TRD OR Wheel as a spare?
Discussion in 'Wheels & Tires' started by Rngr188, Jan 14, 2018.
  1. Jan 14, 2018 at 5:04 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I'll need new tires in 10-15k miles and pretty sure I'm going with Nitto RG in a 275/70r18. If I were to find a matching TRD OR Wheel, mount a RG to it, and rotate it in as needed would the wheel get scuffed up when it's acting as the spare? I'm thinking if I go a size bigger I'd want a matching size spare and wheel and might as well rotate the spare in but don' want the wheels to get damaged when they are rotated to "the spare". Definitely don' want to be like the girls that drive Jeeps on 20" whels with 35s and the stock spare on the back:stirthepot:.
    zcarpenter92 likes this.
  2. Jan 14, 2018 at 8:06 PM
    Rngr188
    Chad
    Harrison AR
    I guess my main question is this; if I bought a matching TRD OR Wheel would it get scuffed or scratched when it is tucked under the bed as a spare?
  3. Jan 14, 2018 at 8:35 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No, can’t damage the wheel under the bed.
  4. Jan 29, 2018 at 6:07 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    I've had my spare tire on a TRD Offroad Alloy since summer 2014, with a TPMS sensor installed. First tire on it was the OE spare Michelin LTX A/T 2. I upgraded to five 275/70R18 Michelin LTX A/T 2's LRE about eight months later - on the original TRD wheels.
    There's absolutely no risk of damage to the spare wheel - only the tire contacts the underside of the truck, not the wheel. The spare does get very dirty (salty too, but no problem with that in AR!). Best to clean and wax the spare wheel thoroughly before cranking it up under the bed. Tire protectant helps the rubber, too.
