 at 11:17 AM
    #728
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Being a "form follows function" kind of guy, my answer to that question is definitive... It depends on what's best for your needs.
    Some cameras have CMOS sensors while others have CCD. Some have guidelines, others don't. Some are water-proof, others not so much. Some mount vertically, others horizontally. Most guys ask your question with the thought of quality and durability in mind, because you don't want a piece of crap that's going to die on you a week after you install it. For the range of cameras most folks are using, you're going to spend $10 to $30. As far as quality goes, this is pretty rock solid technology so there's not much that can break.
    My $30 camera has been installed for a little over a year now and I use it every day. It's still working great and provides a great image. So my advice is to search for cameras on Amazon or e-bay, find one that suits your mounting needs (depending on your grill), buy it, and don't worry about it failing.
    Bprose likes this.
  9. Jan 15, 2018 at 2:42 PM
    #729
    Al92toyo
    Al92toyo New Member
    Alex
    Great, Thanks!
  10. Jan 18, 2018 at 10:55 PM
    #730
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
  11. Jan 19, 2018 at 6:50 AM
    #731
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I'm guessing the extra terminal is for backlight illumination. You'd have to look at the data sheet to make sure. You can tie that lead into your dash lights.
  12. Jan 20, 2018 at 10:55 AM
    #732
    TheBronze1
    TheBronze1 New Member
    Al.
    Maryland
    2017 bronze mica 1794
    bed cover, upgraded stereo system, light bar in hood and front grill, bed lights, switch back lights by step bars
    camera finally came from china. can finally install my frac harness
  13. Jan 21, 2018 at 7:36 AM
    #733
    slide187
    slide187 New Member
    Boston, MA
    2015 Silver Sky Metallic DC Limited Tundra
    Console Cavern Organizer Mod, Driver's Forward Assist Handle Tonno Pro Hardfold, Body Colored Door Handles, Body Colored Mirror Caps, MBRP Stainless XP Series Dual Exhaust, OEM Bed Extender
    Can anyone who actually DID install the flush type logo mount camera post a pic of what that camera sees? If you've read this whole thread, which I have, I think we've seen only 2 peeps go with the more flush option in the logo. We've also seen courtesy of @TundraTex that with the style that pokes out of the logo a little you can see down as far as +/- 1 foot out from the front bumper. So from what I can tell the pokey-outy cam is a solid install, works well and has a good field of view, but see's pretty close to the bumper. And the flush mount style is a less solid install possibly requiring some glue or other MacGuyver-type mounting solution. so i guess for me, if the flush mount can't see as close to the bumper as the one that sticks out, then its probably not worth the headache. so, @CarlitosWay or @TheBronze1, can you guys answer that question possibly? any info is greatly appreciated.
    Also, @TundraTex, I'm almost ready to pull the trigger on a FRACv2 but I've completely lost my perspective on the timeline after reading this, @BlueBottle 's review and your various vids thru the process.... hahaha, So are you at a point now where we can just place an order? or do we still wait for groups to fill up? Seems like we just send you an email now with all the required info and go from there?
    Thanks again everyone for any info.
    Sunnier and TundraTex[OP] like this.
  14. Jan 21, 2018 at 11:29 AM
    #734
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @slide187 at the moment I am filling orders as they come in. Email me with the info indicated in Post #1 of this thread and I'll process your invoice. After payment is confirmed, your kit will be assembled, boxed, and shipped within 5 business days. I'll be on the lookout for your order!
    Sunnier and slide187[QUOTED] like this.
  15. Jan 21, 2018 at 5:47 PM
    #735
    j2007
    j2007 New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    I installed mine today. @TundraTex got it to me really quickly after I emailed. I installed the camera last weekend when I did my lights but just finished it. I pretty much cloned @BlueBottle’s install - same camera and switch locations in my 2017 Limited. FRAC is awesome! The image from the front camera looks great and it’s always annoyed me that the passenger can’t use the nav while the truck is moving. This is going to be so useful.
    TundraTex[OP] likes this.
  16. Jan 22, 2018 at 7:35 AM
    #736
    delta6b
    delta6b New Member
    I have the same camera! I ended up hot gluing it in place cause there’s no way to secure it in place! It’s been in a few weeks now and so far so good!
