Snow chains for the Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by erm626, Jan 11, 2018.
  1. Jan 11, 2018 at 5:45 PM
    erm626
    erm626 [OP] New Member
    Ed
    Norfolk, VA
    2014 Whire Tundra Double Cab
    This probably has been covered, to save some time. Can i use snow chains first of all. If so what about the use of cable chains or the plastic type ? Since I live in Norfolk VA, emergency use only
  2. Jan 11, 2018 at 5:48 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I have never heard of a vehicle not being able to use chains....so I'm going v to definitely say yes our tundys can use chains. I have never seen plastic chains....maybe someone else has. I would say as long as they fit your Tundy correctly you can you chains or cables
    erm626[QUOTED][OP] likes this.
  3. Jan 11, 2018 at 5:56 PM
    erm626
    Ed
    Norfolk, VA
    The reason I ask, Amazon when searching for snow chains, a message came up chains does not fit your truck. Even though I select the correct tire size ? Very strange
    4x4_Angel likes this.
  4. Jan 11, 2018 at 6:01 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    Maybe it thinks there is a clearance issue for some reason. Here is a link from a couple months ago. I have a set of real chains for my 35’s just to be legal when going to the mountain. I’ve had to use them one time on ice. https://www.tundras.com/threads/snow-chains.17359/
    Marty McFly, erm626[OP] and 4x4_Angel like this.
  5. Jan 11, 2018 at 6:24 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Amazon can be retarded at times
  6. Jan 11, 2018 at 6:41 PM
    erm626
    Ed
    Norfolk, VA
    Thanks for all the info, I only wanted them for that just in case ! Not planing on any off road stuff !
  7. Jan 11, 2018 at 6:41 PM
    TheBeast
    TheBeast The Beach
    bought my cables from ebay. I used them on rear tires. 33"
    might be tight on front clearance if you run bigger tires.
    erm626[OP] likes this.
  8. Jan 11, 2018 at 6:49 PM
    LML 3500HD
    I believe your owners manual discusses the use of tire chains.
    Get two strap chains and be done. Needing a full set of chains might be a tad bit of overkill. Just a tad.
    erm626[OP] and Marty McFly like this.
  9. Jan 12, 2018 at 5:24 AM
    erm626
    Ed
    Norfolk, VA
    Colorado TJ Can you give the name of the supplier of those emergency chains. It Perfect !
  10. Jan 12, 2018 at 6:32 AM
    LML 3500HD
    tirechain.com
