ReadyLift 6
Discussion in 'Suspension' started by hollandhunter, Jan 18, 2018.
  1. Jan 18, 2018 at 6:14 PM
    hollandhunter
    hollandhunter [OP] New Member
    2017 SR5 CM 4x4
    Who all has the ReadyLift 6 or 8inch kit. Pros and Cons? Pics?
    Jsena likes this.
  2. Jan 18, 2018 at 6:52 PM
    Checking in! RC 6" lift here looks nice ride quality sucks! Who ever installed didn't install correctly as per installation instructions the rear cross member wasn't cut ..soooo if I wanted I cud get rid of this lift but I wud need OEM knuckles...I mean it looks great just ride quality it's a spacer lift so not good for off roading..also CV axle angles are flexed out at both ends not horizontal so you can bust a boot or what not turning radius decreases.. I ride on 35s 20x10 wheels
  3. Jan 18, 2018 at 6:56 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I have the 8", only have about 2500 miles on it so far, but so far so good. Only complaint I had was it removes the stock skid plate(no biggie) but the kit doesn't come with anything to reattach the bottom of the valance to. I have nutsert tool, so a quick trip to the hardware store for some bolts and nylon spacers and it was all fixed up. Here's a pic from the day I picked it up from the shop, 37x13.50r22 on 22x10's. Needed some trimming behind the front bumper and a cab mount chop to clear with no rubbing lock to lock during normal driving.
  4. Jan 18, 2018 at 7:07 PM
    Cuzican
    Cuzican New Member
    Louisiana
    And another after some of the chrome disappeared.
  5. Jan 18, 2018 at 8:24 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    See HOW NICE his BLACK TUNDRA LOOKS !!!!!:headbang: :headbang: :headbang:
  6. Jan 18, 2018 at 9:07 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ready lift is a nice setup.. it was my next option for sure,!
    hollandhunter[OP] likes this.
  7. Jan 18, 2018 at 9:21 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  8. Jan 18, 2018 at 10:47 PM
    Joshea
    Joshea New Member
    JC
    2015 Tundra Limited Crewmax
    Awesome
    Jsena likes this.
  9. Jan 18, 2018 at 11:00 PM
    xSkeme
    xSkeme New Member
    2017 White Tundra SR5
    7" BDS Coilover kit here...the stance is badass and it rides better than stock. I wouldn't choose any other kit ever but that's just me :)
  10. Jan 19, 2018 at 3:51 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Interesting, I have never ever heard anyone with a 7” lift say it rides better than stock. Stock suspension is pretty soft. It’s been said by many installers the higher you go the more rigid or stiffer the ride.
    :notsure:
  11. Jan 19, 2018 at 4:52 AM
    Cuzican
    Cuzican New Member
    Louisiana
    That's true if you pinch pennies, but my old F250 with an 8" lift on 38x13.50R24's rode much better than stock. I didn't buy the most expensive stuff out there, but I also didn't buy anywhere near the cheapest either. Currently my truck is a bit stiffer in the front than stock, due to the pre-load spacer, but I expect a drastic improvement when the Fox coilovers go on.
    xSkeme and hollandhunter[OP] like this.
  12. Jan 19, 2018 at 5:18 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Tracker, Jsena, AxelsHumanDad and 4 others like this.
  13. Jan 19, 2018 at 5:30 AM
    1UPPER
    TEXAS
    Flux capacitor!
    I'm really enjoying my current suspension setup. It's still a different ride from stock. If you wanted a lifted truck with a softer feeling truck I would look into the pro comp long travel suspension. It's not a 7" lift probably closer to 3". For a 7" lift I elected to go with Pro Comp and use fox Shocks. All though a lifted truck will typically ride more stiff. There are things you can do to make it ride better. Better Shocks, Coilovers not stretched out, adjustable Upper Control Arms, replacement leaf springs to remove blocks, rear shackles, coach-builder steering ends and coach-builder shim kit. But it adds up to a lot more money.
  14. Jan 19, 2018 at 6:15 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have the 6" but only because my warranty wouldn't let me go 8". Love the ride quality, driveline geometry was maintained, customer service is unrivaled. Highly recommend Readylift! I did have spacers but replaced with Fox 2.0 coils.
  15. Jan 19, 2018 at 7:04 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    8" ready lift here.. 37x13.5, 22x12 wheels. had to chop the bumper and cab mount as well, but im running -44 offset.