  17. Jan 22, 2018 at 3:51 PM
    #737
    toyotech2016
    toyotech2016 New Member
    2016 Tundra 1794 2004 Tundra TRD 2004 Sequoia Limited 1988 4Runner LT
    Got mine installed in my 2016 1794 using a Noauka camera.
    Which is a very nice unit for the price. According the the instructions it said to cut the green wire for front camera which was wrong. Has to cut the white for it to see image correctly.
    Might change the camera because I was hoping to install it with the thread part horizontal instead of vertical. Being vertical made the install harder for me and ended up installing it into the lower bumper. Was hoping to install it in my EAG grill.
    So if someone knows of a Camera like the Noauka but can be installed horizontal. That be great.
    A little disappointed that my gps didn't work when disabling the VIM. Others have said their GPS still worked. Mine didn't. The arrow just sits at its last known location when VIM switch is flipped. I knew it was a 50/50 going in and probably best I don't mess with the Navi while driving anyways.
    A little video showing its operation. Didn't realize how much room I had up front when stopping at lights lol.
    https://youtu.be/oSiN-eQ1Yzw
  18. Jan 22, 2018 at 5:17 PM
    #738
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Your supposed to turn the VIM back off after you input your destination so that your location will refresh.
    slide187 likes this.
  19. Jan 22, 2018 at 5:27 PM
    #739
    toyotech2016
    Others have said they were able to leave it off and still work.
  20. Jan 24, 2018 at 3:17 PM
    #740
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
  21. Jan 24, 2018 at 3:23 PM
    #741
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    sweet tunes
  22. Jan 24, 2018 at 7:21 PM
    #742
    toyotech2016
    Thanks
    It should work. I might change mine to this one due to the EAG grill
  23. Jan 25, 2018 at 9:09 AM
    #743
    nk1794
    San Jose, CA
    What's EAG grill?
  24. Jan 25, 2018 at 9:12 AM
    #744
    DexterL
    DexterL New Member
    email sent for an order! Thanks, still debating running it on the switch pros system
  25. Jan 25, 2018 at 2:01 PM
    #745
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Email invoice has been sent.
  26. Jan 26, 2018 at 11:03 AM
    #746
    toyotech2016
    nk1794[QUOTED] likes this.
  27. Jan 27, 2018 at 8:10 AM
    #747
    nk1794
    San Jose, CA
  28. Jan 28, 2018 at 11:19 AM
    #748
    slide187
    slide187 New Member
    Boston, MA
    Installed my camera, I got the one for the emblem like @TundraTex. Perfect fit. I didn’t like how you can’t really tighten the nut that holds it to the emblem, so I did it hand tight plus like 1/4 turn and I lock-tited it. I don’t have plans of un-modding it and the wire tail is short enuff to where it plugs into that red break out wire that it lands at the washer fluid tank. So I can just unwrapp/unplug it there to get the grill off in the future.
    Its goofy, but only if you stare at it... don't make it weird...
    I also remember what a BEEEEEEYOTCH it was getting thru that stupid grommet/nipple/“mini-dink” (as @4x4_Angel likes to call it haha) thing in the firewall when I did the 2018 lights so I did my pop-n-lock at the same time. But my frac harness gets here tomorrow so I coiked everything up in the side panel til it’s here and I can finish.
    I had a limited with only 1 spare blank in the dash so my camera on/off/on is going here:
    And I plan to just put the VIM switch here since there shouldn’t be clearance issues and I don’t think it’ll be an eyesore at all really if I do it cleanly.
    nk1794 likes this.
  29. Jan 28, 2018 at 12:10 PM
    #749
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Looking good, @slide187. I’m not sure if the camera switch harness is long enough to reach to the other side of the steering wheel where you are installing it. I don’t know of anyone else who installed it there. You might want to have some spare wire on hand to extend the three wires just in case. Let me know how it turns out!
  30. Jan 28, 2018 at 12:16 PM
    #750
    slide187
    slide187 New Member
    Boston, MA
    yup, haha I have miles of it on-hand. The right side of my steering wheel is all full up.
    TundraTex[QUOTED][OP] likes this.
