Wheel spacers
Discussion in 'Wheels & Tires' started by TundraTss, Oct 31, 2017.
  1. Oct 31, 2017 at 5:35 PM
    TundraTss
    TundraTss [OP] The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    So I had my new tires put on today, but they were rubbing on my UCAs. Just BARELY, but rubbing nonetheless. Ended up ordering a set of 4 1” spacers.
    For those of you running spacers, when you had them installed did you use loc-tite or do you just re-torque them every few thousand miles or what??
    I read somewhere that they need to be tightened every thousand miles, which seems like it would be super annoying.
  2. Oct 31, 2017 at 6:08 PM
    Zeb8806
    Zeb8806 New Member
    2014 Tundra Crewmax Limited
    I used a couple drops of medium strength lock tite on mine. Theoretically you should not need lock tite, just like you don’t need it on your wheel lugs. Make sure you do not over torque the nuts if you use any sort of loctite, it acts as a lubricant and can cause you to over tension and potentially yield the stud.
    4x4_Angel and TundraTss[OP] like this.
  3. Oct 31, 2017 at 6:26 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Treat them as another part of your maintenance routine. Just check them every now and then, you won't have any problems. I used to check mine every 5000 miles.
  4. Oct 31, 2017 at 8:07 PM
    TundraTss
    Brandon
    2019 TRD SR5
    Right on, sounds good.
    Thanks fellas.
  5. Dec 23, 2017 at 7:34 PM
    Silver8
    Silver8 New Member
    2012 Silver Tundra TRD Limited w/Supercharger
    Hey, just wondered how the spacers worked out for you? I've got some rubbing on my Camburg UCA's and I'm considering wheel spacers as well. Running 285/70/18's on standard rims, lots of tread, so likely won't be swapping them out soon. Reading about this and found some people mentioned having to cut the wheel studs down if they went with anything less that 1.5" spacers. I'm not opposed to going to 2" spacers, but if I only need 1.25" or 1.5" to eliminate the rubbing, than so be it, but I don't want to cut the studs... I've only had the truck for a couple months, just learning the ropes, hoping this question isn't a dumb one. Any advice you can offer would be much appreciated!
    Oh, and should I stick with Bora, or are some of the other spacers fine as long as they have the lip and are made from T6 Aircraft Billet? Thanks again!
  6. Dec 23, 2017 at 10:29 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    Spidertrax, I got them from @ToyTec Lifts, great service, forum discount. Loctite, check them after about 500-1000 miles. I got 1.25 and didn't need to cut the existing studs. I thought about the Bora's, but there's a thread on here about the counter bore being too shallow. Don't know if that's common, but it sent me to the Spidertrax. By the way, Spidertrax spell check wants me to use Aspidistra, huh?
  7. Dec 24, 2017 at 1:29 PM
    Silver8
    Silver8 New Member
    Thanks for the information, much appreciated!
  8. Jan 14, 2018 at 7:05 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @john did you use lug nuts that came with spacers, or did you go with a longer one? I watched a video of an installation and mechanic was like throw them away. Essentially he went with a longer lug, which makes sense. Just curious. Thanks
  9. Jan 15, 2018 at 6:00 AM
    JMB
    Chesapeake, VA
    I used the ones that came with it. Everything fit just fine.
    rons23[QUOTED] likes this.
  10. Jan 15, 2018 at 8:15 AM
    rons23
    Ron
    Kill Devil Hills
    Awesome John. Thanks for your help neighbor
    JMB[QUOTED] likes this.
  11. Feb 12, 2018 at 8:55 AM
    SuaveRC
    SuaveRC New Member
    How is everything going for you with these spacers up to now? Any issues? I'm looking to do something like this and wanted as much feedback as possible. I love my TSS off-road package with the nice black 20" rims, just wish they stick out a bit more. I'm wondering of 1.25 would be best for me? My tires are 285 55 r20