    Mine rides great, love the quality of the ReadyLift. They are a little more pricey, but I say you get what you pay for. it also comes with a lifetime warranty.
    here's a couple pics. IMO, the truck looks way higher without the steps lol but I don't wanna rip my pants jumping in and out
  16. Jan 19, 2018 at 7:11 AM
  17. Jan 19, 2018 at 7:42 AM
    SullyMoto19
    Tyler
    Houston, Texas
    my plan is to have the truck looking much meaner by the end of the year. stay tuned
    :benchpress: :anonymous:
  18. Jan 19, 2018 at 7:47 AM
    :popcorn::pccoffee:
    SullyMoto19[QUOTED] likes this.
  19. Jan 19, 2018 at 7:53 AM
    Joshea
    Joshea New Member
    JC
    How do you guys get such deep dish rims to work? Is it a larger offset?
  20. Jan 19, 2018 at 8:12 AM
    hollandhunter
    2017 SR5 CM 4x4
    My truck looks like yours. I wanted a 8 but settled for the 6. Because i have kids and didnt wanna pay for 37s and gears. But i have to say your truck is freakin BA looking. Love it.
  21. Jan 19, 2018 at 8:15 AM
    hollandhunter
    2017 SR5 CM 4x4
    Yea less offset pushes the tire out. I went with -24 alot of guys go bigger like -44 or more. Looks great too.
    texasrho83 likes this.
  22. Jan 19, 2018 at 8:43 AM
    SullyMoto19
    Tyler
    Houston, Texas
    appreciate it! 6'' is a great height. you aren't sacrificing a whole lot and prolly better for the kiddos. but yeah I plan on doing the regear in the next couple of months. hopefully that 5.29 gear package stays course for april, fingers crossed! definitely kills the MGP without a regear, but that was a sacrifice I was willing to make hahah :fistbump:
  23. Jan 19, 2018 at 8:56 AM
    hollandhunter
    2017 SR5 CM 4x4
    If my truck turns out half as good as yours looks i will be happy. As for the mpg i only drive about 10 to 15 miles a day. An we might take my truck on vacation once a year. I dont get great milage now. About 14 or 15. So its all good. Small price to pay to have a bad as truck like you have. I have seen people trade there tundras in to gain a couple miles on the gallon. Screw that. I will take reliabilty and looks over milage anyday.
    Peace!
  24. Jan 19, 2018 at 9:04 AM
    hollandhunter
    2017 SR5 CM 4x4
    I wish toyota would have put the front pillar grab handles on drivers side too. Dont know why they just put them on the passenger side. Anybody know where to buy one at? Im only 5 10 getting in and out might be a lil tricky. Again small beans but just thinking a head.
    Also talked to boss 4x4 yesterday and they was saying that bilstien should have a aftermarket coilover for us readylift 6 and 8 guys coming out soon. Told him to let me know as soon as they released.
  25. Jan 19, 2018 at 9:22 AM
    SullyMoto19
    Tyler
    Houston, Texas
    well, guess im gonna be broke for the rest of 2018 :rofl:
  26. Jan 19, 2018 at 9:40 AM
    Check your local Craigslist area type in Toyota tundra parts some people will part out tundra parts or check your local scrap yards pick-a-part places a 2nd gen will work u just need 2 pieces of hardware check the MOD section there is a write up on it...
  27. Jan 19, 2018 at 9:43 AM
    https://houston.craigslist.org/pts/d/2007-toyota-tundra-for-parts/6422915715.html
    See what I found
    7th pic..
    https://houston.craigslist.org/ptd/d/toyota-tundra-crew-max-for/6447676091.html
    Paid $25 for mine
    SullyMoto19 and 1UPPER like this.
  28. Jan 19, 2018 at 11:25 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I run a -44 offset. this is a standard 12" wide wheel offset. I believe I have an 8" lip on my wheel, so its pretty deep dish.
    but the larger (negative number) the offset, the higher you'll most likely have to go. Once you start pushing the wheels outside of the wheel wells, you start to rub pretty good. So you can either trim, go higher lift, or both.
    The guys that installed my lift did a great job trimming the bumper for me, so you cant even tell.
  29. Jan 19, 2018 at 12:55 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    The Con: stop Reading these gadurnn threads!!!
    Why on earth am I reading a thread at 3am, then next minute after 3am,, am ordering that item????? WHY??? .....
    Read a post about 4:88 gearing.....now I want sumadat for my 35’s x 6 inch!!
    Read another post about nerf..... I had to get somadat!!!
    Read another, and another, then next thing I don’t have lunch money.....
    Ok, what is my next mod???? I’ll live off my fat!!!
    Mod-addiction-unanimous- member
  30. Jan 19, 2018 at 1:52 PM
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Dammit, I hate these threads.:p
    I miss my lifted truck I parted with. I keep casually browsing lifts for my current truck. Every time I see the suggestions for lifts my credit card inches closer to the website shopping carts... :thumbsup:
    Prostar 190 likes this.
